Results 1 to 5 of 5
    Jun 2017
    Crossville TN
    Default What kind of Cable
    Everyone
    I have an adapter that goes from by battery tender to usb. My question is what kind of cables do you guys use to get up to the dash. I currently have a lifeproof case on my phone but if i keep my charger plugged in the case is compromised. Of course i would not need to keep it plugged in all the time, but just wondering the kind of cables everyone uses. I have switched fuses around so I will be able to use the adapter in the trunk for my tendeer connection. For those of you that have a setup similar do you shrink wrap this connection in the frunk up to dash? Thanks guys
    Dave
    Aug 2013
    SF Bay Area
    Is this what you're talking about?
    If so then this is to power your device when you're not using it. Like if your phone goes dead and you need to get going, you can charge it while traveling. To power the phone on the dash check some of the sponsors on the Spyderlovers home page.
    2021 F3 Ltd , Magna Red
    Jun 2017
    Crossville TN
    Default Exacty
    What I have, just wondering what kind if any charging cables guys use, to get up to the dash Thanks guys
    Dave
    Aug 2013
    SF Bay Area
    This plugs into a Battery Tender Jr battery charger/maintainer and is installed so you can easily connect the charger to the bike's battery. Check spyderpops.com for something to power and mount phone.
    Active Member siny10309's Avatar
    Dec 2015
    Tropical Island ____________of Staten
    2015 F3 SE6
