Page 12 of 16 FirstFirst ... 28910111213141516 LastLast
Results 276 to 300 of 378
  1. #276
    Clermont, Florida
    Just to set appropriate expectations, I spoke with a competent dealer who said BRP is paying 3.25 hrs for the recall but the real time to process will be between 5 & 6 hrs.. - certainly at the beginning at least.. they may get better with practice
  2. #277
    Quote Originally Posted by WellsboroSpyder View Post
    I sleep well. I keep a great outlook on life and enjoy it until a multimillion dollor company blames the customers for issues they created and then are forced by a gov. Agency to fix. But your out look might change if your 2014 blew up with you on it ..or the wheel falls off going down the road.... I was told you have a sweet imag?
  3. #278
    Jun 2014
    Southern New Jersey
    Why do you think the gas milage will go down? Steve never advised this nor is there any technical reason for it to do so. It may even go UP in warmer months from what we have now.
    BRP has no real control on how the market will perceive these changes and its effect on resale values, nor do they give resale values to dealers for trade ins.
    IF the recall alleviates many of the complaints, the values should stablize somewhere in between 2012 and 2014 values. They already have for the most part. There will ALWAYS bee a big gap between 13 and 14 due to the considerable engineering changes and considerable difference in cost new.
    About the best you can hope for is that trade in values for a 2013 will stabilize just above those for 2012 models. Thats really as it should be. The current market shows its about there already. The big hit on the 2013s has already recovered a great deal.
    According to some of the techs I spoke to part of the fix was to readjust the fuel mix and most likely the fuel milage will decrease. Looking for verification.....I like the Spyder and plan on keeping it for a while, but also looking to the future......
  4. #279
    Since these repairs have just started ... nobody really knows yet; do they?
  5. #280
    Jul 2013
    Piedmont, SD (Black Hills)
    First off I find your crack pipe toon offensive. You don't know me. What I see is a 2013 and a 2014 in a driveway with the comment out with the old in with the woo hoo. I am sorry if your intend of the pix and comment have a different meaning...like I said just an observation.
    Just a reminder that there is an ignore function so if you don"t want to see posts from certain people, the function will block them so you won't see them.
    However, I find the banter back and forth entertaining. No need to be so serious. Welcome to life, no one gets out alive...
  6. #281
    Danbury Connecticut
    Quote Originally Posted by Commander View Post
    From a theoretical standpoint, lower gas mileage is a likely possibility. We know that BRP is remapping the fuel injection.
    Since many people were unhappy with the range of the Spyder, BRP may have leaned out the mixture to help increase mileage, thus adding to the heat issue.
    I would anticipate the remap consists of increasing the fuel rate to cool down the engine, but honestly, I'm just speculating.
    Like so many, I don't have a 2013, but lots of my friends do, so I hope the fix works out well.
    The scoops will, however, make the 2013 model year visually apparent, even from a distance. Who knows, that unique feature might even make the Spyder more valuable in years to come.
    Once again, I'm disheartened that a thread has turned into a flame war. That's too bad. Some people need to get more of a life.
    IBA #47122
    2020 RT Limited Asphalt Grey
  7. #282
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by DrewNJ View Post
    Wow, this thread is way to tense for me!...[emoji38]
    Yeah, and other than maybe just one short post, YOU weren't even in it up 'till now....
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
  8. #283
    May 2013
    Stanton, ca
    I have had my Spyder apart many many times. Yes it is a 2011 not a 2013 But I would not worry about water coming in at the scoop area.
    All of the connectors and harnesses in the sides near the scoops are Delphi water proof connectors. I really do not think this will be an issue.
    Prior to the scoops you DO have open vents there anyway. Rain for sure would have also gotten on there.
    As for gas mileage. I think it might get better on the highway. The are converting the fuel regulator to a dead head type setup. This means it will be richer when idling but may in fact get leaner at highway speed when plenty of air moving will keep the engine and you cool.
    We will see when people start riding. So if you do a lot of stop and go riding, you may see worse gas mileage. If you do a lot of highway, you may see better. Just my opinion based on the changes I see them doing. As far as the BUDs update and what it does, who knows! But for sure that is being done to work with the fuel regulator changes.
    Bob
  9. #284
    Oct 2013
    Pottstown, PA
    I don't know how "sweet" Bob is, but Wyliec said he had a "goody-2-shoes" image that he was trying to shed. Come to think of it, that may be true. I haven't seen "ATGATT" in one of his posts now for at least a good month and a half.
