Digital dash
Have a new 14 rts with just over 300 miles on it. The digital dash is flickering diffrent shades of grey while riding. Have checked the battery connections and the ground strap under the seat. Any ideas would be appriciated. Guess if nothing else ill let it go to the 600 mile check up.
The breakin inspection is at 3,000 miles for a 2014 RT. Check on page 120 of your owners manual.
Dont know if it is trying to go to low light or not. it was in bright sun light both times it happened. Yes i know that the break in is 3000 miles that is why i said 600 mile check up. it recommends in the manual and the dealer does to to have everything checked at 600 miles. And i hate to say it but just about everything you ever buy vehicle wise always say to check it after install and used no matter how long it is supposed to last.
On what page of the manual does it say that? I can't find it.
There is a ground for the cluster. Only problem is, you have to take the whole front end off. I suspect your problem is in the cluster itself. Either a loose connection on one of the boards or in the connector to the cluster.
Considering..!!
your first service is at 3,000 miles I would take it in and have them check it out. If it is a connection problem letting it go may cause you other problems you really don't want. Call them and set up an appointment this is not the first I have heard of this and it may be an easy fix...
My dash on my 2014 has faded to black from the top down in direct sunlight on a hot Vegas day. As soon as I got back to speed it came back. I was stuck in a traffic jam for an hour with the sun shining directly on the dash and the air temp was upwards of 105.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Digital black out
Pull down that dumb plastic little safety check card that's installed in the dash and it will shade your digital dash and keep it from going black out. That little card is handy for something after all. I use it when I have to park in the direct sun light.
