Results 1 to 25 of 25
    Active Member JB62's Avatar
    Feb 2024
    Dover Delaware
    Wink Want to make it easier to remove the bugs - what wax should be used, if at all?
    I want to wax my Spyder to make it easier to remove the bugs and I don't want to damage the paint.
    What cleaning methods do you guys use to clean it. Thanks for the inputs.
    Last edited by Peter Aawen; 04-30-2024 at 01:12 AM. Reason: Expanded title to briefly ask the question... ;-)
    Feb 2012
    Spring City,Utah
    I put a coat of Mothers on once a year and then Yamaha Spray Detailer to clean the bugs and dirt off and put a new shine on it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member Elwood58's Avatar
    Mar 2012
    PHOENIX Arizona
    I wash with Chemical Guys Foam and wax with Turtlewax Ice.
    2012 Viper Red RT-S (Sold)
    2020 Ryker Rally
    2023 Plasma Red F3 Limited
    I recommend ANY type of wax ..... some say " Ceramic " ( which is NOT wax ) is best .... however if you read about that product you might not like what you find out ..... I did and don't use it ....Mike
    Feb 2024
    Tennesse
    I bought some stuff from Chemical Guys to use on my Spyder.
    Meticulous Matte Auto Wash
    Meticulous Matte Detailer Spray & Sealant for Crisp Satin & Matte Finishes
    Chenille wash mitt
    I haven't used them yet, but in my defense the odometer on my Spyder only passed 100 miles during my last ride.
    racoon
    Middle Tennessee
    2024 CAN-AM Spyder RT Sea-to-Sky - Vegas White Satin
    2023 Honda Ridgeline Sport - Sonic Grey Pearl (aka Baby Blue)
    2024 RT Sea-to-Sky , Vegas White Satin
    INDIANA, USA
    I use Mother's wash and shine. Wet the compete Spyder and then wash with the 'solution'. Doing this way 1 or 2 times a month as needed. As for the daily cleaning after I had a 'Ryde Time'. I use some spray wipe and polish. I have used a Yamaha and BRP product.
    Both are very good.
    Ryde clean and stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Feb 2024
    Dover Delaware
    Thank you guys for your advice
    Oct 2021
    TX
    I use Rejex, then bugs and dirt wipe right off with Mother’s instant detailer and a microfiber cloth.
    2019 RTL
    2019 RTL , Blue
    Active Member Two2Three's Avatar
    Mar 2023
    Missouri
    I've used various waxes, but between waxes, like after a ride or whatever, I always use Lucas Mist. It's a spray wax that works great for quick wipe-downs and keeping a shine and wax coat.
    On the windshield I think it does help the bugs come off a lot easier.
    2022 Spyder RT Ltd Petrol Metallic
    ________________________________
    Jan 2024
    Texas
    A good coat of wax/protectant, regardless of which one, will help with bugs and paint protection, period. It seems there's as many opinions as there are people. I've used everything from Lemon Pledge, to "specialty for plastics" products. Right now I'm using Turtle Wax's "hybrid ceramic" with very good results, and will probably try something else when that runs out, just to continue exploring And yes, all of these can be and should be used on the windshield. (This isn't true for everything...read the label, some things are not safe for plastics.)
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    May 2013
    Apex, N.C.
    F11 has always worked great for all my bikes, cars and trucks. Gives it a slick finish.
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    A way to "dissolve" bugs, and their related spatter, is to first spray the area with Hydrogen Peroxide. Bugs will literally "foam" up and will be very easy to wipe off. Like others here have said, use what ever type of wax or protectant works for you. The peroxide will not harm anything.
    Active Member BoatFixx's Avatar
    Oct 2023
    Port Hadlock, WA
    Quote Originally Posted by JB62 View Post
    Hands, down... "F11 Pro" on everything!
    2023 Sea2Sky
    Feb 2024
    Dover Delaware
    Quote Originally Posted by BoatFixx View Post
    Where can you get f11 from and do you guys wash your spyder or just use spray on cleaner
    Oct 2023
    Port Hadlock, WA
    I've bought it direct and from Amazon.
