Results 1 to 25 of 33
    Member Bart's Avatar
    Mar 2017
    Kaysville Utah
    Default What are these brackets for?
    I always find it interesting when there are brackets, but nothing in them. Any clue what could go in here? This is under the left cover next to the trunk release.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    1970 Honda Trail CT70 fully restored
    2016 RT , Orbital Blue
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Bart View Post
    I always say find it interesting when there are brackets, but nothing in them. Any clue what could go in here? This is under the left cover next to the trunk.
    Can't really tell from the photo. Not sure what you mean by left cover next to trunk...
    2014 RTL Platinum
    May 2017
    Mesa, Arid-Zone-A
    I agree. Can't tell what area you are looking at and what bracket you are referring to..... ???
    Semper Fi
    Mar 2017
    Kaysville Utah
    If you are facing the trunk, they are to the right. The cable in the picture is the release cable. I can try and take a better picture tomorrow.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Dec 2015
    Oakley Utah
    That's the frunk, not the trunk...
    I don't know the answer, but someone else will now we know you're talking about the front compartment (frunk)
    2014 RTL Platinum
    Mar 2017
    Kaysville Utah
    Dang auto correct. I type frunk, but obviously I've missed it twice now. Sorry.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Sep 2016
    clark county indiana
    if I might throw a guess out , could this be the attachment area for the screen looking thing that is at the lower location of the oil tank/ add area , of the r-t `s ? ( that or this is part of the engine harness , for techs to put engine in and out , or handle it while in service ? )
    Sep 2016
    you have 2 brackets in that area , mmmmmmmmmm wondering if there is something that can be purchased and also an add on that some models might be able to attach here ?
    Sep 2014
    USA
    Thing he is referring to the two tabs sticking upward??
    I was thinking sticking a frickin lazer in that area.
    Nov 2016
    Upstate NY
    My dad's 2013 RT-S has a jump-start port in that location. Wish I had one.
    Mar 2017
    Kaysville Utah
    Now that's cool!
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Mar 2017
    Kaysville Utah
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Mar 2017
    Kaysville Utah
    That's kinda what I was hoping to find out. Interesting about the jump start.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    The other thing is that these units are made for the international market and european models for one have some different requirments. There could be something they use elsewhere that goes there that is not used here... they make just one frame and then build it accordingly like the wiring harnesses having plugs not used....
    Vermont
    Hi Bart, I think I can help, I have a 2014RTS-SE6 and here is a picture of mine: Gerenral Altimax RT 43 ( 175) 008.jpg.
    Is the space you are taking about below the plug-in for the buds?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Joel is correct. The 2013 RT models had positive and negative jump start posts on a bracket there. It was a one year only feature. Maybe BRP engineers determined there wasn't enough call to jump start Spyders to justify the cost of having it there.
    May 2017
    Mesa, Arid-Zone-A
    That makes sense. They moved the battery so it is easier to get to if a jump start in required. No need anymore for the extra terminals. Just did not re-engineer the brackets.....? Jim
    Semper Fi
    Mar 2017
    Kaysville Utah
    It sounds like y'all cleared it for me, thank you!
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Quote Originally Posted by canamjhb View Post
    Not quite. The 2010 - 2012 RTs have the battery in the rear but no jumper posts. The 2013 has the battery in the front and the jumper posts. 2014 on have the battery in the front and no jumper posts. Go figure!!
    The jumper posts on the 2013 were great for connecting accessory power cables!
    They did have jumper posts: under the seat!
    Vermont
    They diud have jumper posts: under the seat!
    2012 spyders had jumper posts under the seat. ( my first spyder was a 2012 rts-se5).
    Also the battery was underneath the seat.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Deanna
    I wondered about that as I didn't think the battery was that accessible, but I didn't see any indication of them on the parts diagram pic of the positive and ground cables. Maybe I just didn't look close enough! Or, I guess I could've looked in the owner's manual! They're shown there but labelled terminals, not posts.
    Mar 2017
    Kaysville Utah
    Pish posh, who looks at the owners manual!? That's like reading installation instructions.....
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    The battery was hidden behind the left saddlebag... The jumper terminals were actually a pretty necessary item on these bikes.
    Remember the fun that you could have; after loosening the screws that were in the terminals? (Try getting a wrench underneath them in order to tighten them back up... )
    Vermont
    I connected the "pig tail" to the battery, to run the battery/maintainer to keep the battery charged ( it had the 998 engine). Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
