Results 1 to 6 of 6
    Oct 2019
    FL
    Default 2019 F3-S Passenger seat loose
    Hello
    I have a 2019 F3-S and for some reason, my passenger seat does not fit snug against the driver's seat. I'm not sure why. It locks in but as I ride the thing will push back and leave a gap like the picture shows.
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    yes my 2019 f3 was loose too, I did adjustment to it, works fine now, loosen and turn locking bolt 2 turns should do it
    richie spyder
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Mine is the same - I think it's due to the rider backrest pushing it backwards. It's forward / backward movement in the seat so I'm not sure the locking bolt adjustment would help - but I'm happy to be corrected?
    Does tightening that up help to keep the push fit tabs (I don't know how else to describe them - you can see one in the OPs photo) secured? Mine just doesn't seem to stay in on one side. I had a good play with it a couple of months ago but didn't get anywhere.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Jul 2020
    Brea, CA
    I think it is just because the backrest pushing backward, But the fix is pretty much simple with adjustment of locking bolts.
    Oct 2019
    FL
    Quote Originally Posted by AlanSmith7 View Post
    What locking bolts?
    Jul 2021
    LA
