Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Ryker backrest
    Active Member Ryker900's Avatar
    Jan 2019
    Blacklick, Ohio
    Default Ryker backrest
    The Can Am Ryker needs a driver backrest ASAP!
    Nov 2018
    N.E. Ohio
    The back bag is the back rest for me. Fits my body excellent. Maybe you can adjust the handle bars and foot pegs to make it work for you. cueman
    Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I think that is what Ryker900 did. It looks like he has added a larger pad to the front of the trunk. Looks good
    Jan 2019
    Blacklick, Ohio
    Yes I did, but it does not have much padding and it's velcroed on. Would like something with more padding for my old back.
    Jan 2019
    Blacklick, Ohio
    Default New Back rest
    Here's what I did for a back rest. I bought a back rest pad from E-bay for $23 and made my own bracket to attach it to. Works great and cost was cheap! I also changed the top case to a lockable EMGO for $70. A 3/4 helmet will fit in it. Also cheap! Works great!
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Could also fit a motorcycle top case with an integrated passenger backrest, such as this SHAD one:
    I'm presuming it would attach to the Max Mount ok and it could be adjusted to fit behind the rider.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Jan 2009
    austria
    better to ride 2up ..
    Ryker 900 - Outlander fairing - Fox-shock - BajaRon Swaybar - Toyo tire/ back - longer shocks 400mm front - frontgrill + LED - GIVI topace - heatet grips .. & very fast !
    Jan 2019
    Blacklick, Ohio
    Quote Originally Posted by monkeyboymorton View Post
    I thought about that, but decide it was too expensive. I'm retired and living on a fixed income. Need to watch my budget.
    Dec 2018
    East Texas
    Quote Originally Posted by Ryker900 View Post
    I would be interested to see some detailed photographs of how you attached the EMGO case and backrest to the Max Mount. Also which EMGO?
    Dec 2018
    KS
    This lumbar support works wonders for my back.
    Jan 2019
    Blacklick, Ohio
    Quote Originally Posted by Tslepebull View Post
    Here's where to get the Emgo: https://www.denniskirk.com/emgo/trav...prd/493508.sku
    Emgo connection.jpgBackrest connection top.jpgBackrest connection underneath.jpgBackrest connection 3.jpgBackrest connection 1.jpgBackrest conection 2.jpg
    You have to put the Emgo as far back as you can. I used the 2 brackets that came with the Emgo and put them both together to go all the way across the bottom of the max mount and the Emgo mount. The Emgo fits pretty tight against the backrest. The lid of the Emgo opens almost all the way, but not quite. You can get everything in but have to hold the lid open or it will close. Maybe you could raise the Emgo a little some way. I'm fine with the way it is. Hope that the pictures help. I changed my mind and I raised the front of the Emgo a quarter of an inch with a piece of 1/4" thick x 3/4" wide x 9" long aluminum I had on hand. Now the Emgo opens all the way and is not touching the backrest.
    Dec 2018
    East Texas
    perfect, thank you
    Jan 2019
    Blacklick, Ohio
    perfect, thank you
    I changed my mind and I raised the front of the Emgo a quarter of an inch with a piece of 1/4" thick x 3/4" wide x 9" long aluminum I had on hand. Now the Emgo opens all the way and is not touching the backrest. Works great. Hope that helps you.
    Apr 2019
    Massachusetts
    do you have a pic showing that piece you added to raise it up?
    Apr 2019
    Jacksonville
    My solution - a neighbour skilled in needlework stitched a pad for me and it is attached with several strips of Velcro - feels very comfortable and I don't see why it will not work well.
    I am going to attach pictures but they will probably be upside down based on previous experience :-)
    Apr 2019
    Jacksonville
    Apr 2019
    Jacksonville
    Well if you can turn your neck sideways you will see what I did - if you can't you should not be ryding :-)
    May 2019
    New Jersey
    Can you share any information on your back rest, make model, where to purchase
    May 2019
    PA
    being 76 the back rest is top need for me
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    [attach=config]173050[/attach
    Jun 2015
    Spokane, Wa
    Put 2 pads on back to back.
    Greg Kamer
    "If you're not living on the edge, you're taking up too much room"
    Sep 2019
    TX
    Which bag is that vstrommer, and is it on a linq plate?
    Jun 2019
    Florida
    Put a pillow in a back pack and keep on riding...........
    Sep 2019
    Utah
    CTAC,
    Where did you source your lumbar support from?
    Apr 2019
    Jacksonville
    I posted this previously but it works great for me - neighbor sewed a pad encased in waterproof material and it is attached with Velcro - in the Florida heat the Velcro melted a bit so I had her attach a couple of straps that fit inside the top case cover and when pulled tight the pad stays well in place.
    Picture attached but it will probably be upside down as I have not figured out the IT skill needed so far! Backrest2.jpg
