Page 1 of 5 12345 LastLast
Results 1 to 25 of 109
    Aug 2019
    WI
    Default Laser Schmaser ?
    I have a 2010 RT with 17,000 M.
    I am prepared to be corrected, so don't hold back.
    As I understand it, the Spyder front end alignment is for "toe in" only. There is no adjustment for caster or camber. Correct ?
    If this is correct, I do not understand the big deal about a laser front end alignment.
    Does this just use a laser measuring device in lieu of a ruler ?
    If this is the case, I would really question the necessity of a laser.
    If "toe in" specs are available it would seem to me that it could be done with a ruler.
    I am not a Luddite, but I don't like being snookered either.
    I have heard the advertisements for high tech laser back surgery. I understand that the only difference is that the incision is made with a laser instead of a scalpel.
    It sounds impressive though.
    Apr 2019
    Clinton, MS
    I think you are overlooking the part where it is all in relation to the rear wheel.
    Correct no caster or camber …. but you forgot " Toe - out " ….. Yes it can be done manually, but a bit difficult …. If your " toe " is way off, the tire wear will be affected … sometimes minor - sometimes Major …. when a bad wear pattern starts - it ruins the tires, and pretty much correcting alignment won't save the tires. …. It is well reported here that the OEM - BRP alignment is usually OFF, my 2011 RSS wore evenly, but that was the exception ….. good luck …. Mike …. PS, I've had mine re-checked a few times and the alignment was still good.
    SoFlo
    Sort of. Castor is not adjustable. Camber technically is not adjustable. Toe is adjustable.
    I believe toe specs are published in the manuals, however they are expressed in degrees, not a linear dimension.
    You certainly can align the wheels without a laser setup. Be aware though you may need to null the steering electronics to prevent other problems.
    Jul 2019
    UK
    Number one; lasers are used because it's very difficult to get a measurement across the Spyder, physically, that is. The super-duper laser alignment attempts to get the chassis and all three wheels kinda neutrally aligned. Probably impossible unless you're very lucky and your rear wheel lines up with the chassis just as the belt runs true on the sprockets - not very likely. It sounds good but as soon as you drive along a road with a camber (most roads) the bike runs down the camber and you steer to counter that so the whole kaboosh runs out of line anyway.
    However, plenty of Spyders appear to have poorly aligned front wheels in relation to toe-in so getting that sorted is a good thing. Since you've got a 2010RT, the steering tie-rods are very flimsy and flex under cornering loads, if you have the wherewithal to address that, you'll find your steering and general handling is much improved. They also flex on the 1330 but they're a little better but the front suspension is rubber bushed anyway so is a bit wooly.
    3mm toe-in measured at the wheel rim isn't a bad place to start.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Aug 2019
    WI
    Thanks to all for good input and for not beating me up.
    PinkRosePetal,
    Front edge of rim to edge of rim 3mm narrower than rear edge of rim to edge of rim and squared with centerline of rear rim ?
    I live by your rule # 1 and have used that line for most of my life.
    Jul 2019
    UK
    Quote Originally Posted by 12tree View Post
    PinkRosePetal,
    Yup, 3mm narrower at the front of the wheel rim compared to the rear. You have 12" wheels so that gives you a tad more toe than it would on a 1330 with 13" rims. The front suspension has a certain amount of bump steer so your weight and the load in the front trunk will have a wee effect on the actual toe setting once you're riding.
    Good call, you might find you need it here too...
    Dec 2015
    Oakley Utah
    I have a 2010 RT with 17,000 M. I am prepared to be corrected, so don't hold back.
    As I understand it, the Spyder front end alignment is for "toe in" only. There is no adjustment for caster or camber. Correct? CORRECT
    If this is correct, I do not understand the big deal about a laser front end alignment; does this just use a laser measuring device in lieu of a ruler? YES
    Laser alignment is not necessary, but some people prefer having someone knowledgeable align their Spyder and those folks use a laser assisted system.
    2014 RTL Platinum
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    The biggest benefit of the laser is it projects the position of the toe-in well past the front and rear of the Spyder. This will magnify the error and therefore allow you to make a more accurate adjustment.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Jul 2014
    Mint Hill, NC
    If laser alignment systems, for both cages and Spyders, weren't more accurate than older systems dealers and independents wouldn't invest the considerable bucks they cost. The real key is the knowledge and meticulousness of the operator of the system.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2013
    Quote Originally Posted by PinkRosePetal View Post
    Yup, 3mm narrower at the front of the wheel rim compared to the rear. You have 12" wheels so that gives you a tad more toe than it would on a 1330 with 13" rims. ......
