Results 1 to 18 of 18
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default 2020 Spyder RTL Lights up the night!
    Got all the rest of the lights on these past couple days. Wife took a video of me ryding up/down the street to see how it looks. No one can ever say they didn't see me!
    Check it out:
    https://youtu.be/srY-eUsomiU
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Very nice.
    Quote Originally Posted by FINFAN3DP View Post
    Check it out:
    WOW..... Nice job .... So what brand / type etc. are the headlight/ DRL's ????? ..... Mike
    Feb 2017
    Wow doesn't quite describe it. From the front it looks like a super nova closing fast!
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Nice! As long as you didn't just make yourself a better target.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    Dec 2020
    Down South
    TricLED floorboard lights?
    Apr 2019
    Clinton, MS
    Oncoming might mistake you for a low flying UFO.
    I like it!
    Sep 2017
    Durham,Maine
    When you drive by a airport, do you have to call ahead for permission to pass??
    2012 RTL , Pearl
    Oct 2016
    Sebring, FL
    Oh yeah, if my 2020 had half that many lights.....
    Jun 2018
    HAYMARKET,VA
    All in all, I put on the TRICLED: Sequential Fender Lights, the Floorboard Lights, the rear Brake/Run/Turn Lights, Side Bag Lights, and the LED American Flag on the back. I think I'm done with lighting mods for a while.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Dec 2020
    Down South
    I want the tricLED floorboard lights, but don't know if they're compatible with the show chrome fender lights. The dealer installed them. I don't think they came with a plug n play harness. I believe everything was spliced and crimped.
    You did a nice job on the lighting
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by JohnRuckus View Post
    Thanks. Yeah, the dealer installed the show chrome ones on mine too. I took em off, and put Tricled's on. Simply cut the wires leading to it, and taped them off, then used the Tricled plug and play harnesses for everything else. VERY EASY. (With the exception of me not understanding one of the directions.)
    Baja Ron Sway Bar
    Key Cover from Ebay
    Active Member Doug44's Avatar
    Jul 2020
    Decatur, IL
    Check it out:
    IMHO w-a-y overkill might even be illegal in some (many) states. Again IMHO I consider this setup dangerous.
    Doug 2020 RTL F3 Short reach bars -factory backrest
    K9CRT Ham Radio
    Sold 5/27/2021 Spyder just wasn’t for me. Went back to Goldwing
    Dec 2020
    Down South
    Awesome! Thanks. Did you get rid of the show chrome b/c you didn't like them or b/c you couldn't use with tricLED floorboard lights?
    Jun 2018
    HAYMARKET,VA
    I didnt like em. Not bright enough, and tge sequentials are way cooler.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Doug44 View Post
    Well, ya know what they say about opinions! Hehehehe
    Baja Ron Sway Bar
    Key Cover from Ebay
    Sep 2013
    Spring Park, MN
    Actually the part about legality in some states is relevant. I'm in Minnesota and the rules here state only four forward facing headlights. I was pulled over 5 years ago by a MN State Trooper, was riding my 2016 RT-L with a spider pops bump skid that had the LED's. His comment to me was that it was "terrifying to the on-coming drivers and that he had me on two points. a) more than four forward facing headlights and b) you can't have white lights shining to the rear (except license plate) Spent 30 minutes in the cold with him alternately telling me that he was "pretty sure he was right" and unless I agreed with him to take a citation he was going to have me towed. I countered with they were not headlights but marker lights which are allowed and he should look up the definition of headlights with regard to candle power or lumens. Told him to call a supervisor and also mentioned he was not the brightest cub in the litter. He took it well because he started backing up on how sure he was it met the criteria for a violation. I finally decided to push the subject by telling him to tow me, write the citation, I'd have him subpoenaed to testify and also have someone from the MN DOT explain to him and his sergeant in court what constituted a headlight versus a marker light and that no, he didn't have the power to have a major manufacturer change their design. He actually said that with the fogs and headlights, the marker lights on the front fenders violated the statute and BRP / Can Am was going to have to recall their spyders. After 45 minutes in 40 degree weather he ultimately gave up, printed out the part of the statute he thought vindicated his case and said adios. Three years later I got pulled over by another State Patrol for speeding (valid stop, I was) and he comes back to me asking about the details to the earlier stop and WTF was that all about. He just shook his head to the story, handed me my license back said keep in down and have a good day.
    2016 Spyder F3-L Special Series
    2016 Spyder RT Special Series
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    That's amazing!!
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
