im looking at this one so I can have a flush look instead of the lock sticking up so much. and ill just put a bolt for the latch to slide under to secure....
https://www.amazon.ca/FJM-Security-8...49762RYE7&th=1
Printable View
Why would you want to use a key every time you want to get into the frunk?
you have to use a key every time you want in the frunk of the spyder. so whats the difference.
Also on the ryker you have the areas on the side where I can just pull up on the frunk cover. no need to add a spring etc....
Amazon lock is exactly what I was looking for. I used the video from slingmods and guesstimated. Works perfectly!
Same here. I made it 1.5 inches from the edge per someones suggestion here, then mounted the angle bracket on the inverse angled section inside the trunk with the edge of it just touching the transition line between the angled and the vertical wall of the trunk. (if that makes sense) O.o
Found this while I was searching for some other installation instructions:
https://instructions.brp.com/content...n&title=CAN-AM ON-ROAD KIT - Glove Box Lock - Ryker MY21 and Up&rel_part_number=219401136
Wonder what locks and unlocks it...
Looks like it unlocks whenever the USB is getting power since it plugs into the harness right there. I'd rather have something like that instead of having yet another key.
is this part available to be purchased from some where? never mind I found it
