Results 26 to 50 of 55
  1. #26
    Sep 2015
    Chilliwack, BC. Canada
    Ride safe stay safe and live long enough to become an old biker.
    How old do I have to be to qualify as “an old biker”?
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  2. #27
    Quote Originally Posted by bigbadbrucie View Post
    You are as old as you feel. WARNING, WARNING, WARNING, that number can vary from person to person.
    Dec 2015
    Oakley Utah
    And, this is why trying to find solid information by searching topics on threads is a painstaking exercise in frustration. Which is why newbies keep asking the same old questions about the same old topics. Which is why PROPERLY DESIGNED AND CONSTRUCTED STICKY threads on common topics would be invaluable.
    Gurus aren't necessary for a sticky to be useful. Just someone who thinks and writes in a deliberate, organized, coherent fashion and moderators who are able to impose some discipline on TECHNICAL threads.
    I'm not going to hold my breath.
    2014 RTL Platinum
  4. #29
    Katy, Texas
    I think I can fix this thread...
  5. #30
    INDIANA, USA
    ....Well now, let's just think about this situation.
    I use to feel young until one day I was going to do something and it happened. I was NOT able to do
    what I had done in the past. It was very painful, both Physically and Mentally. ......
    So for me, I have enjoyed being an active member of the 'Ole Man Club'. ......
    This 'Old Biker' thing really scares me. I will need more help and time to give an answer. .......
    Thank You, .......hope you enjoy your day..: )
    ENJOY YOUR LIFE WITH A SPYDER
  6. #31
    INDIANA, USA
    Default Tires Tires and Tires
    I believe a 'Tires Stickey' would be a good thing.
    So let us have positive feedback and just do it.
    Have yourself a Great Day. ......
  7. #32
    Gurus aren't necessary for a sticky to be useful. Just someone who thinks and writes in a deliberate, organized, coherent fashion and moderators who will impose some discipline on TECHNICAL threads.
    Ah Ha...I knew it was going to be the moderators fault, eventually.
    Dec 2015
    Oakley Utah
    Not at all. The problem as I see it is the rules, as written, don't provide for any kind of thread topic discipline that can be enforced. In other words, this forum works well for its intended purpose, but not as a repository for objective technical information, which is what people are asking for when they ask for a sticky on after-market tire fitment and performance.
    2014 RTL Platinum
  9. #34
    So far, no one has jumped in to do the deed. You are welcome to start a sticky thread on tires. You have good ideas. Go for it.
    The subject has kind of been kicked around now for a couple days. Many suggestions made, nothing happing of note.
    The "usual" back and forth with good ideas.
    But so far, no takers.
    We will let this subject run another day or so. Then if no thread, we should probably close this one down.
    I am thinking, not happening at this time.
    Let us know if you want it to run or to be closed down.
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    Let it run!!!!!
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
  12. #37
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    How about:
    Front
    Year Model Rim Size Brand PSI Traction
    2010 RT 14"
    2013 RTL 15" 165/55-R15 Vee Rubber 18 Hydro Plane
    2021 Sea/Sky 15"
    Rear
    2010 RT ??
    2013 RTL 15" 225/50-R15 Kumho 25 Good
    2021 Sea/Sky 15"
    Hope this load as I see it now. Probably put together on a spread sheet first and then up loaded. Updates would reload a new spread sheet.
    DELETE THIS ONE
    Can Am 2013 RTL SE5
  13. #38
    Dec 2016
    Quote Originally Posted by wingit3611 View Post
    How about:
    Front
    Year---Model------Rim----Size----------Brand-----------------------PSI-------Traction
    2010---RT---------14"
    2013---RTL--------15"----165/55-R15--Vee Rubber-???------------18------Hydro Planes
    2021---Sea/Sky---15"
    Rear
    2010----RT--------??
    2013---RTL-------15"-----225/50-R15----Kumho-ECSTA-KU25-----25------Good
    2021---Sea/Sky--15"
    Couldn't find edit so I did this. But that's the Idea. Looking for comments, Pluses & Minuses.