    Sorry Bob. Since everyone else is pickin' on you lately, I thought I might as well join in.
    Rob
    2013 RT Limited
  10. #285
    May 2014
    Benson, NY
    Default Hopeful
    I hope if there is a decrease in MPG it will be offset by fuel that no longer overflows from the evap canister and fumes that are no longer being inhaled by me every time I slow down or stop on a warm day. I like the look of the scoops, I always thought that area was a void that needed to be filled.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  11. #286
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by finless View Post
    Bob
    I suspect that may be right on, Bob. Either way, I don't expect it will effect the overall MPG all that much. As for stop & go speeds, I'll welcome all the cooling fuel that the BRP techs want to throw at me at those times. But they did try that last year in WB 2013-9, and it didn't seem to help all that much. Maybe they weren't aggressive enough with the mixture change at that time, and they have more room to go, but there is only so much cooling you can achieve with mixture. Also, the richer you make it, the more the plugs will fowl, and they are a bear to change.
    ...which reminds me... I'm going to ask the dealer to change the plugs when they do this recall - "whether they need it or not".
    Rob
    2013 RT Limited
  12. #287
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by Bensonoid View Post
    Good thought! I forgot how much fuel is currently boiling off on some of the 2013 RT's. That SHOULD improve mileage, IMO.
    Rob
    2013 RT Limited
  13. #288
    Mar 2012
    NJ
    Quote Originally Posted by robmorg View Post
    I know, right! Trying to play nicer in the sandbox.
    Not saying it's a bad decision, but let's just say surprised to see the deadhead fueling. Typically, people mod the other way and convert dead head, to a return style.
    The reasons are:
    -typically more consistent fuel pressure with a return system. Deadhead systems do go rich at idle.
    -fuel typically runs cooler in a return system. It heats up quicker sitting in the rail.
    -fuel pumps tend to last considerably longer in a return system..
    However, all of this may have needed to be done as a way to richen things up. It's actually kind of a backyard way of richening things up, but I guess I shouldn't say it that way....[emoji16]
    Either way, I just hope it works out for everyone.
  14. #289
  15. #290
    Jun 2013
    Québec, Canada
    1. I understand that the gas milage will decrease with the recall, if true what is the estimated MPG
    Hi Commander,
    We don't expect the gas mileage to be noticeably lower after the recall.
  16. #291
    Jun 2014
    Southern New Jersey
    Thank you Steve
  17. #292
    Mar 2014
    Troy Tn.
    Quote Originally Posted by BRPcare View Post
    Hi Commander,
    This is good news, Thank you for this , Please give me your advice on what will be or is available that will work with this recall to route air flow to me & my passenger. Thank you in advance.
  18. #293
    Jun 2013
    NE South Carolina
    Quote Originally Posted by R&L Limted View Post
    A vent in the windshield or lower Baker wings. I doubt BRP will make anything for a one off 5000 unit roadster.
  19. #294
    Mar 2014
    Troy Tn.
    Quote Originally Posted by Magdave View Post
    Thank you Magdave, does the vent in the windshield work good ? Wonder why BRP Steve has not responded to this , I have asked three times?
  20. #295
    Jul 2013
    Central, NY
    Dealer called last Friday - Parts are in, time to schedule operation.....
  21. #296
    Invalid Emails
    Oct 2013
    CLERMONT FL
    Default parts
    It seems that the dealers are getting the parts fast. Thanks brp...
  22. #297
    Jun 2013
    NE South Carolina
    Reports are the vent in the windshield work well. BRP only answers what they want to. Here are some links they come in 23" or 25" but I seem to remember you can buy just the vent and self install I am still looking for that.
    http://www.spyderlovers.com/forums/s...or-Spyder-RT-S
    http://www.ebay.com/itm/GENUINE-CAN-...25.m3641.l6368
    https://www.f4customs.com/index.php?...product_id=299
    http://www.ebay.com/itm/OEM-Can-Am-S...25.m3641.l6368
    http://www.amazon.com/Spyder-Touring.../dp/B00B0E1TL4
    Here is one Inspector Gadget says works and is self install
    http://www.saber-cycle.com/store/product197.html
  23. #298
    Feb 2014
    Wellsboro, PA
    Default ?
    How many received your official letter from nhtsa about the fix? And are you aware of why not?
  24. #299
    May 2013
    Stanton, ca
  25. #300
    Nov 2013
    pa.
    Default mail
    wellsborospyder we have not received any notification from BRP as yet. Needless to say like everyone else on the site have been following all of the notifications here..
