Results 1 to 7 of 7
    Aug 2015
    Gastonia, nc
    Default 2009 se5 rear rotor/brake pad replacement
    anyone have step by step instructions on how to replace rotor and brake pads ?
    Nov 2015
    Chardon, OH
    For your 09 GS/RS, this series of videos might help out with a few things for you, although the oil change video will not cover your HCM filter. Rear brake is video #10. And take note, compress the brake cylinder with the C-clamp before you remove the old pads.
    https://www.spyderlovers.com/forums/...pdated-Version
    Unless you have signs of physical damage, or just want to upgrade, it is not necessary to replace the rotor when doing a standard brake job. And of course, to replace your rear rotor, the wheel needs to come off.
    https://www.youtube.com/watch?v=u_QV0WaRNVM
    After that, removing the rotor is self explanatory.
    Doug
    ”Freedom is not a loophole”
    Aug 2015
    Gastonia, nc
    Thank you for these videos.....Very helpful !!
    Mar 2016
    n.c.
    FYI,,,,,
    I am thinkin the brake cylinder is a screw in type! Its is on mine anyway.....A c clamp will damage it. FYI...Mine is 2014.Might be different.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by TONYO View Post
    FYI,,,,,
    2013+ models use the Brembo brake system. Completely different animal. All he needs is a C-Clamp to compress the caliper pistons.
    Mar 2017
    SLC, UT
    Default Rear brake caliper piston not retracting.......
    I've tried to compress piston on rear brake of 2008 GS and it will not retract. I put huge press on it with a C clamp and would not move. What am I not doing correctly?
    Sep 2013
    Houston
    Quote Originally Posted by TMoo View Post
    Did you retract the parking brake? Twist the shaft that the parking brake sector goes on counter clockwise.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
