Results 26 to 50 of 56
  1. #26
    Quote Originally Posted by trong View Post
    The only thing to watch for is the API Donut with label saying "RESOURCE CONSERVING", most oils with viscosity of xW30 or less will have that since they have friction modifier(s) added. Oils with xW40 and higher don't have friction modifier(s) and they are safe for use in engines with wet clutch.
    Also the Rotella T6 5W40 is excellent engine oil but it is not certified to use in gasoline engines per API Service classification, reading the label, it is designed for Diesel Engines with certain additives. I'm sure Rotella T6 oil won't harm Spyder engines - vTwin or Triple - on long run but why take a risk just to save a few dollars on your $20K plus toy.
    Just my 2cents.
    Cheers!
    Where did you see that T-6 is NOT CERTIFIED for use in gasoline engines ???????? ..... Thanks Mike
  2. #27
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    This should be The End of any 710 discussion.
    Cheers!
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
  3. #28
    Check this document out
    https://rotella.shell.com/en_us/prod...sae-15w-40.pdf
    Rotella T6 is CK-4 certified but nowhere in the document mentions that is is SN or SM certified for gasoline engine. Not even JASO MA certified. It just happens that diesel engines require higher viscosity oil and this T6 is one of the best out there for diesel engines.
    Motorcycle owners see this full synthetic T6 in the viscosity that matches the requirement of motorcycle engines with wet clutch, at very good price compare to motorcycle oil, so most of them switched to this T6. Many motorcycle owners swear by this oil. And I somewhat agree. I used that T6 once in my '13 RTL until last spring when I changed the engine oil I switched back to Mobil1 5W40 European car formula. Engines in the Spyders were designed and manufactured in Europe by Rotax so using Euro formula oil seems to be a logical choice.
    No Offend to anybody here, just my own experience and opinion.
    Cheers!
    But doesn't the yellow 'Specifications & Approvals' block on page 2 of that linked document ^^ include both JASO and MA/MA2 in T6's listed approvals??
    Besides, most diesel oils are not only 'suitable' for gasoline engines, but pretty much meet & exceed all the relevant gasoline lubricant standards, with the addition of added cleaning/detergent agents & anti-foaming properties.... So generally, if the viscosity range is appropriate, a diesel oil is not only 'suitable' for a gasoline engine, it's even better than 'just suitable'!
    But it is your Spyder, you can run what you like - me, I usually run a full synthetic 10W40 Penrite oil that's specifically suited for 4 stroke wet clutch motorcycle engines (with JASO & MA cert's ) AND it's ALSO listed as being "suitable for most petrol, diesel, or racing internal combustion engines" that require oil in the same viscosity range besides!
  4. #29
    Cheers!
    Well YOU really need to read the Label that you just posted a LINK to : The yellow spec box says JASO DH-2 , MA / MA-2 .... if a Spyder is used in a mostly VERY warm climate I would use the 15w-40 weight but most here only use the 5W or 10W - 40 weight. I suggest you change your posts, it's mis-information ...... thanks ... Mike
  5. #30
    Mar 2020
    Richmond
    Anyone using Shell Rotella T6 Full Synthetic 15w-40 in their Spyder RT? I see that it is rated for motorcycle clutches.
    Last edited by Peter Aawen; 05-15-2024 at 06:13 PM. Reason: Moved Post title after thread merge - they mess with Searching! ;-)
  6. #31
    Mar 2017
    Salisbury,NC
    A lot of us Spyder riders do. But T6 is 5W-40, unless that's a typo, or T6 comes in 5W and 15W, being not aware of 15W of T6. I also use it in my Honda NT700V. Cheaper alternative is to buy it in 5-gallon containers rather than quart size.
  7. #32
    Mar 2021
    Maryland
    I get the T-6 10w-40 in the 2.5 gal at walmart and filters from lamonster.
    Only issue I have seen is with colder weather (below 30 deg. f) if I don't let the spyder warm up first it will want to stall from taking off from a stop other than that no other issues.
    2020 F3 SE6
    2020 F3 , Black
  8. #33
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    I will be using T6 on my upcoming oil change. Glad I stocked up before shrink-flation rolled around.
    Joe
    2023 F3
  9. #34
    Mar 2021
    Maryland
    Damn didn't realize I was replying to a 3 year old thread. Sorry.
    2020 F3 SE6
    2020 F3 , Black
  10. #35
    Durham,Maine
    We have all done it at least once!!!
