Results 1 to 6 of 6
    Invalid Emails
    Apr 2017
    athens ohio
    Default Please help! Air bubbles in oil! We are new, it’s been cold, we have had the 2010 RT
    On a trickle charger. It fired right up, but when we checked the oil, noticed air bubbles in the oil...
    Please help! Any help greatly appreciated!
    Northern Kalifornia
    Not to worry. When it warms up bubbles should go away.
    Invalid Emails
    Apr 2017
    athens ohio
    Thank you! We really appreciate your assistance. My Dan bought the 2010 Spyder RT; he wanted me to ride with him, he has neuropathy and there’s a Screaming Eagle (Harley) 1200 in the basement... I adore the Spyder, but we are newbies and appreciate your kindness and assistance!
    Apr 2017
    North Central Florida
    This.
    IF the bubbles are air........and not water.
    But the oil should not be checked when it is "cold" anyway.
    Hope there isn't more to this story.
    Default Little checking.....
    Welcome to the 🎪... being new perhaps the oil check proceedure was not brought up. You need to warm up the engine to operarting temperature then shut her down and check the oil level. Add or remove as needed. Best time to check your oil is coming in from a ryde...
    ​2012 RS sm5
    Aug 2007
    Greeneville, TN
    BRP oil tends to foam more than most. As mentioned, you cannot get an accurate oil level reading with the oil cold. The oil (not the coolant) needs to be at operating temperature. Which means you must ride the machine for at least several miles (especially in cold weather). Of course it goes without saying that you need to be on flat ground when you check (a gas station will have a flat surface at the pumps).
    The best time to check oil level is either when you get fuel after some riding. Or at home at the end of a ride. Let the Spyder idle for 30 seconds or so, shut it off and check the oil level. If the oil is still foamed. Wait another few minutes and try again. Doing it this way you don't need to check the oil at the beginning of a ride (where you can't get an accurate reading anyway).
