Results 1 to 20 of 20
    Very Active Member Flamewinger's Avatar
    Aug 2013
    SF Bay Area
    Default 2018 dash removal?
    I got the new painted dash from Pierre and can’t wait for him to get back from Spyderfest to make a video. So anyone know how to remove the dash? I’ve removed the screws but the display and speakers are attached and not sure how much I can pull on it. Thanks for any ideas.
    Susie - 2018 RT-Limited with 14000 miles so far . . .
    '13 Spyder ST-L with 21k miles
    '04 GL1800 with 91k miles
    '97 GL1500 with 87k miles
    '95 GL1500 with 102k miles
    '89 GL1500 with 96k miles
    '83 GL1100 with 117k miles
    [/COLOR]'81 Honda Silverwing with 36k miles
    '79 Kaw 400LTD with 26k miles
    GWRRA - 39 yrs - Life Member
    AMA - 40 yrs
    Just remember, if common sense is so common, why do few people have it?
    Vermont
    I can't help you with the display and or speakers. But post a picture once you get your painted dashboard installed.
    Deanna
    2014RTS-SE6 Cognac I am a Happy Spyder Owner!
    BRP Semi-Rigid Rear Side Cargo Travel Bags
    BRP Glove Box Organizer
    Ron-rnet Laser Alignment
    TRIC-LED Spyderpockets
    STV Black Carbon Fiber Windshield Blackout
    WRAPMYSPYDER.COM Sceptor Kit Reflective Decals-Orange
    painted Dashboard+ GPS plug-in
    BRP Half Cover
    WRAPMYSPYDER.COM Air Dam Web Decal Black Reflective
    General Altimax RT 43 Rear tire
    BRP Full cover
    TRIC-LEDS Front Fender Marker Lights & Saddlebag Markers Lights
    Deanna
    I painted Dee's dash surround ( post #2 above ) ..... the four bolts that you see hold it on the plastic frame underneath .... the only difficulty is - the gauges have very short wires, so a pair of bent needle nose pliers is a hugh help ...especially for those with large hands ..... Yes, I know the 18's are different, but I think the difference is that the gauges have been re-placed with small speakers....... Mike
    Vermont
    Here is a picture of my painted dashboard that Mike( blueknight911) painted:
    dashboard on spyder14RT 003.jpg this is after the dashboard was removed.
    I know that 2018 dashboards are different.
    I hope the above picture helps.
    Deanna
    BRP Half Cover
    BRP Full cover
    Aug 2013
    SF Bay Area
    Here is a video of me trying to pop it out and I find the display seems to be part of it unlike the earlier RTs where the LCD display is separate.
    AMA - 40 yrs
    Durham,Maine
    Good luck!! Cant tell you about the 18's, but I just took my 12 apart to get to the seat cable out and replaced!! I should have listen to you guys and just put the old fish line cable on it, What a pain i the @#$, But SLOW and easy wins the race!!!!
    I would look at a Fiche ' like at Cheapcycleparts.com .... I'll see if I can find out why !!! .... Mike
    Jul 2010
    Las Vegas, NV
    Pry the left out like the right, then press the tabs in. I’ll do one tomorrow and let you know. Joe
    Joe Meyer
    Aug 2013
    SF Bay Area
    Pulled it a bit further and I got a pic of the massive cable plugged into the back of the display. Thinking that if I pull it the cable will allow me to get in with enough room to pop the plug off. Waiting for service tech to call and cptjam to do one. Pierre sold quite a few of these and we will be wanting to install.
    Thanks cptjam
    AMA - 40 yrs
    Aug 2013
    SF Bay Area
    Got it off!!!
    Talked to Pierre and he explained that he'll be doing a video within a few weeks. In the meantime he explained that once you get the panel lifted out you can get your fingers in either side of the top logo spot and pop the clips that hold the display to the panel in behind and the display will come off. Well . . . I couldnt figure out how to get my tiny fingers in but, looking at the new panel I see the two large clips on the bottom, so I thought what if I pop those? Well they popped off and the display fell away and now I have it out. Must remember the speaker wiring, negative - bottom, positive on top. Hope I can put ti all back together easily.
    The two bottom tabs
    Dash without panel
    Two bottom tabs on display
    AMA - 40 yrs
    Dash removal .. ......... the " terminals " are usually different sizes to fit the speaker connections .... at least on my 2014 RT they were ...... BUT check to make sure First ..... Mike
    Aug 2013
    SF Bay Area
    Not quite put all back together but couldn’t wait to post pics.
    AMA - 40 yrs
    Durham,Maine
    nice tank wrap!!!
    Feb 2013
    Pittsburgh, PA
    Nice��
    Jul 2010
    Las Vegas, NV
    Yes! Just the same as I found. Glad you got it. Helps to have strong hands: some connections are stubborn!
    Joe Meyer
    Vermont
    Nice painted dashboard.
    The added pop of color to the dashboard, see my painted dashboard on my posts/or threads.
    Deanna
    BRP Half Cover
    BRP Full cover
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Default Install was easy
    And Pierre's dash looks sharp....before and after on a 2013 RT
    Aug 2013
    SF Bay Area
    Really stands out! Nice!
    AMA - 40 yrs
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Has anyone seen the 2018 RT Dash Removal video from Pierre yet? Just doing thorough homework before replacing my dash.
    Thanks.
    Got it off!!!
    The two bottom tabs
    Dash without panel
    "BLUE STAR She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    Aug 2013
    SF Bay Area
    Quote Originally Posted by MeudtPG View Post
    Thanks.
    Can't find it so I think he got caught up in rallies and forgot. Basically remove the speakers screen screws and then unplug the speakers. (Use plastic panel tools to pop things apart. They look like small plastic pry bars Harbor Freight) Remove the dash screws and reach up under it and pop the tabs and the LCD falls away and the dash is free. Put the new one in and the LCD should snap into place on its own. Then put everything back the way you took things off.
    AMA - 40 yrs
