Results 1 to 25 of 31
    Dec 2010
    Telford, UK
    Question Help: Can you identify these brackets?
    I've found a pair of brackets under the front fascia, left hand side.
    See photo. I've color-washed the brackets yellow to make them more obvious.
    Together they obviously hold something about 4.5" wide.
    Anybody know what the missing item is?
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    I don't see an attached photo...
    Dec 2010
    Telford, UK
    Quote Originally Posted by MarkLawson View Post
    I know. I forgot to add it to my post.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    There is nothing attached to these on the stock Spyder RT. Obviously the engineers had something in mind, but until someone ends up with an option or accessory installed there, we will never know.
    So stay tuned for coming attractions!
    Banged Up Member
    Dec 2009
    Sanford, Florida
    Inquiring minds need to know.
    Chris
    Good find! It will be interesting to see what they are (were) up to.
    Hey! Maybe that's where the larger gas tank/ sixth gear/ better stereo with a CD & DVD player/ and cupholder will mount!
    Dec 2010
    Telford, UK
    Thanks Scotty. I was looking to fit a Stebel Nautilus air horn. According to the fitting instructions the Nautilus should be mounted upright in both directions. I think the space between or near to the brackets is a good option. I'll try it, now that I know the space is good to go!
    What a great idea!
    Dec 2010
    Telford, UK
    What a great idea!
    That's all it is so far, an idea...
    But I'll appreciate some applause if it works out. And also maybe a fanfare or two, a Dixie band, a dozen cheer leaders and a crate of beer. Then I'll wake up and discover I'm down a rabbit hole with the Wicked Queen... Don't you just hate sad endings?
    If it works you're sure to earn at least a little bit of undying grattitude...
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    Quote Originally Posted by GeoffCee View Post
    I do know, but I have been sworn to secrecy!
    heck I'll probably get in trouble just for answering this much. Let's just say close the hatch and step away from the bike ! OK?
    sorry
    Invalid Emails
    Redding, Calif.
    Do those brackets hold either the CB / Communication module or the XM radio module ?
    Dec 2010
    Telford, UK
    Speaking of grattittude, dude. Undying you say? What about the genius who invented the incandescent light bulb, you'd think gratitude would be undying in his case, yes? For being the first to bring light into the dark corners of life at the flick of a switch? Well, it turns out now that the creep was responsible indirectly for global warming and here in Europe we are all converting to mercury-filled light bulbs to save the planet. Do they realise or care how poisonous mercury is? Undying gratitude means gratitude for ever. For all time to come. Not gratitude only until your reputation is shredded on a whim by a bunch of scare-mongering egg-heads.
    Tomorrow I will find a way to install my Nautilus. It contains no mercury.
    Jun 2011
    Harrisburg, PA
    Default Use for mounting bracket...
    SOMEONE needs to come out with either a machine gun or rocket launcher to fit there, for those who pull out in front of you!
    Dec 2010
    Telford, UK
    Quote Originally Posted by FrankPa View Post
    I've found a toot of my horn sufficient retribution but I'm riding in the Old Country, not the Wild West.
    Yes... But is it CAFFEINE free too?
    I kind of thought that a "Frunk Monkey" with a shotgun would suffice...
    Dec 2010
    Telford, UK
    It works! See my post with photos in the DIY Step-by-Step forum for fitting a Nautilus on the RT. I'm really pleased with this.
    Very Active Member MMcc's Avatar
    Aug 2010
    Annandale, MN
    They look like the brackets that hold the fuse box on my 2008 GS.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Default Brackets for additional Fuse Box
    Ref those Brackets - I have found a use for them
    I have fitted an additional Fuse Box - FZ-1 - .See http://www.fuzeblocks.com/
    I have connected a Power socket, Running Lights, Clock and Voltmeter off it - all fused
    The problem was where to locate it ?
    It had to be easy access to allow for any changes (Adding more accessories) - Replacing Fuses if needed and
    also the runnning of wires etc
    A Location where it would not get too hot _ Difficult on the Spyder RT - S
    and would not be prone to failure due to the weather
    Having looked at the those brackets and their location and with the size of the FZ -1 Fusebox - this was my chosen location
    I found the location ideal for running wiires to either side as the Fusebox is on the RHS (Looking from the front)
    any wires needed for the LHS run under the lights behind the Front trunk (Plenty of room)
    I fixed the Fusebox with Heavy duty velcro and Zip ties which hold it very secure - it has extra wire which allows me to pull it out when I need to
    Although the fusebox is under the RHS Service cover I have added extra sleeving to protect the wires and made a rubber sheet which covers over the top of the FZ1 - Fusebox stopping any Water/Dirt etc
    I have been in 2 storms and not had any problems
    I have posted some photos as this may help others
    Eddie Sheppard
    Reading Uk
    Spyder – RT-S SES (AUTO 2010 Model)
    List of Mods :-
    Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
    Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
    displayed in Cluster Display
    LED Bulbs Reversing Lights,Front position lights
    HMT - Brake Light
    LED – Running lights
    LED - Mud Flap lights
    Rear extended Mud Flap
    Sport Tall Wide Clear Windshield
    Utopia Backrest
    S/S Grills both sides matching
    Bottom Panel S/S Protection
    S/S stronger Funk Lid brackets
    S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
    Rubber Tank protector on glove box
    Grip Puppies
    Power Socket in Switch Cluster and at Rear passenger Handrail
    Rear Speaker Switch for passenger On/OFF
    Upgraded Front Marine Speakers
    Bluetooth On board Radio to Sena SMH10 Headsets
    Dec 2010
    Telford, UK
    Quote Originally Posted by eddieshep999 View Post
    Ref those Brackets - I have found a use for them.
    And a good use of the space, too, there's no doubt about that.
    I've just visited Nippy Norman's and had a look at the specs for the FZ-1. A bit expensive I thought, but plenty of features --- if I bought one I'd be looking for additional electrical stuff to add to the RT as a way of justifying its cost!
    Smatter of fact I'm close to needing a fusebox. As well as the Nautilus, I have connected up a Zumo 550, an Autocom and a 10 amp socket for my wife's heated jacket, all powered by in-line fuses. Happily, I am about done with electrical extras (until the next "must-have" item comes along)! When that happens I'll probably get a box and rewire everything to it. Good fun and educational, too!
    Thanks!
    Feb 2011
    Hamburg, New York
    Default Somebody wanted machine guns ?
