Results 1 to 15 of 15
    Feb 2014
    albuquerque, nm
    Thumbs up After advice on pulling a trailer?
    ADVICE:
    I have a 2014 Can-Am RT Limited, I'm thinking a buying a "mypod max" motor cycle camper trailer. The camper weight is 580# with a tongue weight of 90#. I believe the cycle will pull the weight with no problem, but does anyone see any problems with this set up?
    Last edited by Peter Aawen; 03-06-2022 at 04:39 PM. Reason: Title clarification & spaces/layout
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    I see a lot of problems!
    Tongue weight 40lbs. Not really sure but tow weight about 450 or so your way out of specs!
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    I wouldn't . The Spyder hitch is poorly designed and isn't designed for that much weight.
    Mar 2013
    Maumelle, AR
    Look at this ad. It may be what you're looking for.
    http://www.spyderlovers.com/forums/s...e-Tent-Trailer
    2020 RT Limited , Chalk
    Default Omg !!!!
    People here worry that using 10/40 oil instead of 5/40 oil is going to VOID THE WARRANTY and you want to do WHAT ?????? .... Honestly, re-think this ..... 90 lbs is more than DOUBLE, and 580 lbs. is EMPTY. If you can't figure out what's wrong with this picture any in depth explanation I give would be Futile ...... Best of Luck .......Mike
    Jun 2010
    Las Vegas
    Russell, forget about getting that trailer it is way too heavy. Contact PrairieSpyder is selling her Leisure Lite camping trailer and that is a lot closer to the weight requirements of the Spyder. (I see now that the earlier link is to this trailer)
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Oct 2013
    Wood Village OR
    Default pulling a trailer
    Russel, I have over 50K miles of pulling different trailers with my RT , my tent trailer with all our gear in it is about 450 lbs and I have pulled it in ALL kind of conditions including snow I would think that what you are looking at is way over the boundary of safe. I I had to do it over and we still might is go for the Lesurelite , it sets up fast and is light.
    i phone photos 003.jpg i phone photos 004.jpg i phone photos 030.jpg i phone photos 016.jpg
    2014 RTL , Black Currant
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by easysuper View Post
    I pulled a lees-urlite for many seasons with my Goldwing, and it was a dream to pull,and yes.....it does set up very quickly.....less than a minute.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    First of all, never never never ever ever ever believe any weight specifications from any RV manufacturer. Never ever.
    For an example, we were looking at an Aliner Alite which was listed as 400 lbs. and was supposed to have a tongue weight of 40 lbs. It actually weighed 560 lbs. with a tongue weight of 90 lbs. This trailer was completely empty and had no options on it. I have seen other RV's like that so if you are going to buy a "lightweight" trailer to pull behind your Spyder make them weigh it in front of you before you pay them! No kidding!
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    May 2017
    TEXAS
    I went with the Can Am Accessories hitch, much stronger than the BRP hitch.
    https://www.canamspyderaccessories.c...trailer-hitch/
    Aug 2019
    southwest oHIo
    I can't give you any Spyder-related advice about towing, except for quoting what's in the manuals.
    However, I have been towing various trailers with two-wheeled motorcycles since 1978 and I'm still around to talk about it. Some of what I have learned can be applied to Spyders.
    One thing that has positively amazed me about Spyders is that it is the first motorcycle I have seen that not only allows towing, but Can-Am actually makes a trailer for it.
    Another of the things that amazes me is the fact that the trailer hitch attaches to the swingarm. I have known owners that have drilled the axle to reduce unsprung weight. I can not imagine intentionally adding up to 40 pounds, let alone what happens to stuff in the front of the trailer (or in a cooler on the tongue) when it is subjected to every single bump that the rear wheel hits.
    I'm not going to try to talk you out of towing a trailer, I'm just going to remind you to DO IT CAREFULLY.
    Feb 2012
    Spring City,Utah
    this post is 5 years old.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Actually only 3 1/2 years old! Sorry, couldn't resist!
    Mar 2013
    Maumelle, AR
    But the information is still relevant.
    SoFlo
    Quote Originally Posted by Mjhitman View Post
    Might consider rethinking the claim about stronger. The non gusseted hitch ball area might be an area of concern. Also, box tube construction builds light structures with minimal flex vs solid plate construction.
