Results 1 to 25 of 29
    Jul 2011
    Lawrencevile,Georgia
    Default 2011 spyder min. octane 87. Just wondering what others are using
    The manual states 87% octane min. Has anyone noticed any perforamce using 93% octane. Only on my 2nd tank of gas we just bought the touring RS on July 4th weekend.
    Invalid Emails
    Sep 2007
    Wayne, NJ
    Quote Originally Posted by Boomer2 View Post
    I started using anything above 87% just to get away from that ethanol crap leaving deposits in the future. As far as performance, I've seen no difference.
    Aug 2010
    Riverside, California
    I use 93 because it is only 20 cents a gallon more and that is only a dollar a tank fill-up more ($20 vs $21 for a fill-up)
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    The only time I notice a big reduction in performance is when I use any octane level gas with Ethanol. I will loose around 4 MPG with Ethanol. I don't notice a big difference between 89 and 93 octane non-Ethanol but since it typically costs less than a dollar a fillup I go for the good stuff if they have it.
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
    May 2008
    Tiffin, Iowa
    08' GS 91 Octane I think a little better mileage
    Feb 2009
    Ceresco, Michigan
    I know previous years said 87 min -- but I thought the 2011 manual stated 91 min...... this was talked about awhile ago. No changes to the engine-- hmmmmmm
    May 2011
    Ontario, Canada
    My 2010 RT manual states recommended 91, but 87 and up can be used.
    Shell 91 octane is the only gas in my area that has not been corn feed, and I do notice a mileage decrease with corn feed fuel.
    Lots of opinions on this one. I have mostly put 90 octane (highest available here) into my Spyders.
    When gas got to $4.00 I started using 87 octane. After a couple tanks--I felt my RTS was a little sluggish and noted the miles per gallon was down a couple from usual.
    Same effect with a couple tanks of 89 octane.
    Im back to 90 octane and feel the bike performs better as well as gets better mileage.
    My 900 Vulcan LTD--runs just great on 87 octane.
    Just my experience.
    May 2011
    Hawaii
    I just finished a 5,000 mile trip. Someone on this forum mentioned using regular, the gas is fresher. The higher grades are older.
    I used different grades. I can say without a doubt regular is the preferred choice. Several times when I used the higher grades the roadster responded negatively. One fill up my roadster and my rider companion thought we were not making it to the next stop. My Spyder and his backfired idled really rough.
    Lamonster mentioned octain additive. I think this is the best way to go. i was stunned at the performance difference.
    MOgang Member GloryRyders's Avatar
    Mar 2010
    St. Louis Mo.
    I started using 93 octane ($0.30 higher) after the first three months of ownership and have found better performance, more responsive and better gas milage.............other than that, no difference.
    Apr 2011
    Vermont USA
    I use 93 Octane when available, some stations only carry 91.
    Sep 2008
    Carmel, In
    Man the oil companies love you guys using premium. cha ching!
    If the higher-grade fuel yields better fuel economy then the tradeoff might be worhwhile on that basis alone. If you also notice that your bike runs smoother and cooler... then it's all good!
    BRP didn't suggest using 91 octane in the RTs for their own benefit. In fact an argument could be made that this suggestion may have even HURT their sales...
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Trickie Dick View Post
    I use 91/93 all the time, I get that money back Quarterly.
    Boerne, TX
    I use the lowest priced gas at the pump. I have two large stations (companies) very close to me and one has 10% ethanol and one "regular". I fill at one or the other and can tell no difference in my performance. I have used the lowest priced gas for 50+ years in my scoots and never had a problem. I have saved $21,247.87 by using regular during this time.
    I put 1/2 can of Seafoam in my tank about every four fillups or so. Works for me.
    I used to worry about not using premium gas, but I went to my psychiarists and now it does not bother me.
    ...Now I've been "forced" (You'd be surprised at how a Mad Wife can ruin your day...) to try 87 octane in several tankfuls this Spring and early Summer. I noticed that my fuel mileage dropped from 34 to 35mpg, down to 31 to 32mpg. A solid 10% drop in fuel economy!
    The spyder also didn't have a clean a low-end "pull" and it required some downshifting in places where it hadn't been an issue during previous rides...
    So I'm figuring that the 93 octane that i'm stuffing down it's gullet isn't the worst thing that I could be doing to my Spyder...
    Thanks --as an accountant, I just love statistics and numbers.
    Invalid Emails
    Mar 2009
    ontario canada
    i use premium,. dont care about mileage, i bought the spyder to ride and ride and ride and ride....................
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Quote Originally Posted by RoadHammer View Post
    are you rich rich rich??
    Invalid Emails
    Dec 2010
    Augusta Georgia
    There are three issues here and we must separate them out to make some sense out of the octane issue. 1 RS Spyders have different loads on them than RT Spyders. 2 high octane gas has less available power than low octane gas as the octane additive is to prevent pre ignition caused by placing the engine under higher loads see number one. 3 ethanol is not as good as gasoline for delivering power to an engine and can also adsorb water which last time I checked does not burn.
    So if you have an RT with the heavier weight and therefore greater loads on the engine the 91 to 93 gas may help avoid pre ignition and may contain less ethanol
    If you have an RS the 87 stuff for most folks seems to be ok but I would still seek out non ethanol gas if possible it will run smoother.
    Miles per gallon is Ryder dependent I don't know how you can really do a case by case comparison ie heavy wrist versus light and 150# single Ryder versus two up seniors with lots of baggage.
    Jun 2008
    Vail, AZ
    Hey look, a can of worms.
    2009 GS SM5 , Red/Black
    Jun 2011
    Grayslake
    ya what octane is a can of worms ALL the time . I prefer to use premium in mine just force of habit from sport bikes. I know higher octane gas wont really improve gas mileage etc typicall unless your motor is worked over etc. But if i recall higher octane will help with a cleaner detonation and a few other misc stuff, but if the min rating is 87 and you want to run 87 feel free it definately wont hurt it . if you want to run the expensive stuff freel free its power of choice ! that is until you deck your head, put high compression pistons , diff cam and mess with your fuel mixtures etc then you need high price gas like 100 + octane or C16 race fuel . but for my answer since they can run on 87 octane put in what your little heart or wallet wants
    Something i was told when i started riding sport bikes years ago . your right hand/foot can determine your fuel consumption to " lead foot" or lead wrist LOL
    Invalid Emails
    Mar 2009
    ontario canada
    Quote Originally Posted by Mexican View Post
    well maybe..... but i feel really really rich rich rich when i bomb around on the spyder !
    Alignment Specialist
    Aug 2008
    MD
    Facts show there is no difference in performance...there have been tons of threads on this topic over the last 3 years that I've been on the board...nothing has ever shown a gain in performance...
