Results 1 to 13 of 13
    Jun 2018
    Bedford VA
    Default Is there any Oil filter crossover list available?
    I just picked up a 2016 F3-T (Ace-1330) for my wife. (I'm still on 2-wheels)
    I've always done my own maintenance and will continue to do so on the Spyder.
    I'm having a bit of a hard time finding a compatible Wix, Fram, Purolator....
    (any filter available at the local parts house)
    Is there a crossover list available? Advance Auto's computer showed a (K&N) filter that was about 1/2 the length of the needed one.
    Nov 2012
    Pueblo Colorado
    Default Just call or email BajaRon and he'll fix you up - filters, HCM filter, Brake Pads
    The Hiflo 556 that Ron (site sponsor) will send you is good for the 1330 Ace and he can provide your brake pads, oil, etc as needed. Just got 4 more so we're good to go for our 15 RT and 16 F3T. Quick service with great value!! DSCN2574.jpg
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Dec 2019
    Land of Lincoln
    K&N556 is at O'Reilley's.
    K&N556 as well as HiFlo HF556 and Outlaw Racing OF556 at Amazon.
    Jun 2022
    N.E. Fl
    Summit Racing...
    2016 F3-T , Blk/Rd
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Amazon has the hi flo 556 on sale
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Any of the above oil filters will work, but ONLY the kits from Lamonster and BajaRon include the 5 o-rings and 2 crush washers that are needed to do the job properly. Also, they are our site sponsors and keep SpyderLovers alive.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Apr 2014
    Claresholm, Alberta
    Quote Originally Posted by Jetfixer View Post
    It's just the shipping to Canada that is a problem, $120 US turns into $227 Canadian with shipping.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by rideaway View Post
    Just purchase the filters. Get your oil in Canada. You'll save a lot doing it that way.
    Maybe I'm the luckiest Spyder owner on the planet .... I've owned three Spyders over 14 years and completed dozens of oil filter changes ..... I've Never re-placed an "O" ring nor washer .... No leaks that couldn't be fixed with an extra tap on the socket handle. In the beginning, I remember reading on the forum lots of folks were changing their Wheel Bearings at every or every-other tire change. I've never done a wheel bearing either ..... JMHO .... Mike
    Nov 2019
    Kansas
    Agreed sir. I do not replace the O rings either. And also no leaks etc.
    2018 F3 Limited
    Aug 2007
    Greeneville, TN
    It is not necessary to change the seal kit with every oil change. Though it is recommended by Can-Am and you will find every other manufacturer. It's just accepted practice and considered cheap insurance. But that doesn't mean you can't skip this step with success.
    But I do highly recommend you have a new seal kit available, should you discover a damaged piece. Otherwise, you're stuck with a 1/2 done service and your bike torn down until you get one.
    Dec 2019
    Land of Lincoln
    I do o-rings every third change. Every change is just a waste of money.
