Results 1 to 25 of 25
Thread: Laser Alignment
    Jun 2012
    Hampton, Virginia
    Default Laser Alignment
    I owned a 2012 Spyder RT-L for 22 months (26,636 miles at trade in) and am currently the owner of a 2014 Spyder RT-L (over 9300 miles since 20 Mar 14). Both Spyders had a slight drift to the right even on relatively flat super slabs. I even rode in the left lane of a two lane road (no oncoming traffic) and both Spyders tracked straight in the left lane but drifted to the right in the right lane. I had both Spyders laser aligned, twice each. The drift to the right persisted on the 12 model and persists to this day on the 14 model. The drift is so slight that just the weight of my hand on the left grip keeps the Spyder on track with my right hand off the bars. However, a somewhat constant push (more like pressure) on the right grip is required to keep the Spyder on track with my left hand off the bars. I keep the front wheel tire pressure the same in both tires using JT's equal pressure thingy. Also have not noticed any uneven tire wear.
    Now having posted the above, let me say that I noticed a marked improvement in the steering after the laser alignments (especially the second ones that were done by independent ROLO techs while the first ones were done at dealers using the ROLO system). I do not regret getting the laser alignments and truly believe it is a good investment. I plan on talking with Mike (ROLO laser alignment inventor) at SpyderQuest about my "drift".
    Bottom line...if you have the opportunity to get your Spyder laser aligned by an independent ROLO dealer, do it! You have nothing to lose...most if not all do not charge if you Spyder needs no adjustment, and better handling to gain.
    Nov 2012
    North Las Vegas, NV
    I second that, even if you think your spyder handles fine.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member spyderbirds's Avatar
    Apr 2011
    Bowling Green, FL
    Timely Post, Doing alignments this afternoon in Tampa area...
    2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
    2014 XLR Viper 305V14 Toyhauler (Home)
    2015 Ram 3500HD Crew Cab
    Former Spyders
    2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
    2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
    Feb 2013
    UK
    Cool
    If you get slight drift on a Spyder which is correctly aligned it's down to the camber of the road.
    Mar 2013
    Quote Originally Posted by OJ UK View Post
    I have noticed this. Some roads more so than others. There have been roads that I can take my hands off the bars and the Spyder tracks straight so that tells me it's the road and not the Spyder.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Alignment and sway bar are must haves!
    Apr 2012
    Florida
    Just had the sway bar, links and alignment done yesterday. Ron(rnet), Netzley's Tire and Auto, on this board did a great job. Alignment was way off. Next bike after me, another 14 RT was even more off. Tom
    2020 Petrol Blue Metallic RTL
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default Had the drift to right also
    Even after laser alignment...discovered that my right tire was slightly less inflated than left. Used my JT equalizer pressure thingy and no more drift....
    Jun 2012
    Hampton, Virginia
    Post
    Quote Originally Posted by murphybrown View Post
    MB, after seeing your original post about how your "drift" was caused by unequal front tire pressures, I bought JT's "equalizer pressure thingy" but I still have the slight drift to the right. Guess my issue is not caused by unequal tire pressure...
    May 2008
    Saratoga Springs, NY
    Are you getting the steering angle and torque sensors reset at the same time as the alignment? Without resetting the sensors (with BUDS) after doing the alignment you can have the effects you guys are describing. Personal experience speaking here.
    Jun 2014
    People's Republic of NY
    Default Where oh where
    I'm in Putnam county ny, anybody know where I can get laser align done.
    thanks
    Jun 2012
    Hampton, Virginia
    Post
    Quote Originally Posted by mike3069 View Post
    Yes, steering sensor was reset to zero via BUDS after each alignment.
    Jun 2012
    Hampton, Virginia
    Post
    Quote Originally Posted by vided View Post
    thanks
    Check out this link http://www.spydercomfort.com/dealers.htm for both dealers and independents doing the ROLO laser alignment in your area.
    thanks
    How far are you from Accord, NY?
    Give Ron a call!
    Quote Originally Posted by Tango View Post
    How much was MikeGuyver's off???
    Jun 2014
    Quote Originally Posted by SpyRyd View Post
    Thanks for the info,
    looks like there's a place not far from the dealer I brought the spyder from
    Default Curious..!!
    when doing alignments off the rear wheel,which is not a fixed part, are they checking the alignment of the rear wheel. Belt adjustments can change rear wheel alignment. How would this affect the front end alignment in relation to the rear wheel. If rear wheel is off and front is aligned to it could this give you that slight drift..?? just asking...
    Jun 2014
    Give Ron a call!
    That's the one. He's about 65 miles from me.He's a few miles from arctic adventures, the dealer
    i got the st from
    Invalid Emails
    Mar 2013
    queensland australia
    I made my own wheel aligner about 2. 5years ago long before lasers .it is a peace of tube with adjustable bolts that measures the distance between the rims and you use feeler gauges to get your 2 mill tow in and then I set the steering not to Center but 2degrees to the right because we drive on the left side of the road hear . I have found that buy offsetting the steering my shoulder does not ache on long trips. It mite be old school but it does work well for me bike handles well and front tyre were is down to 1 mil in 30,000 k.
    Aug 2013
    Northern California
    Default Pssssssssst!
    Quote Originally Posted by spydajohn View Post
    Lasers have been around more than 2 1/2 years
    Aug 2013
    That is awesome.
    Lasers just help at making what you did a touch quicker IMO...although some here think they are the only ones capable of doing so.
    Harper, Texas
    You get drift when the front wheels are not aligned to the rear wheel. Suppose that the front wheels are like (\ \) in relation to the rear wheel. The bike is going to drift to the left.
    Jun 2010
    Las Vegas
    We do that.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2013
    Stanton, ca
    We do that.
    So that is one question I was wondering about.
    If I get aligned and 2000 miles later need to adjust my belt "tracking", the rear axel has now changed in relation to the fronts so my assumtion is the alignment is now off again?
    Bob
    Harper, Texas
    Quote Originally Posted by finless View Post
    Bob
    Anything you do that changes how the rear wheel sits in the swingarm will change the alignment.