    I wash then apply.
    However, on long trips I use it as a waterless wash.
    I also use Griot's Spray-On Car Wash and the two seem not bother each other
    2023 Sea2Sky
    Sure I wash my Spyder!! It gets washed every time it rains while I'm out ryding!
    Oct 2023
    Port Hadlock, WA
    Why?
    2023 Sea2Sky
    Jan 2024
    Texas
    It better be, it's $$$!
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Oct 2023
    Port Hadlock, WA
    Quote Originally Posted by Allen42 View Post
    It is. A little goes a long way, and you can use it on everything.
    I get 10 months (water still beading off) on my 2000 Dodge Ram 3500. The truck lives outside, and it shines liker near new.
    We still use it on all boats.
    The higher the SiO2 content the more expensive it is. A professional content for high end vehicle treatment runs about $300.00 per 8 oz kit!!
    Part of our family business is yacht/boat detailing. I've been using/experimenting with all sorts of products for over 45 years.
    https://galmukoffmarine.com/services...uffing-waxing/
    Last edited by Peter Aawen; 05-01-2024 at 10:39 PM. Reason: removed color cmd stopping link fm working... :-/
    2023 Sea2Sky
    Member ZiggyF's Avatar
    Aug 2023
    Florida
    I’ve tried a lot of different products but in the end, I have gone back to the old tried & true things I have used for years. Aside from an occasional claying, I use Meguiar's Flagship Premium Marine Wax for my base wax & Meguiar's Ultimate Quik Detailer to remove the bugs & to spruce it up before I go on a ride. Being that I have a lot of chrome, I use Never Dull which I’ve used since the 1970’s. For the leather seat, I go with Leather Honey conditioner. For the tires, I go with Aero Products Rubber Care - no gloss, just a nice matte finish.
    I keep a bottle of Quik Detailer in my trunk with a fiber cloth since I lived in Florida - land of the love bugs.
    I used to try any of the latest & greatest products that came out, but I’ve narrowed it down to only these.
    2014 Can Am Spyder RTL Chrome Edition
    Led Headlights & Fog Lights
    Frunk Organizer
    Rear Trunk Organizer
    Painted Windshield Bracket Black with Chrome Spyder
    Leather Like Foam Hand Grips
    Handlebar Weights
    Plug N' Play Brake Light Flasher / Modulator Kit
    Trunk Mounted Run, Brake & Turn Signal LED Light Kit
    USB/Volt Meter
    Led Undercarriage Lights
    Show Chrome Full Size Brake Pedal
    Show Chrome - Chrome Handlebar Cover
    UltraGard Essential Half Cover
    Polished Stainless Steel License Plate Frame
    KEMIMOTO Motorcycle Bottle Holder
    Bluetooth 5.0 FM Transmitter
    Hopnel Trunk and Saddlebag Cargo Net System
    TackForm Center Mount Phone Holder
    Trunk Mount Dual Flag Holder
    High Way Pegs
    Baldwin Ironworks Cat By-pass
    K & N Air Filter
    Magnetic Mirror Mounts
    2-WDG Motorcycle Seat Cushions
    Kenda Kanine Tires
    Originally from Medina, Ohio
    Currently living in The Villages, Florida
    Oct 2021
    Wichita, KS
    Same here. It won't hold up for months like claimed, but does a very good job.
    Peter Pan has struck again!
    Bossier LoUiSiAna
    Vaguely remember a vid shared here of dogs licking fresh bug splatter off. Sorry has been awhile & **vaguely** being key word. Anyone else know it??
    Oct 2021
    Wichita, KS
    I'd be interested to know what you read that has you reluctant to use ceramic products Mike.
    Feb 2024
    Dover Delaware
    Quote Originally Posted by VitoNam View Post
    It really works well.
    Apr 2024
    Central Fl
    It does work well. A heavy rinse of water is needed as it is corrosive
