Results 1 to 25 of 37
    Jul 2020
    KY
    Default Spyder has to stay at dealer?
    My dealer says that BRP policy says they have to keep the
    unit in-house while waiting for a backordered warranty part.
    The part is 3 Months out. Has anyone else been told this?
    I have tried for a month to get answers from BRP.
    TIA
    Where's that BS Meter when you need it!!
    You got any other dealers within a day's travel you could go to? If so, I would!
    Jul 2020
    KY
    Dealer told me if I take the Spyder,
    BRP will cancel part Order. I called
    BS from day one. Been calling and
    emailing BRP and always get replies
    of a supervisor will call you.
    Tell the dealership to open a case with BRP and take the warranty part off another Spyder.
    Bossier LoUiSiAna
    & or a loaner while you wait especially if is already decided to be warranty
    X's 10 ..... if this was your car do you think that stealer would hand you that line ...... the only time I've heard of a TIME delay was when the fix was under Warranty and BRP wanted to verify the part was broken ....Good luck ..... Mike
    Aug 2019
    Stoughton, WI
    What is this back ordered warranty part? Does said part make the machine un-rideable ?
    2022 RT Sea To Sky
    Feb 2020
    N. Wilkesboro, NC
    My thought is similar to what troop said. If the broken part makes the bike either unridable or at least unsafe to ride, I can see this. I can even see the dealer not letting you continue to ride if it's some sort of recall, even if it's still technically safe to ride. If not, keep calling BuRP CC (best of luck w/that) or file a BBB or AG complaint.
    Apr 2020
    Edgerton,WI
    Question
    Quote Originally Posted by snuffy210 View Post
    TIA
    What part is on a 3 month backorder?
    2019 F3L , Covid Blue
    Jul 2020
    KY
    Spyder is 2018 F3L. The backordered part is the "Left Hand Multi-Function Switch assembly".
    Not any safety issues, just won't go in reverse or manually downshift. TSB 2018-5.
    Here you go.
    My feeling is that this dealership does not want to do the work. Or, they are afraid they order the part and you get it done elsewhere. I believe that 'ELSEWHERE' is your key to resolution on this one.
    Jul 2020
    KY
    The dealership has my Spyder. If I pick it up I will be responsible for
    the $99 BUDS diagnostic charge. I have sent another email to BRP...
    Dec 2012
    Murphy, NC
    Possibly a short term solution would be for you to give them a credit or debit card number. This might make them feel more comfortable in letting the Spyder go. Then when the part comes in you could bring it back. Knowing that they have your number this would insure you would not get it repaired elsewhere.
    Another thought is that if the dealer really valued you as a customer they would take the switch assembly off of another Spyder in their showroom.
    2020 F3 Ltd
    Spyderpops Bumpskid
    The BS meter is in full operation here. The dealer is an outright liar. I would not trust them for anything. Are they cheating on their floor plan? And need to have stock on the floor to match inventory numbers? I know a couple places where that has actually gone on with other motorcycles.
    Time to find a better dealer. And they must release your Spyder, they cannot legally keep it.
    Feb 2020
    N. Wilkesboro, NC
    What's the name of the dealer? I'm not in KY but I'm sure others would like to avoid them, if possible.
    OMG .....I would be thinking " your State Attorney's office " ..... as others have said Total BS .... good luck .... Mike
    Jul 2020
    KY
    I will hold off on naming the dealer... for now.
    I took the Service Writers word that the hold Policy
    was from BRP. I will be contacting the dealer, since
    BRP Customer Support is non-existent.
    Do you have the part # or #'s that you need? I wouldn't mind checking for you and giving you a 2nd opinion on availability. Couldn't hurt.
    Sep 2020
    Platte City, MO
    So you can pick it up but will have to pay the $99 charge. Honestly that doesn't seem to unreasonable, but I think the
    dealer would work with you to waive, or refund, the fee if you brought it back to have the work done.
    Jul 2020
    KY
    The Warrantied part order will be canceled if Spyder leaves their shop. Pretty unreasonable.
    Jul 2020
    KY
    Great. Part # 710008091
    Thank You!
    Oops! Posted wrong # Earlier.
    Sep 2020
    Platte City, MO
    Yeah, that really is unreasonable, and I've never heard of a shop doing that. Hopefully there are other shops that aren't too far to use.
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Check out Cheap Cycle Parts - 710008091 Looks as if it may be in stock.
    Joe
    2023 F3
    Jul 2020
    KY
    Tried to call "Cheap Cycle Parts" keeps disconnecting??
    I believe the correct PN is 710006576. The original PN was 710005427 but is listed as changed to the former by Cheap Cycle Parts. CCP also lists the part as specifically for the 2018 F3 Ltd, amongst other F3s. PN 710008091 is listed by CCP as for MY 2020 and 2021 F3s. Send this post, along with a complete, polite litany of the BS you are getting from the dealership to brpcare@brp.com and ask them to get off their backsides and get a WARRANTY part, 710006576, for your Spyder from CCP, who has it in stock. Last step, find a new dealership.
