Results 1 to 6 of 6
    Maine
    Default Spyder pulling to left - Any ideas/suggestions?
    Can't solve my Spyder issue it pulls to the left while driving. Tire pressures are equal at 16 lbs. , 3 oz. balancing beads are in place. I tried rotating the front tires and it made the Spyder pull to the opposite side. Any ideas/suggestions?
    Last edited by Peter Aawen; 09-01-2022 at 04:25 PM. Reason: Expanded Title to briefly ask the question ;-)
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    If the pull goes with the tire location, it is a tire problem. Possible broken ply in the tire. Replace tires.
    2014 RT SE6
    Sep 2014
    USA
    Bump up the pressure a few pounds and see if it’s any better.
    As mentioned maybe bad tires.
    Danbury Connecticut
    Quote Originally Posted by SpyderJerry View Post
    Exactly. Your problem follows the tire, it's a problem with the tire.
    Replace the tires with a car tire.
    IBA #47122
    2020 RT Limited Asphalt Grey
    NorCal - Northbay
    As stated by SpyderJerry, it is a problem with the belts/casing in the tire... Happens even with car tires. I have a Michelin causing a drift on my McLaren right now!
    Chuck
    Quote Originally Posted by sandman53 View Post
    More tire info would be helpful ..... however as others have said if the issues Follow the tire ..... then it's probably the Tire .... JMHO .... good luck .... Mike
