Results 1 to 25 of 25
    Very Active Member sabunim5's Avatar
    Jan 2008
    Pensacola Beach, FL
    Default My Rear Fender Brackets are Cracking --- AGAIN
    I had my rear fender brackets replaced under warranty some time ago. I quit keeping an eye on them as the replacements seemed like they were a reinforced version of the originals and were unlikely to crack again. I was checking the rear tire pressure a few days ago when I noticed that they were both cracked about a third of the way through. I am at about 34k miles and can't seem to locate the shop order for when they were replaced before without a more thorough search than I have time for right now. Just wanted you all to know so that you can check yours too. Don't be complacent like I was because you have the 2nd generation (if there really is such a thing) rear fenders. I hope you don't find what I did.
    Happy owner of Silver PE #1232
    All The Gear All The Time - ATGATT
    Gulf Coast SpyderRyders
    Default NEW BRACKETS
    Quote Originally Posted by sabunim5 View Post
    Even if you can't find the work order, the place that did them will have a record of it....just saying....Mike
    Jun 2011
    Aransas Pass Texas
    Default mine are currently cracked
    took it to my dealer and they are trying to get BRP to cover them since its a case of poor design and metal fatigue
    they are saying there is not an issue in RS bikes
    please if you can find where yours were replaced i might need data for mine
    if there are others that have had theirs done we need to all speak up to BRP and get this rectified
    Active Member bobnaquin's Avatar
    Nov 2011
    St George UTah
    I have had two RS's and no broken fender brackets. I wonder why. The present RS has a habit of vibrating the license plate frame to shreds (2) and I have fixed that by just not using one.
    Good luck with BRP on getting them to rectify what seems to be a fairly common problem.
    May 2008
    Clearwater, FL
    Quote Originally Posted by Tx web rider View Post
    Replaced 5 pairs of rear fender brackets in 150K miles.
    BRP explanation: "It is not poor design or metal fatigue, is BC of the Turbo..."
    Mar 2011
    Charleston West Virginia
    Default BRP and warranty Issues
    Quote Originally Posted by bobnaquin View Post
    If you listen to BRP they have no problems everything that goes wrong with a machine it is the operator which is so far from from the truth I like my 2010
    RS very well but when you have a warranty Issue they being BRP should step up to the plate if they plan on growing the Line of machines
    Tony Holbrook
    Springfield, MO
    Quote Originally Posted by docdoru View Post
    There is a design issue for sure as I've welded up both sides of mine once but in your case I would say it is your Elka suspension that is way too tight and not taking up the bumps like it should. After riding behind you it looks like you have a hardtail.
    May 2008
    Clearwater, FL
    Quote Originally Posted by Lamonster View Post
    I should "dump" the Elka's and go with Fox...
    Motorbike Professor
    Mar 2008
    Allegan, MI
    More damping, less spring tension. JMHO
    Jun 2011
    Milton, FL
    It had to be in July/Aug of 2011, Steve, since yours broke around the same time that ours did. We were in DC when ours gave us problems. We don't ride with ours on anymore since I was worried about the second one breaking like the first one did.
    Default BROKEN BRACKETS
    So it's not because you are not using GENUINE BRP air in your tires......... Mike.
    Jan 2008
    Pensacola Beach, FL
    Default It is/was an issue with GS/RS bikes
    At the time mine failed the first time there were a lot of posts about rear fender bracket failure. It was mostly in higher mileage machines. BRP had no problems with the warranty claim. They supposedly redesigned, and I will have to say that I thought my replacement brackets were reinforced/thicker in the problem area. That is why I quit checking mine at subsequent service intervals. I am currently waiting for my dealership to let me know the status on my warranty claim. Good luck with yours.
    May 2012
    sussex, nj and tug hill, ny (west turin)
    mike,
    he just isn't using that fresh vermont air!
    Feb 2008
    South Jordan, UT (Salt Lake)
    I have stock rear suspension. I went through two sets of fender braces in 30,000 miles. I gave up and now I go fender-less.
    2008 GS , ISCI Quantum Blue
    Registered Users twain's Avatar
    May 2011
    Rosharon Texas
    My fender is fine but my license plate cracked on way back from Vandiver. Tag office said never seen one crack in half before.
    Invalid Emails
    Dec 2007
    winnipeg mb
    Lower the tire pressure and you won't have problems with the brackets.
    Feb 2008
    Quote Originally Posted by twain View Post
    I lost my first two, they just fell off. My third one is cracked. It's now mounted off my GIVI trunk.
    Feb 2008
    Quote Originally Posted by spyryder View Post
    I highly doubt that it would make any difference. It would do a great job of lowering your fuel economy.
    Aug 2009
    Hoffman Estates, IL
    Just think how much that would cost when my wife rear ends me again (4 times so far, )
    Mine never cracks and falls off... 'cuz she runs into me and trashes it and I get a new one every 6 months or so.
    Now... fenderless... I might go for that.
    Jul 2011
    Mount Airy,Ga.
    Default Pics of cracks in the fenders
    Does anyone have a picture of the cracked fenders? I like to check mine. Thanks.
    Mike
    Jan 2008
    Pensacola Beach, FL
    Quote Originally Posted by MikeinGA View Post
    Mike
    I think ERAGS took a picture of his when they were cracked. I don't have any. The cracks are at the rear (fender) end of the bracket. Both times, mine started cracking at the bottom side of the bracket and worked their way up.
    Invalid Emails
    May 2009
    Clearwater Florida and Frankin NC
    Just a piss-poor design. Too much weight hanging off the end of the brackets, compounded by any aftermarket plate frames. ( even the ones BRP sells)
    May 2010
    Milton, FL
    Default Broken Rear Fender is Not covered by Best
    Broken Rear Fender is NOT covered by BEST protection plan
    Got a call today letting us know that our 2008 GS rear fender is not covered under the BEST protection. The Spyder is still covered, but not the rear fender. On the web page for BEST Protection in small print:
    "Note: accessories, normal wear and maintenance items such as tires, batteries, bulbs, filters and lubricants are not covered,"but it doesn't say anything about body parts.
    So it looks like the rear fender is an accessory (because it doesn't fit in with items like tires, batteries, bulbs, filters and lubricants), or is it that they consider the fender falling apart "normal wear?"
    We are going to have to think about this for awhile. I'm not sure if I need that accessory because the 2 rear fender supports are $50.00 each plus I will need all new bolts and nuts, because of the normal wear and tear on them from the rear tire throwing things up against them.
    I'm making this piece of Diamond Plate aluminum for mounting the license plate and license plate light.
    May 2008
    Clearwater, FL
    Quote Originally Posted by Erags View Post
    Contact NHTSA 1-888-327-4236: poor design body parts are to be covered by extended warranty.
    Apr 2009
    Mission BC Canada
    I hung my rear fender from above and have not had problems with it since. Fenders riding on the trailing arm get shaken to pieces, I think.
