Results 1 to 22 of 22
    Active Member Escorial's Avatar
    Jun 2021
    Chicago il
    Question What could this mystery bolt on my 2020 RTL be from?
    While working on the bike I noticed what I thought may have been a vent tube from the battery hanging down from under the bike. I touched it and it fell out. It was a bolt!
    My vision is not all that good but when it was dangling it looked to be right of center about even with the center to rear front of the wheel. perhaps hanging from the belly pan or whatever is under the bike.
    Bike has 1700 miles and the only work I have had done to it was the brake switch recall and the front frunk latch adjusted.
    I tried removing the left tupperware to see how involved it is, but do not remember even seeing a bolt like that. I never completely removed the body panels as the Phillips Tuflock rivet was stripped, so I ordered some replacements and decided to do that when the parts arrive.
    So the mystery is, was it something left over from the factory? Or who knows what?
    Anyone out there have any ideas?
    Bolt head is 10mm and stamped on the top is 8.8, under that is B.Y or 8.Y
    Please look at the pix.
    TIA and Have a Safe 4th
    Last edited by Peter Aawen; 07-03-2023 at 10:03 AM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    My first thought was one of two bolts that holds the seat!
    I just had mine off and that sure looks like one of those, you are missing a nut tho, if I am correct.
    Item 20 and 19 on this partlist !
    Brgds Martin
    Durham,Maine
    Have you ever change the seat or has someone else had it off? That black hole from no where have swallowed many items!
    2012 RTL , Pearl
    Oct 2020
    Vinton, IA
    Don't think that is a seat bolt. I've had my seat & sidepanels off 6 - 7 times; there is little or no chance a seat bolt could make it past the gas tank and engine assy to hang out that far forward.
    My first inclination...., it's a sway bar mount bolt. Have you changed your sway bar?
    If not, take a look at the BRP parts diagrams and look above & ahead of where it was hanging out. Maybe the air intake box or anti-freeze overflow container.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Jun 2021
    Chicago il
    Quote Originally Posted by spyderdave View Post
    When I purchased the bike, it did come w/ BajaRon Sway bar installed.
    Both ends are bolted w/ larger bolts that I see, what I did notice there is a little slop when I move from side to side. Otherwise, I see nothing but again I do not know what I'm looking for.
    Can I view it by just sliding under the bike?
    Clinton, MS
    It's definitely not a seat bolt. Remember the design changed in 2020.
    2019 RTL Phoenix Orange
    Dec 2020
    Hartwell, Ga
    Maybe the bolt that holds the bushing's in place for the swaybar?
    Also being your bike is new, it could be that the person doing the final install of things at the dealer dropped it and couldn't find it so they used another.
    I just looked at the pics again, at those bushings there should be a bolt going through them, is there? If so, I would tighten them, they look loose to me.
    Last edited by K80Shooter; 07-03-2023 at 02:28 PM. Reason: Added last sentence about loose bushings.
    Dec 2020
    Hartwell, Ga
    In the picture at the YELLOW ARROW there should be a bolt going through there on both bushings.
    At the RED ARROW feel with your finger and see if the bottom of the bushing is flat or does it have a slight dimple in it? If flat, it needs to be tightened up a little.
    Nov 2015
    Chardon, OH
    I think you might be on to something here. Plus, let's check the two channel stiffener bolts. One on each side, just inboard of each bushing. Make sure they are both still there.
    Edit - Picture
    Doug
    ”Freedom is not a loophole”
    Oct 2020
    Vinton, IA
    I was just gonna add that; thanks!
    Apr 2023
    FL
    +1 for K80 Shooter and Snowbelt Spyder. Either the bushing bolt or the channel stiffener bolt.
    Chip
    2020 RTL
    "Stella by Starlight"
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    Edit - Picture
    There are no channel stiffener bolts on my 2013 Spyder ST, Should there be?
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by RangerRick View Post
    Not Snowbelt Spyder but,
    I helped install a Baja Ron bar on a 2015 RTL and it also did not have the channel stiffener bolts. I think that BRP started that a little later on.
    Jun 2021
    Chicago il
    Ok have the bike up on the lift, both bolts are missing that go through the rubbers, also in your photo with the red arrow both of those spacers/bolts ate loose/ So looks like I will be ordering parts. I do not know if the previous owner installed the sway bar or the dealer did but whoever did it did a very bad job. Im just glad I did not loose those spacers or shims.
    Could anyone tell me how tight the bolts should be that go through the shims? Also I will be using blue lock tight on everything,
    Jun 2021
    Chicago il
    I just want to double check on the parts needed. I suspect that I need
    190 Screw-Hex.Flange M6 X 60
    250000778
    $4.19 x2
    195Washer M6
    250200029
    $2.39 x 2
    200Hex. Flange Elastic Nut M6
    233261466
    $1.89 x
    See arrows in pix ( bad way to spend the 4th)
    Jan 2019
    Western PA
    Here’s a recent thread with some great information from Ron about proper tightening of the sway bar blocks and end links.
    https://www.spyderlovers.com/forums/...light=Baja+Ron
    2022 RT-L , Silver
    Jun 2021
    Chicago il
    Thanks btw what would the plastic panels that cover this be listed under in the parts diagrams? I already lost a screw hehe
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Escorial View Post
    The Splash Panels? Body And Accessories Fairing.
    Doug
    Jun 2021
    Chicago il
    Thanks again!!!!!
    Dec 2020
    Hartwell, Ga
    When I purchased the bike.it did come w BajaRon Sway bar installed.
    This is what got me to thinking that there was a problem with the installation. Glad that you found it. The Spyder will ride better when you get this taken care of.
    Apr 2023
    FL
    250000778
    $4.19 x2
    195Washer M6
    250200029
    $2.39 x 2
    233261466
    $1.89 x
    Those are indeed the parts you need, although if you don't feel like waiting for delivery there are undoubtedly places in Chicago to buy grade 8 bolts.
    Chip
    2020 RTL
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    McMaster Carr and they will ship to you. I recommend proper length sleeves on all the channel stiffner bolts as well as proper flanged nylock nuts with serrated heads
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
