Results 1 to 11 of 11
    Active Member Frost's Avatar
    May 2019
    TX
    Default 2011 RT Question
    I've had my RT about 5 days now and have been steadily poking at it to figure out what I can and can't mess with without breaking something expensive which led me to notice that my RT doesn't have manual gauges like some of yall's. Here's my question. Those gauge ports are covered up by very nice black disks that have a mess of wires behind them. Has anyone replaced one of those with a 12v cigarette lighter plug? I'm trying to find a place to hook up my GPS and that looks like the most reasonable place.
    Thoughts? Solutions? Pictures?
    Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    I did that with my 2013.
    2013 RT SE5 Pure magnesium metallic
    Leader GPS mount
    Russell Day Long seat
    Seadog power outlet DIY
    Mirror LED lights DIY
    Yokohama S drive
    Federal formoza's
    Daytime running lights DIY
    A name we shall not mention fender tip lights
    F4 Customs windshield
    Sena 20s
    I did it also ...actually installed two ….. if one is used for actual cigarettes - make sure the wires you use are of a heavier gauge and fuse for 15 amps ..... Mike
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Put a USB in mine
    2010 RTSM5
    Default Sure....
    The analog guages did not work as well as the digital ones that appear on the screen. Many removed them as you have to remove both to get the digital ones to appear on the screen. They have been replaced with many different guages and power sources. The wires left are easy to use and active upon ignition one (switched).
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2019
    TX
    What fillers did yall use to cover the holes up? Just cut a hole out of the gauge plug that is there? Is there something Can Am makes that would make it look factory instead of like a retarded monkey with a Dremel got a hold of my bike (as that's exactly what it would look like).
    May 2014
    Benson, NY
    I drilled a hole in the blank that was there.
    Leader GPS mount
    Yokohama S drive
    Federal formoza's
    Sena 20s
    Oct 2014
    Fort Mill, SC
    The disks should be covering standard 52mm holes. There are a variety of items that can go in them; voltmeter, cigarette lighter, USB port, etc.
    Here's an example on Amazon: https://www.amazon.com/HOTSYSTEM-Uni...s&sr=1-1-spell
    2011 RTS
    1998 Honda Valkyrie
    US Navy Veteran
    Member: American Legion
    May 2019
    TX
    I appreciate all of the help. Thank yall so very much. I just need to find a cigarette lighter that will just plug in there and I"m golden.
    Quote Originally Posted by Frost View Post
    Every Auto parts store I ever went in had them … or E-bay, just click on " Free shipping " first ….. Mike
    Active Member jarvis's Avatar
    Jun 2018
    Pahrump NV
    Once the gauges are out, do you just use the existing wiring for any new gauges you want to install?
