Results 1 to 25 of 37
    Dec 2018
    Navarre, FL
    Default 2019 Spyder RT Limited - Firmware Updatee
    Just had my 2018 Spyder RT Limited firmware updated to new version... big change. Can now see miles to empty, mpg avg/instant and same for speed. Radio sounds better, in general the digital system now works as it should.
    Active Member Blake33's Avatar
    Mar 2013
    Lakes Region of NH
    Quote Originally Posted by rpainter View Post
    I'll be having my dealer perform a firmware update soon on my 2018 RT Limited. Can you tell me what version of BRP Connect is now installed on your RT following the update you just had done?
    2018 RT Ltd.
    2018 RT Ltd , Oxford Blue/Chrome
    Nov 2018
    St Pete Beach
    New version is 20.8
    2018 RT , Asphalt Grey
    May 2012
    Southern California (Oceanside)
    Getting the update tomorrow AM....I report the findings.
    May 2012
    Had the 20.8 installed today. As mentioned before everything works the way it supposed to now...instant mpg, avg.mpg, dist. to empty, even Bluetooth connects!
    USA
    All,
    This may be a general Spyder thing, but please check the self canceling feature on your Spyder after the 20.8 update. I think mine has about the longest cycle I've ever seen on a bike, provided you are traveling down the road when you initiate it. At turns it performs much like other bikes, and cancels quickly after the turn. It doesn't seem to cancel if sitting still, which is normal. But if you do a lane change signal they seem to stay on a very long time. Since the turn signal cancel button is so cantankerous, I'd like to shorten the cycle.
    h0gr1der
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by h0gr1der View Post
    All,
    The turn signal self cancel will happen after 30 seconds while moving. Seems like a long time. But has been the same for Spyders since the beginning.
    Active Member brerrabbit's Avatar
    Jan 2015
    Colorado
    Wouldn't be great if BRP would program the cancel feature to use the same function as turning it on? You could turn a blinker on as you do now but to cancel you 'turn it on' again. The logic should be easy to program. When you hit the switch, the computer would check to see if it is already on, if not it would turn it on, if it is already on then it would turn it off.
    =bob=
    2018 RTL--------------------------------2018 RTL
    Champagne Metallic-------------------Oxford Blue
    Lamonster Pegs------------------------Lamonster Pegs
    Motorcycle Dave Gel seat inserts----Motorcycle Dave Gel seat inserts
    Big Bike Parts Backrests--------------Big Bike Parts Backrests
    Magic Mirror mounts------------------Magic Mirror mounts
    Tri-Axis Handlebar---------------------Tri-Axis Handlebar
    KurYakyn Grips-------------------------Foam Grips
    2018 Limited , Champagne Metallic
    Jan 2019
    Blue Mounds Wi
    Just push straight in to cancel turn signal.
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Quote Originally Posted by JeffandLori View Post
    Agreed, however pushing that button straight in isn't as easy as it sounds. I've turned on the opposite signal, then back to the original direction a few times before hitting dead center to cancel. Button could have been designed a little more user friendly(IMHO). Or...….maybe it's just me.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Quote Originally Posted by Valkrocket View Post
    ......….maybe it's just me.
    Yeah.......... Nope! I'm pretty sure it's not just you!
    Mar 2018
    Ontario ,way up north
    No it is not just you as i have done the same .
    2018 RTL , dark blue
    Apr 2015
    Brockville ONT
    No it's just not you.I seen me push the cancel button only to find now flashing on opposite side.The ones following me must think I'm crazy or lost
    2018 RT Anniversary , Brake pedal extended
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    The problem with canceling the turn signal is NOT with the operator but with the switch itself. See https://www.spyderlovers.com/forums/...g-turn-signals. I had the entire left hand module replaced due to other problems but it solved the problem that I was always having with canceling the turn signal. I could only successfully cancel about 30% of the time and now I am successfull nearly 100% of the time.
    So if there is anyone out there (and I know there is) that has this problem do the following:
    1) Ask a friend if you can sit on their bike and test their turn signal to compare it to yours.
    2) Ask a friend to sit on your bike and have them try to cancel the turn signal.
    3) Go to a Spyder dealer and sit on a new Spyder and test the turn signals on it.
    4) If you are still convinced that your Spyder has a problem with canceling the turn signal, talk to the service rep.
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    Member DuckDodgers's Avatar
    GA
    I just visited my dealer today with my 18 RT Limited specifically to get the 20.8 software update, and got the old “ our system shows you are already on the current version for your VIN.” Which of course is 13.20
    Jan 2019
    Blue Mounds Wi
    I just watched a Shaun Smokes video and he said brp has approved the 2019 software for the 2018"s. So dealers should be catching up.
    Sep 2018
    Sneedville, TN
    I had it done on my 2018 RTL today.
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    Quote Originally Posted by DuckDodgers View Post
    Tell your dealer their computer based data system is NOT correct. Tell them to plug in the darned update cable then look at the RT's digital screen to see that the update is available. If they say that isn't so, tell them to call BRP while you are there. If they still say no, tell them you are going to get a lawyer and sue them for refusing to perform available warranty service for your RT. Then when they finally install the update, find a different "my dealer" for the future.
    USA
    Just went to the dealer yesterday with my 2018 RTL. Got the same old "VIN not due for an update". I pressured them with all the arguments, they graciously tried the hookup. It worked, but they said they had trouble getting it to go. I must say I like the new features. Miles to empty, averages working as well. Haven't checked on the Bluetooth stuff yet.
    h0gr1der
    May 2012
    Dealer updated my 2018 last FRiday..free...no questions asked.
    Nov 2018
    Altamonte Springs, Fl
    Not just you.
    Feb 2017
    Aurora Indiana
    No, its not...bought a 2018 off the showroom floor on 5/6...got to reading the forum about firmware and checked my NEW bike and it was 11.0...NOT 13 anything, or 20.8, but 11.0...called the dealer service...he said bring it in...did so (a 50 mile one way trip) and in 15 minutes had it back, updated, and NO cost...love that dealer...that being said, where does it tell Miles to Empty?????
    Mar 2013
    Lakes Region of NH
    Quote Originally Posted by hershey View Post
    Just had my 2018 RTL updated to 20.8 this morning. The "Miles to Empty" indicator appears just to the right of the fuel gauge on the electronic display.
    2018 RT Ltd.
    May 2019
    New Mexico
    Just scheduled my 2018 RTL for its initial 3000mi check in at R&S Powersports in Albuquerque. I mentioned the firmware, and the service manager stated that they always check.
    Mar 2013
    Lakes Region of NH
    Quote Originally Posted by SuperG View Post
    My Spyder dealer, HK Powersports in Hooksett, NH, said the same thing. When I told the service manager some people here had reported that their dealers didn't have the latest software update, he was amazed. He said he checks with BRP for updates every day. Guess I'm lucky to have a good dealership!
    2018 RT Ltd.
