Results 1 to 11 of 11
    Nov 2016
    Arizona
    Default Anyone fit a Tail Box on a 2014 RSS?
    Anyone add a tail box on a 2014 RSS?
    Would like to install a tail rack and box.
    Put a Corbin trunk on both my 08 and 09 GS/RS models. The RSS should be similar.
    Bossier LoUiSiAna
    Think the sports rack /Top box stopped at the ‘13, at least what my ‘14catalog stops at, there is a passenger seat bag #280000320 $139.49
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    This is what I have on my 2016 ST-S...it's the Givi top box, matches my saddle bags.
    I already had the passenger backrest, and needed to add the rack for the top box to mount onto.
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    2016 ST-S , Steel Black Metallic
    Jan 2021
    Albany NY
    I know this is an old thread, but I'm in the same position - need to add the rack for the top box to mount onto. Where did you find the rack? Thanks in advance for your help
    Quote Originally Posted by Chuck518 View Post
    I made my own steel mount for my 08 GS and added a top box ..... this was before anything was made by after-market vendors .... It can be done ..... Mike
    Bossier LoUiSiAna
    EBay , however the case mounts to the backrest that mounts to the sports rack some have made other mounts5145FD64-A4BE-45DD-852C-17CEDED92CDA.jpg95477F5A-4AA1-42CB-9BC4-832101DFF5B3.jpg
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Apr 2020
    tucson az
    I did something similar but instead of cutting a whole on the mounting plate I cut a nylon cutting board to shape. I bought an extra plate for the tail and drilled holes for the mounting plate and cut the cutting board to roughly the same shape as the cover then mounted everything to the plate an put it in place then set the trunk onto the mounting plate.
    2011 rt , pearl white
    Very Active Member Vader's Avatar
    Jul 2014
    Hudson Valley
    Here's what I did on my GS..should be the same, or close..
    https://www.spyderlovers.com/forums/...7-Givi-top-box
    IT IS, WHAT IT IS...
    RT-S PE#0027 widowmaker2011's Avatar
    Jan 2010
    Orchard Park NY
    Well , this post is from 13 years ago right before my trip to the very first Spyder Homecoming in Valcourt Quebec. but this is my post of how I did I it. Your setup would be the same . This is prior to me adding the givi side bags which were added at the homecoming . Side note ~ The post linked below is from SpyderTalk which was the predominant Spyder forum ( which Lamont was a member of ) before he left and started his own , aka : Spyderlovers. Currently that SpyderTalk site is just archived info, but I mention it only because it has some really good reference stuff for the older spyders if you search around . https://www.spydertalk.com/threads/g...nstalled.5649/
    Back amongst the living May 2021
    2022 RT Limited Hyper Silver
    Out to Pasture:
    2013 ST Limited , Black Currant
    2022 F3L , Dark Edition
    2021 RTL , Chalk Chrome
    2013 RT Limited , Circuit Yellow Metallic
    2008 GS SM5 , Millenium Yellow
    2020 RT Limited Petrol Dark
    2014 RT Limited Champagne Black
    2012 RT Limited White
    2010 Timeless Black RTS SM5
    2010 Orbital Blue RTS SM5
    2008 GS SM5 PE 1941
    2008 GS SM5 PE2011
    Active Member hollybry's Avatar
    Jun 2016
    Southern Indiana
    Hey Bromfla! That is my spyder that you have a picture of with the cutout in the Givi top case mount!
    Did you have that spyder before? Orange 2011 RSS?
    2011 RSS SE5
    2011 RSS , BajaRon Orange/Matte Black