    2012 RTL , Pearl
  11. #36
    Mar 2021
    Maryland
    2020 F3 SE6
    2020 F3 , Black
  12. #37
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by CloverHillCrawler View Post
    you probably replied to the new post, then Peter merged them!!!! starting at #30
  13. #38
    Sebring, FL
    Rotella T6 5/40, I've not been able to find 10/40 or I would use it. I've often wondered if Rotella T5 blend 5/40 would be OK but haven't tried it. If I'm gonna get up under there and go through the motions, might as well go for the best. I've also thought about T6 15/40 since I live in FL and it gets hot. I'd like to quite that annoying 'clunk', but I don't think that's gonna happen. I know, as Peter says, "Ride more, think less", or something like that. After all, this is an 'oil thread', but I like oil threads. :-)
  14. #39
    SoFlo
    While many run and like Shell Rotella T6 I still remain a fan of the Mobil 10W40 Racing 4t motorcycle oil.
    For comparison, Mobil 1 10W40 Racing 4t motorcycle oil is currently ranking at #136, essentially the #1 highest rated motorcycle oil acceptable for a 1330 Spyder engine and gearbox. The test data value came in at 93,661 psi.
    Shell Rotella T6 5w40 ranked as #261 at 67,804 psi.
    If there are other motorcycle capable oils, with an acceptable viscosity and wet clutch rated, they may be listed but I did not notice them.
    Difficult blog to follow, but scroll down and the list of tested oils is long and impressive. No, not every oil is tested either.
    Ultimately though, I understand how many of you must balance frugality as part of oil change costs. With that Shell Rotella T6 costs less, but is also a lesser quality oil. Makes no never mind what oil you run, simply sharing a very good and accurate, independent ratings test, by a qualified person.
    https://540ratblog.wordpress.com/201...-test-ranking/
  15. #40
    Aug 2019
    Stoughton, WI
    Following threads on BITOG, Shell Rotella T6 5w40 has a reputation of quickly shearing down in shared sump bikes. Castrol Power 5w40 full syn also has a history of quicker than average shearing in shared sumps. Maybe that's a characteristic of 5W oils in motorcycle use? I get that people like Rotella T6 as it shows MA/MA2 rated on the jug, plus it can be had for $22/gallon from Wally world. That said, I have been a fan of both M1 10w40 4T and Amsoil 10w40 metric m/c oil for years and will continue using them. In fairness to Rotella T6, I have never heard of any oil related motor problems...
    2022 RT Sea To Sky
  16. #41
    Mar 2020
    Richmond
    Thanks to everyone for sharing your experience with Shell Rotella T6
  17. #42
    Sep 2021
    Fredericksburg, VA
    Amsoil 10w40 metric MC oil here also... To me it's worth the little bit extra $$
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
  18. #43
    Mar 2021
    Maryland
    I went with the T-6 10w-40 in the hopes that it would be more durable but with how cheap it is I am changing it out at every 5k instead of th 9.3 k recommended for the BRP XPS oil.
    2020 F3 SE6
    2020 F3 , Black
  19. #44
    Sebring, FL
    Wheer are you finding Rotella T6 10/40? I'd love to use it but I can't find it.
  20. #45
    SoFlo
    According to Shells brochure, 10w40 is not offered, but 5w40 and 15w40 is.
    https://rotella.shell.com/en_us/prod...synthetic.html
  21. #46
    Aug 2019
    Stoughton, WI
    Yup .. according to Shell oil, Rotella T6 full syn is offered in 0w40, 5w40, 15w40 and 10w30 weights. I see no 10w40 blends in T4/T5/T6 oils.
    2022 RT Sea To Sky
  22. #47
    Sebring, FL
    Oh yes, why they dumped the 10/40 is none of my business, but I continue to look for another brand I suppose, which might be Mobil One.. I had a wild thought of half T6 Rotella 5/40 and half T6 Rotella 15/40, but that could be a dumb thought.
  23. #48
    Mar 2021
    Maryland
    I just woke up and saw this and went out to the garage to verify and I think I found out why I am having the stalling issues in cold weather.
    It's the 15w40, I could have sworn I saw 10w-40 when I bought it at walmart. LOL I think I need to go in for an "old man checkup" between this and me forgetting about the kill switch a couple of weeks ago is really making me question my state of mind right now.
    2020 F3 SE6
    2020 F3 , Black
  24. #49
    Oct 2022
    Jacksonville, IL
    Do we have anybody here who has had their Shell oil analyzed and is willing to share their findings with us? With an oil analysis of the XPS blended stuff proved to me that I never want to use this again. Virtually the viscosity was gone!
    2016 Spyder RTL SE6
  25. #50
    T-6 is a Full synthetic .... I don't think they will thicken in cold temps like a dino oil will ....JMHO ....Mike