    Now I see the Edit
    Can Am 2013 RTL SE5
  14. #39
    Dec 2015
    Oakley Utah
    Now I see the Edit
    That's a good start.
    2014 RTL Platinum
  15. #40
    INDIANA, USA
    Default Excellent Start with Tires
    How about:
    Front
    2010 RT 14"
    2021 Sea/Sky 15"
    Rear
    2010 RT ??
    2021 Sea/Sky 15"
    This is a wonderful start. Hopefully everyone has enjoyed something meaningful and can move forward.
    I have been locked into the OEM tires. My local Spyder Dealer will Not install anything but OEM TIRES. ..
  16. #41
    Feb 2020
    Minnesota,USA
    Now I see the Edit
    Maybe add one more detail : such as: Kumho KU-22, or Kumho KH-16, :
    would like to know the type or model of tire, only trying 2 help!
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
  17. #42
    There is now a Sticky at the top of Spyder General Discussion for you to provide details of the a/mkt Tires you are running on your Spyder.
    https://www.spyderlovers.com/forums/...Spyder-Details
    Any other discussion or off topic posts will be removed from that thread as detailed in the first post, but you are invited to share the info requested as per the first post in the thread.
    There is also a Sticky at the top of the Can Am Ryker General Discussion section for those with Rykers to provide details of the a/mkt tires you are running on your Ryker.
    https://www.spyderlovers.com/forums/...-Ryker-Details
    Nb: These Stickies are being trialled - if they don't get posts, are abused, or otherwise fail, they will be removed or un-stuck.
  18. #43
    Katy, Texas
    Quote Originally Posted by seaweed View Post
    Let it run!!!!!
    Ya baby... I gots lot more explosives.
  19. #44
    Clinton, MS
    Thank You...................
  20. #45
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Just want to say that I really like and appreciate the new tire sticky for the Spyder. THANK YOU!!
    The structured format is exactly what I have been looking for to more easily be able to find the information I need pertaining to my year and model of Spyder in order to purchase the right size car tire for replacement …. and for which wheels… front or back..
    Since Spyder tire sizes are different from car tire sizes I do not know EXACTLY what size car tire to buy just by going to a tire dealer’s website.
    In perusing the jillions of tire threads I have several pages of notes I have jotted down so that when the time came to make an actual purchase hopefully I was buying the correct size tire…my notes all end with: ??
    I have a few thousand more miles before I have to make the replacement purchase but at least now I will be able to make a proper decision pertinent to my vehicle.
    P.s…. I also appreciate that members are putting the year and model in their signature.
    Members have some really good skills, experience and information but it is frustrating to figure out later it doesn’t pertain to my year and model Spyder.
    Thank you members for updating your signature area.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
  21. #46
    Dec 2016
    Quote Originally Posted by Knizar View Post
    Did an edit and added detail. Yes it was needed.
    Can Am 2013 RTL SE5
  22. #47
    Mar 2015
    forrest above Reno, Nv
    How about a " templet" that can just be filled in so there is some consistency in the thread????
    Lew L
    2014 RTS , Circuit Yellow
  23. #48
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Lew L View Post
    Lew L
    pretty useless without it.
    2014 RTL Platinum
  24. #49
    Lew L
    That's something that's not easy to do..... if at all possible! I don't know if this version even supports them?!
    That said, if you just use the mouse to select/highlight the important bits of the previous post, then copy & paste it into your post before editing out their tire details & putting your own in, you've achieved the same result with just a few clicks!
    Might be a bit harder on a phone, but if you know how to select & copy text then it shouldn't be too hard to paste & edit the details in your own post.
  25. #50
    Sep 2015
    I hear what you’re saying, but personally I think that way will discourage many. For the computer literate folks, I should think that someone should be able to devise a template that works on this system, especially in this day and age. jmho
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
