Results 1 to 8 of 8
    Nov 2020
    Virginia
    Default 2013 RT Ltd Spyder Switch Cluster removal - any hints?
    Can someone tell me how or point me to a DIY on getting the switch cluster out of an RT Limited SE5? I know I started reading this somewhere, but I'll be John Brown if I can find it now. I found a thread in (archived) but it was not much help.
    2013 RT , White
    Bossier LoUiSiAna
    Nothing in manual?
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Nov 2020
    Virginia
    Correct. Nothing in owners manual. I don't have a maintenance manual.
    2013 RT , White
    Idaho
    Quote Originally Posted by RogDawg View Post
    Probably time to get one. Go to www.canammanuals.com and download a PDF version for about $24. Well worth it.
    2014 Copper RTS
    I've been in that area trying to remove ONLY the cluster of switches ..... I decided that the entire plastic piece is a one piece mold .... the switch area is not a separate piece. .... good luck .... Mike
    Nov 2020
    Virginia
    Default Switch
    Do you know how to get one switch out?
    2013 RT , White
    May 2018
    millsboro,delaware
    You didnt say what year it was but if youre talking about the switch cluster where you have your 4 rocker type switches that control things like air suspension ,handgrip heaters,and parking brake then I believe they are just standard rockers that have tabs on the sides to lock them in place.So to get them out you need to push the tabs in while pulling up.It could be a little tricky.I think you can see them from underrneath when you remove the body panel.I took out a blank in the middle and put in a usb socket and it was very easy.
    : 2017 RTL ORBITAL BLUE
