Results 1 to 5 of 5
    Nov 2022
    ME
    Default Gauges acting a bit strange - any ideas on cause?
    Hello all! I’m new to spyder ownership , just bought a used 2011 rt-s in blue. Love this machine it has really scratched my itch to get back into riding. I do seem to be having an issue with my gauges. I’ve been riding some chilly weather here in Maine, as low as 38 degrees and my temp gauge suddenly goes to just below the red zone if I idle for very long. The other curious thing is when I shut the bike off the fuel gauge pegs out way past full and the temp gauge rest out at the quarter mark. These readings connected? Is something affecting the reading? I also just connected a quad lock power source for a wireless mount on the handle bar mounts, would that affect the gauges? Any advice appreciated- I’ve already learned a great deal from this forum and appreciated the collective experience here
    Nov 2011
    Brisbane Australia
    Does it have the magic mirror mod - this affected some. There was a fix but am unable to remember what it was.
    Best of luck chasing the Gremlin
    Quote Originally Posted by 10centspyder View Post
    Well if this Spyder is new to you, it could be low on anti-freeze .... hopefully it has some in there now, and it's not so old it no longer provides adequate cooling ..... Mine got low & this was the cause .... It's difficult to see Exactly how much is in the reservoir ...... So I just added until it over-flowed, the next ride I took it spit out the excess from the system. ..... Mike
    Feb 2012
    Spring City,Utah
    Check your battery connections. Loose ones are know to cause erratic gauge readings. Also the older analog units were known to be erratic anyway just cause. If you disconnect the gauges your digital ones will show up on the dash and are much more reliable.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2017
    Agree with that entirely. Disconnected the analog gauges on my wife's 2012 RTS, before she traded it for a newer model, and found the digital gauges were much more stable and reliable. In fact, we removed the analog fuel and temperature gauges and replaced them with a digital voltmeter and a dual USB port. Did the same on my 2015 RTS as well and were/are very pleased.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
