Results 1 to 9 of 9
    Active Member SpyderF3-s's Avatar
    Oct 2015
    Menifee, CA
    Default 2015 Spyder F3-S SE6 stalls when idling with Check Engine Light on
    After driving my 2015 Spyder F3-S SE6 (87,500 miles)for about 5-10 minutes, when I come to a stop, the engine check light comes on then stalls. Works fine when over 1000rpm. Finally was able to get an error code..P0106. Error code states it is possible mass air flow (MAP) sensor or tubing leak.
    I have checked the filter, changed spark plugs and only run premium gas.
    I have looked and can not figure out where the MAP sensor is located. Can someone point me to the location? Is it part of the throttle body module? Also under what section in the BRP parts list is it located? Thanks!
    God bless those who serve/served our country!
    Jan 2021
    Descanso, CA
    Spyderf3-s -- those glasses you're wearing ... you need a new pair. It's MAP not MAF.
    P0106 ECM Manifold absolute pressure circuit range/performance
    And the sensor is actually MAPTS (MAP+Intake Temperature Sensor). EFI Subsection Page 25 in my 2014 Service Manual. Top Left side of engine. 4-pin connector. It's probably leaking a bit of air or a connector isn't quite perfect. Easy to replace if it's bad.
    Oct 2015
    Menifee, CA
    Unfortunately I do not have a 2015 F3-S service manual. Does anyone know the part number? Is it 707000995 - Pressure And Temperature Sensor?
    Jan 2021
    Descanso, CA
    That's what it is for my 2014 RT-S SE6.
    Oct 2015
    Menifee, CA
    Thanks!
    Oct 2015
    Menifee, CA
    For those who may have to replace the MAP sensor, it is easy to access the screw that holds the sensor in place by taking the plastic cover around the ignition off. The screw is straight down and requires a T27 to remove it. Just a FYI, the screw is not magnetic so be careful when removing
    Durham,Maine
    Did it solve your problem???
    2012 RTL , Pearl
    Oct 2015
    Menifee, CA
    Drove it this morning and no errors. So far it looks like issue resolved.
    Active Member lugnut1009's Avatar
    Nov 2018
    Mississippi
    Quote Originally Posted by SpyderF3-s View Post
    My wife’s ’18 F3L is doing this now intermittently with approx 72k miles on it. I hope this was the fix for you, I’m going to tackle this on hers this weekend!
    Mine: 2016 Indian Springfield & 2021 Indian Roadmaster
    Wife: 2018 Can-am Spyder F3 Limited Pearl White
    2018 F3 Limited , Pearl White
Tags for this Thread
