Results 1 to 10 of 10
    Mar 2018
    Monroe, NC
    Default 2018 RT-L Chrome - FM Radio Reception
    Just traded in my 2012 RT-S for a 2018 RT-L Chrome and noticed that the FM radio reception was, for lack of a better term, was crappy. It couldn't really get any local radio stations at all without static. I did notice that the antenna on the rear was a shorty type antenna. I am not sure if this is stock or aftermarket. Is the FM reception a known issue with this year RT-L or should I be looking for a possible disconnected plug or chaffed wire>
    thanks in advance
    Mar 2015
    forrest above Reno, Nv
    Lightbulb Just a thought
    Try removing the antenna and cleaning off any thread locking compound from the male and female threads. It has worked for others.
    Lew L
    2014 RTS , Circuit Yellow
    Apr 2019
    PA
    Make sure the flat ground (fat looking) wire is bolted under the seat. I’d unbolt it, brush and reattach.
    with both other posters ... it has worked for some ..... I also swapped the OEM antennae for a Bosche manual collapseable Auto antennae. this also gave me lots more stations to choose from ..... the entire antennae housing will fit in the right speaker box ./...Mike
    Nov 2020
    Lincoln, Nebraska
    I use iHeartRadio through my phone. I can also get Sirius radio.
    Mar 2018
    Monroe, NC
    Do you have a link to the antenna you used?
    Mar 2018
    Monroe, NC
    5EA6E183-C704-4EE4-A017-B36F8121B360.jpg5EA6E183-C704-4EE4-A017-B36F8121B360.jpgWanted to post an update here just in case someone else has this same issue. I removed the old antenna and found the threads hooped with loctite. Ended up destroying the old antenna removing it though. Replaced the mast with a new one about 18” longer and problem solved.
    Quote Originally Posted by NascarGuy View Post
    I bought it 6 + years ago on E-bay ..... It was a Bosche brand ... black manually collapsible auto antennae. I'm sure there are lots of other sellers with the same product listed as replacement antennae's, for auto's ..... sorry best I can do ..... in order for it to fit inside the housing, I had to change the angler slightly .... my antennae goes thru the rear most portion of the factory armrest .... looks stock ..... Mike
    Apr 2014
    NE O-H-I-O
    NascarGuy…Same hardware on my 2018 RTL. A bear to remove. Seems like BRP went thru a few different ways to mount the mast.
    Active Member Papa103's Avatar
    Aug 2019
    Maine
    My 2019 was this same. Very poor reception. I tried all the above plus an antenna booster. Ended up using pandora and bluetooth to my phone. It did get fixed when I traded for a 2021.
    2021 RTL Chrome Deep Marsala
    HELI Bars
    Garmin Zumo XT
    USB power port
    Front fender lights & Sequential turn signals
    Front LED Auxiliary light
    Flashing brake module TricLED
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    2021 RT Limited , Marsala Red
