Results 1 to 21 of 21
Thread: Ryker Fun
    Jun 2010
    Las Vegas
    Default Ryker Fun
    Installing a BajaRon bar on Highwayman2013’s Rally. It is a cool 100+ in the garage today, what better way to spend a day. I was fortunate enough tp be busy doing something else so I didn’t have to help.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Kansas
    Just be glad you did the BajaRon Bar and not the CanAm Bar. My wife said I actually made up cuss words she had never heard before uninstalling and installing the upgraded CanAn Bar.
    Mar 2017
    Salisbury,NC
    Looks like your husband is being forced adult labor!!! while you take pic and run back into house AC!!
    Apr 2013
    Vancouver Is. BC /Arizona
    I thought I saw a utube video where you cut the old sway bar in half to remove, then you can snake the new BajaRon bar in without removing all the front body parts. Please clarify
    whether this is correct or not. Thanks.
    Gotta love those projects that entail the invention of new cuss words.
    Default Soooooo...!!
    Where was the fun part...?? hate to work in those conditions just sweat all over the work...One of those swamp cooler fans helps a lot....
    Thinks out loud
    Apr 2012
    Around here we call it.......... Slow Cooking!
    Cooler days are just around the corner
    Durham,Maine
    x2!!!! I know I have made up some new words this year!!
    2012 RTL , Pearl
    Ann, sounds like you planned your day perfectly. Best!
    Quote Originally Posted by cheska View Post
    I am not familiar with the YouTube video you reference. And I was not able to find it. But you are correct. The BajaRon Ryker sway bar slides in through the wheel. You CAN do the job without removing the front components. But in our experience, it is a much more difficult job to do it that way.
    It looks like a lot of work. But removal of the front end parts is very easy and does not take very long. It's only a few steps. This gives you much better access to the nuts/bolts which hold the sway bar to the frame.
    If you can find that video and post it here I would appreciate it. Who knows! Maybe they found a better way to do this install.
    Jul 2010
    Las Vegas, NV
    4 hours, 1 was spent on the bushing hardware. The ABS is right in the way. Cutting the old bar took a couple of tries: hack saw(gave up on that pretty quick) and then a jig saw, then a cut off wheel. Lost a bit of time with hardware going into the black hole, requiring a search. We do have a swamp cooler, and it was not as bad as teaching motorcycle safety on hot asphalt, which I did today. Barely 110 today. Great product, easy to follow instructions, great results! Thanks Ron, and thank you, Len, for allowing me to learn this new part!
    Joe Meyer
    Nov 2012
    North Las Vegas, NV
    We had fun and those bushing bolts were a pain.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    The bushing bolts are a bit of a pain. Though after you do it a few times it gets a lot easier. But, of course, this is a 1 and done project for most.
    May 2009
    Connecticut
    https://youtu.be/qQrDLs6nOYQ
    This shows the BRP bar installation attempt and covers some real good take the front end apart points. Rons is Much easier but this video would help anyone to be more familiar with the beast.
    Sea Doo GTI-SE 90 Jet Ski!!
    Nov 2012
    North Las Vegas, NV
    Well yes you do cut the original bar in half. The bodywork and radiator must still be removed to get to the bushing bolts. Also the left shock (viewing from the front) must be removed so Bajaron's bar can be inserted through the wheel hub.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Actually, there are several ways to do the install with the BajaRon bar kit. There is a way to do it without removing the shock and some other alternatives as well. The instructions I provide give what I think is the overall easiest method for the 1 time installer. If you were an installer like SpyderPops or Lamonster Garage, you would probably do it a bit differently because 1- Time is money. If an installer can save even 10 minutes on an install, that is huge. Not so much for a DIY'er. 2- If you do the install a good number of times, a more technical approach isn't going to give you the same kind of grief that a 1 time installer might have.
    There are also considerations about scratching up your new bar. We were not able to do the BRP bar install without scratching it up. The scratches don't do any real harm to the bar. And you can't see the scratches once it is installed. Still, I just don't like scratching up a new part.
    For the Factory Upgrade Bar install, there really are no options or shortcuts that I am aware of. Cutting the original bar will get you nothing with the Factory upgrade because you will still have to dismantle everything anyway to get the new BRP bar in.
    Nov 2012
    North Las Vegas, NV
    5BBBF215-E845-477C-8840-14CD50E5FCDC.jpgDC87D04F-4042-4B64-AFD4-8A4E6B6AFEC0.jpgOn the plus side I was able to make it up to the mountains today for a good test. Bajaron bar is far superior in the corners compared to the stock Rally bar. Unfortunately I also drew the attention of the State Police.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Dec 2015
    Oakley Utah
    Len, you have a weird sense of 'fun'...will we see you at another Ryde-In with the Ryker, or will you be riding your Spyder?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    I bet they stopped you just to admire your new ride....right? Maybe you need to black out that hi-viz accent color...
    2014 RTL Platinum
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I know the black out comment was tongue in cheek but I really like the color matched trunk. I would consider something similar to mine in hopes of brightening up an otherwise dark back end. No point in getting run over.
    2019 Ryler Rally , Shock Yellow
    Nov 2012
    North Las Vegas, NV
    Not sure which one yet.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