    Yup, 3mm narrower at the front of the wheel rim compared to the rear. You have 14" wheels so that gives you a tad more toe than it would on a 1330 with 15" rims. .........
    Probably best to try & get the details right Fixed it for you (in bold) above!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2015
    forrest above Reno, Nv
    Squared Away did a laser alignment on my 2014 RTS a few months after we purchased it. Its been great, I can ride the crown of a 2 lane road ( plenty of those here in No. Nevada ) with my hands off the bars no pulling left or right. Hands rest on the bars when not turning . A laser alignment, done properly ( by Joe and Ann) is a wonderful ( and probably necessary) addition to most new s. Me doing this with straight edges and a tape measure surely would not be as accurate. ( and quit calling me surely) [ a movie punch line----- What movie?????? ]
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2019
    WI
    Airplane, Lesley Nielson ??
    Mar 2015
    You win!!!!!!!
    ????????????? …. did " Lew L " mean " Shirley " ????????? ….. Mike
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Since I do all my own work, I built my own laser alignment system, based on plans found here, with some modifications. http://www.lindsayroland.com/spyder/...-DIY-gear.html
    2020 RT Limited , Marsala Red
    Jul 2019
    UK
    Oops, brain fart, thanks.
    May 2017
    Mesa, Arid-Zone-A
    I think this is one of those "You don't know what you don't know" situations. The bike may seem OK. But after having a proper alignment suddenly you realize just how much you were fighting the steering control. After having mine aligned by Joe, I could ride almost any road condition using just two fingers on the handlebars. I didn't realize how much I was constantly fighting the steering and the fatigue it produced. A correctly aligned bike is a lot more fun and easier to ride for long periods of time..... Jim
    Semper Fi
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Jetfixer View Post
    How do you reset the BUDS?
    2014 RTL Platinum
    Nov 2012
    North Las Vegas, NV
    Does this align to the chassis or to the rear wheel?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    SoFlo
    I read through the linked info. Seeing they measure from the rear wheel, it appears it may based on the rear rim.
    They do a few other things that seem incorrect, but if it is working, then so be it.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by canamjhb View Post
    100%.
    In the early days, Lamont & I took several, excruciatingly careful runs at aligning our Spyders. We followed BRP's instructions to the letter. They used the frame as the basis for alignment. It never worked regardless of how accurate and careful we were. That is because the frame is a very inaccurate way to align the front wheels. What you want, after all, is for all 3 wheels to be going in the same direction. When ROLO came out with their product and process for alignment. It really was a 'DUH!' moment for us. It doesn't matter what the frame orientation is. If the rear wheel is fighting (directionally) the front wheels. The Spyder is never going to handle correctly.
    The 2 major things that ROLO did was move the base line from the frame to the rear wheel using lasers to magnify (greatly) the error in alignment. The Spyder is so sensitive to alignment, that unless you greatly magnify the error, you just do not have a chance of getting it right. Rulers, tape measures and lines marked on the floor can easily be misaligned. Believe me. It only takes a little bit off and you're wasting your time.
    To be sure, the laser equipment is not magic. It still requires an operator that not only knows what they are doing. But are also willing to be meticulous in their adjustment process. A sloppy job is no better with lasers than with any other form of alignment.
    The alignment people can tell you that customers come in saying that they are very happy with their current alignment, no issues, runs straight, etc. But just want to get it checked out. (Many purveyors will not charge you if your alignment is within spec.) Only to discover that, indeed, their Spyder is out of spec. And, the customer is then quite surprised at how much better the steering is after getting a correct alignment. It's just another 'Didn't know what I didn't know' moment.
    Nov 2012
    North Las Vegas, NV
    Just wondering because our 2016 F3L had good alignment between the front wheels but not to the back wheel. It was crabbing slightly.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Mar 2015
    Surely you jest Mike. Surely you've seen the movie "Airplane!" I'm going skiing today----- surely, you are also??? "And' don't call me Shirley"
    Merry Christmass to you and yours.
    Lew L
    Quote Originally Posted by Lew L View Post
    Lew L
    …. I posted this using the wrong Quote ( but couldn't delete ) …. I've seen the movie a few times and always thought what He said was " Shirley " ????? …. No sking today, but I have gone 16 times to date …… Merry Christmas back at ya ….. Mike
