Results 1 to 19 of 19
    Jan 2018
    Australia
    Default Using teflon silicone spray ...
    Has anyone else thought to use Teflon / silicone spray on their Spyder's drive belt ?
    I just thought I'd put it out there ! I've been using it on others now the Spyder for the past 6 months and never had any type of problem at all …
    Simply spray it on …. wipe off the excess … let it sit over-night to soak in and there you go … No mess and all too easy !
    Houston
    Why would you do this?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Oct 2014
    Fort Mill, SC
    Good question.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Active Member jlc41's Avatar
    Jul 2018
    New Jersey
    I have heard of belt dressing on V belts but not sure about cogged belts. please explain the reason for doing this.
    Happy Thanksgiving to all.
    Joe
    Lamonster Bright Ryder,
    Lamonster Bright Tail Lighter,
    Lamonster H4 LED Headlights,
    Lamonster LED Fog Lights,
    Lamonster Fog Light Ring Combo,
    Rox Riser
    Lamonster Driver Back Rest,
    Lamonster Frame Mount Drink Holder.
    Lamonster 15" Freedom Shield Wind Shield
    ******* USA flag
    Freecom 2 head sets
    Mirror Wedgies by Squared Away
    Motorcycle Dave's Tachform phone cradle
    Spyderpops Turnsignal LEDs
    Spyder Sisters Shade
    Spyderpops LidLocs
    Spyderpops front fender LEDs by Show Chrome
    Motorcycle Dave's Gel seat insert
    2018 F3L , Blue
    Apr 2017
    North Central Florida
    NOT a good idea.
    Especially not with anything that really "soaks in", which would weaken the belt over time.
    I suspect what is really happening is that the solvents are evaporating and only the dry lubricant is left.
    I see no reason to apply a dry lubricant to a "toothed" belt like that.
    Teflon (PTFE) and silicone are two different things.
    Northern Kalifornia
    You could put a little PB&J on it too but it won't help it any. (just razzing you a little) Do your belt a favor and run it dry and keep it adjusted for the rest of it's life. It will return the favor by giving you a long service life. Ask SpyderAnn how long a belt lasts.
    Jan 2018
    Australia
    Each to their own then ...suit yourselves ...
    Apr 2017
    Quote Originally Posted by fatenhappy View Post
    I ask again:
    What do you think this accomplishes ??
    If you don't really know what it DOES, you should not be doing it.
    And "Some guy told me......" is not a good reason either.
    Jan 2018
    Australia
    I ask again:
    IMO … most anything that reduces heat, drag and friction has got to be a good thing (within reason)
    If in doubt very gingerly try touching your drive belt after a modest run just too see how hot it really does get on a day of mid to average temperatures … you will be amazed …
    I certainly don't come from a back ground of " .. If you don't really know what it DOES, you should not be doing it .." rather than … does this have an improved or adverse effect ?
    I draw comparisons to other heavy laden drive belt situations such as your car's cooling systems, again your car's air conditioner, even a conveyer belt … All produce heat and all get that heat as a result of friction. If not these working belts wouldn't occasionally slip as a direct result of stretching due to stressors and heat and eventually wear out …
    Just because its not be thought about before doesn't mean it shouldn't be … After all, why do they produce drive belt lubricants normally in the form of a heavy white oil base, if I am totally wrong !
    Jan 2018
    Australia
    Apologise up front … I have no clew as to what PB&J is !
    ......I have no clew as to what PB&J is !
    If I recall the 'Americanism' properly, then PB&J = Peanut Butter & Jelly.
    Apr 2017
    A common "drive belt" won't work without some friction on the pulley that it drives.
    That doesn't apply so much to a toothed belt like the Spyder has.
    I have no good idea what "drive belt lubricant" is really supposed to be used for but I suspect some application that is MUCH larger than a motor vehicle.
    I think it is pretty good evidence that NO maker of ANY motor vehicle of any type recommends "lubricating" any of their drive belts.
    SoFlo
    FWIW, there is a Can Am bulletin and maybe more that has you apply a small dab of their multi purpose grease to the pulley teeth to lube the belt.
    Northern Kalifornia
    Default LOL.....Peter got.....
    Just joking with you, but I have heard of what PMK is talking about. A small, and I mean a SMALL, dab of grease on the belt has been reported as not being harmful and possibly a good thing. Just a personal thought, I would guess you'd want to run it dry so as not to be collecting any dirt or dust that could tend to degrade your belt and sprocket over time like micro grains of polishing compound.
    Apr 2017
    That's one good reason NOT to do it.
    Another is: Once you tell people it is OK to put "stuff" on their belts, that will open the flood gates to all KINDS of stuff........that they heard was OK to use.
    Some of it might actually attack the material the belt is made out of and cause it to fail prematurely.
    You can't fix stupid, but if careful you can minimize it.
    Active Member Igofshn's Avatar
    Lemoore, Ca
    On my 2010, I do this about every 1000-2000 miles. It stops the belt from squealing.
    SoFlo
    Jan 2018
    Australia
    I can only guess you are not a happy camper by the insults you keep throwing!
    If you took the time to read my original post I did ask … 'has anyone else thought to try it?' … ' You can't fix stupid, but if careful you can minimize it. ' !
    Mate …. if you can't make other than derogatory comments … DON'T! … Excuse me for thinking or suggesting!
    Try reading some of the Tech Bulletins from Can Am etc … !
    Last edited by Peter Aawen; 05-05-2019 at 04:26 AM. Reason: Removed catty & offensive lang comments.
    Server Admin AnthonyG's Avatar
    mi
    Consider both of you warned, insulting members isn’t tolerated.
    Last edited by Peter Aawen; 05-05-2019 at 04:27 AM. Reason: Updated re orig quoted post
    2018 F3 , Red
