Page 1 of 3 123 LastLast
Results 1 to 25 of 52
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    Default Does anyone use Fuel Additive in their Spyder? Is it safe?
    does anyone use Fuel Additive in their Spyder ??? I use Sea Foam in most everything I drive and Ride.... but just wondering if its safe in a Spyder ?? as in it not good for the Fuel Pump or Fuel Injectors any Ideas ???
    Mar 2018
    Madison, WI
    I use Stabil for over winter storage.
    But I never use additives other than that in my Spyder.
    Ethanol free fuel is available to me locally, so that's what I use a large majority of the time.
    2014 RT - SE6 , Black
    Mar 2015
    forrest above Reno, Nv
    I use it religiously In my poor, old, slow V-Max and occasionally in the The snow blowers get a shot of it also.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2021
    Limestone Tn.
    oh you use Sea Foam in your Spyder ???
    Aug 2021
    Limestone Tn.
    I'm a 70 year old retired Mechanic. I worked in a VW Dealership in 1969 and 1970... then other jobs... then a Fiat Dealership 1975 & 1976... then went into a Big Diesel Shop, Tractor Trailer in 1976 through 1989... and I do all my own services on everything I drive and ride... but I am quick to admit I don't know much about New Cars, Trucks, and Motor Cycles... I'm sure you folks know more about these Spyders than I do. So thanks for any advice.
    Durham,Maine
    I use it, and have had no problems doing so!!!
    2012 RTL , Pearl
    Northern Kalifornia
    If you buy brand gas like Shell and Chevron they have everything in them you need and nothing that you don't. Most additives are all made simply to make money for the manufacturer who makes and sells the product. As the saying goes, a new mousetrap is being invented every day. As I work my way through my gas cans I can easily end up with 2/3-year-old gas in the last can. It works just as well as the gas I bought yesterday. If like most of us, you run premium gas in your spyder at some point you will be pumping "old" gas. Particularly if you travel long distances. Just ask some of the delivery guys. Most people nowadays don't pump premium fuel because of the cost and their cars don't require it. So, the premium we buy may have been sitting underground for who knows how long. If moisture gets to your gas it will form in the bottom of the tank or whatever it's contained in. Some vehicles like my old 6.9 diesel had water separators built into the fuel system. About once a year there's an article in the local paper where some out of the way mom & pop gas station had to get their tanks pumped because of customers getting water instead of gas/diesel. Fuel additives will cure everything from bad gas to burnt valves and broken piston rings, so some claim. If marketed properly you could sell "Total rebuild in a Bottle," and make millions.
    Jun 2011
    Near Lexington, NC
    I have read that Sea Foam is little more than kerosene. Whether that is true or not, I don't know. As others have said, good brand gas is all you need.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Aug 2019
    Stoughton, WI
    I store my Spyder over the winter with 91 oct/ethanol free gas and Seafoam. Come my mid summer trip, I'll also top off the tank with Seafoam in it. 2X a year is plenty..
    2022 RT Sea To Sky
    Aug 2021
    Limestone Tn.
    Thank you, I just didn't know if that was a no-no or something, thanks again for your help.
    Aug 2019
    southwest oHIo
    Sea Foam won't hurt your Spyder. Personally, I am not convinced that it will help anything, either. I know some guys that will add a capful or two to every tank. Not sure what that's supposed to 'cure'. It has been promoted for off-season storage. I tried it for a couple of years, then went back to Sta-Bil. Any of my 4-stroke machines that get seasonal use get stored with a double dose of Sta-Bil before storage. No problems when it's time to fire them up again.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Use it in Spyder and every thing else with a motor
    western Colorado
    I used seafoam but use startron most of the time.
    Bossier LoUiSiAna
    Use to &stopped tried various brands gas & or treatments all broke even -Ethanol free improved MPG harder to find & also about even price with the additional treatments without having to carry around or remember while at the pump.
    *NOTE* however have had mix of rich & lean Codes https://www.spyderlovers.com/forums/...k-engine-light now at 70k miles & still acting up
    Northern Kalifornia
    Most all additives get blown out with the exhaust and collect up in the cat, if you have one.
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    I have used Seafoam in my Honda Valkyries (2) since 2004 for Winter storage and Our Spyders (3) since 2016 with no trouble at all.
    T.P.
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    Quote Originally Posted by Grayfox View Post
    Agreed!
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Apr 2020
    I use Seafoam in my Goldwings religiously.
    I use it when putting the bikes away for the season along with a fuel stabilizer. I use it in the gas and the oil when needed. All of my Wings (1100, 1200 and 1500) use good old fashion carbs and it works great with them and it dissolves carbon on contact. Works great with oil as well.
    The attached pics are of a 86 Gl1200 engine from a bike I am restoring for my son. Basically a before and after of 2 treatments of Seafoam. I don't believe in 98% of the "treatments" out there but I see huge benefits with Seafoam.
    Tim
    ___
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    I only use Seafoam in my mowers and small engines now. I used it in my bought used SeaDoo and it loosened up the green algae in it's fuel system just fine but all that junk plugged up the small filters in it's Mikuni BN carbs inlets. What a PITA to service those carbs.
    I use Techron in my injected motors like my 1200 SkiDoo's, outboard motor and vehicles for injector cleaning / maint. .
    Seafoam works great but I'm hesitant to use it in a really dirty injection fuel system now. I use marine grade fuel stabilizer and E0 fuel in all my stored toys and equipment. No issues with chain saws that may sit a year or two unused.
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
    Nov 2019
    Central Oregon
    I'm a fan of Seafoam as well, with plenty of anecdotal evidence on various engines and vehicles I've owned and/or worked on.
    But.
    If you're not familiar with this guy, a Canadian with a good sense of humor, check this out: https://youtu.be/chsGBhB5g7o
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (Front).
    Sep 2014
    USA
    Royal Purple Additive
    Vermont
    Quote Originally Posted by sledge View Post
    I use a fuel stabilizer in my spyder for the winter lay up/hibernation.( Oct. to April) Fill the gas tank with gas, then add a fuel stabilizer. I have been doing since 2012.
    In the spring spyder starts up. My spyder is on a battery tender from Oct. to April.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    I also use a fuel stabilizer in my sled off season. No problems.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Aug 2021
    Limestone Tn.
    Sea Foam says to use 1 Oz. per 1 Gal. of Gas. so my Spyder holds little over 6 Gal. it says. ... i might start with a couple of Oz. per tank first. I sure thank all you folks for your help and advice . Thank You.
    SoFlo
    For years, I use Yamalube Fuel Med RX in every tankful unless traveling and burning fuel, vs typical around town riding. I buy the small bottles and keep several in the frunk. One bottle treats 5 gallons of fuel.
