Results 1 to 5 of 5
    Jun 2018
    Pickens, SC
    Post Where did they hide the horn on the 2012 RT?
    I took off all of the left side (as you're sitting on the bike) and can't see a horn. I'm in the process of replacing the horn with a STEBEL IF I can find the stock one. Any help will be greatly appreciated.
    2012 RT SM5 , Silver
    Active Member Air Force PAO's Avatar
    Jul 2011
    Kyle, TX
    Default 2012 Horn
    I admit, I am getting older. If I remember right, it's hiding under the left headlight assembly.
    If I am wrong, I admit it ahead of time.
    John
    Test message.
    2016 Spyder RT
    Nov 2015
    Chardon, OH
    Quote Originally Posted by TexO View Post
    Actually it’s tucked way up under the left front fog light in the frunk module. Get down low behind the left front wheel, looking forward, and you’ll see the snail shell shape of it. Below the fog light and above the air duct. Someone who has done that install can tell you if they have bothered to remove it, or just unplugged it and mounted the new horn someplace else. It looks like the plug is reachable.
    Doug
    ”Freedom is not a loophole”
    Default Don't know
    Not sure on its location but found after installing a Bad Boy airhorn that I have better results installing a high decible low tone spliced to the oem horn. I mounted it to the outside for better sound projection...
    ​2012 RS sm5
    Member stetsr's Avatar
    Mar 2017
    Oviedo Fl
    Default Horn Location
    On my 2013 RT-S was behind the right fog light behind the fender.
