Results 1 to 10 of 10
Thread: Battery
    Dec 2016
    Iowa
    Default Battery
    Is the Motobatt one of the better options for 2016 RT Limited? Bought the cable from Tric-LED to allow better access. Could not get much to fasten onto the default BRP that came with it.
    2016 RT Limited , Black
    INDIANA, USA
    Default Information
    I need more information on your Mission.
    Are you talking about additional accessories or a Battery?
    Please let us know......
    ENJOY YOUR LIFE WITH A SPYDER
    Dec 2016
    Iowa
    Yep, just a battery, mine died.
    Sep 2018
    greensburg,pa
    Lithium seems to be the way to go!
    https://www.spyderlovers.com/forums/...ithium+battery
    2018 RT-L , Blue
    NorCal - Northbay
    Quote Originally Posted by bluewoo View Post
    Definitely. Huge weight savings and higher PCA (CCA for you old-schoolers). The only thing that some of them don't like is cold weather (below 40F). I haven't experienced this with my Shorai at all, which is a Lithium Iron Phosphate (LiFePo) unit, not the more common Lithium Ion. But have read some with other battery makes have.... This can be alleviated by first warming the battery by cranking to get the lights to come on and keep them on for like 5mins. Shut the ignition off and wait a minute, then retry and the next crank will be normal/full power....
    Chuck
    Nov 2015
    Memphis, Tenn.
    What does PCA stand for? and why does someone think it needs to change????
    Dec 2016
    Iowa
    Well, Iowa here, so Below 40 is a real possibility.
    NorCal - Northbay
    Quote Originally Posted by jcoats1 View Post
    Pulse Cranking Amps.... It depends on the battery manufacturer but more and more are rating them this way. It has to do with the way the battery delivers its power at the moment of cranking for the average 3sec start sequence.... I dunno why they are adopting this method. Some like Shorai still list CCA in their measurements.
    Chuck
    Quote Originally Posted by Tyris View Post
    As is 40 below, right?
    Dec 2016
    Iowa
    Well windchill wise yeah, could hit that but doubt I'd be riding. Getting snow tonight, "I'm dreaming of a white "Halloween"
