Results 1 to 16 of 16
    Jan 2020
    North Georgia
    Default DIY 2012 RTL floorboards
    Mar 2019
    NEBRASKA
    Very nice!!
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Lookin' pretty good to me!!
    Maybe you could add a quick touch of black paint to those shiny bolt heads on the boards and the brackets too, just to make them blend in a bit better?!
    Your call, they certainly look as tho they'll do the job, and probably keep juust a bit more spray off your feet than some?!
    Jan 2020
    North Georgia
    That’s the plan to paint the screw heads. All the screws and nuts are stainless, so no rust. Just need a good warm day to do it, boards are painted with bed liner.
    Quote Originally Posted by Eredding View Post
    I did something very similar to my 14 RT after I brought it home from the dealer in Ill. ,..... I love DIY'ers ..... Mike
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Very nice. I did something very similar with aluminum diamond plate, though I didn't paint them. Way cheaper than buying a set.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Jan 2020
    North Georgia
    The diamond plate came from a scrap yard and the color didn’t exactly match even after polishing, so I sprayed the with bed liner. $14.00 worth of aluminum and about $20.00 in supplies and hardware. Can’t beat them.
    Mar 2019
    NEBRASKA
    Can you elaborate on the attachment? Pics possibly? Thanks Dave
    Jan 2020
    North Georgia
    I will post some more pictures tomorrow
    Mar 2019
    NEBRASKA
    Love to get some pics OR can I have you make a pair?
    Quote Originally Posted by davev1pa View Post
    His are similar to mine ..... I can't tell if He bent His or not ??? ...... my boards are not bent, after taking the oem rubber pads off the pegs, I mounted the boards using the oem angle and hardware ...... the rear of mine are a bit higher in the rear , they will be just ABOVE the bolt head shown in His pics, so my bracket is hidden under the board completely ...... the reason I went with the same angle as the pegs were to make sure the Brake Pedal could be FULLY applied in a Panic stop..... it's hard to tell if His can do that ..... On the RT-S and RTL the oem boards can drop lower in the front in a Panic stop ..... I haven't found my angle to be un-comfortable ..... it feels right ...... Mike
    Mar 2019
    NEBRASKA
    I can appreciate that..thank you.
    Active Member vindex1963's Avatar
    Jul 2018
    Payson AZ
    I put Victory Cross Country floorboards on mine.
    CLICK
    2012 RT A&C SE5
    2015 Victory Cross Country (Dyno tuned 118hp 116tq)
    2006 Triumph Rocket Dyno tuned 140hp 154tq)
    Quote Originally Posted by vindex1963 View Post
    CLICK
    I see you have the same board angle as I do ...... Mike
    Apr 2013
    Rocanville Saskatchewan canada
    Ultimate boards on 2012 RTL
    Jan 2020
    North Georgia
    I haven’t had a chance to take more pictures yet. I put a 1” square tubing spacer between my brake pedal rubber pad and brake arm to allow for panic braking. Works great.
