Results 1 to 18 of 18
Thread: front tires
    May 2019
    Windsor
    Default front tires
    I need to replace the front tires on the old RT, I was talking to a few tire guys and they asked " because of the configuration of the spyders why can't you just use conventional tires on the front instead of motorcycle ones? I did not have an answer other than that is what came with it. Dose anyone know of a compelling reason why we can not use non-motorcycle tires on the RT?
    USA
    A bunch of threads on here support the use of car tires. Mr. Blueknight911, Mr. Peter AAwen, Ms Spyderanne01, Mr. JCthorne and a bunch of others are all excellent reading. I personally use the Vredstein Quatrac 175/55R15 front and Vredstein 205/60R15 rear combination, but there are a few very good choices. Do an advanced search with the names and put tire in the query. Should keep you busy for a couple of days, weeks, or months, depending how much you want to know.
    h0gr1der
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by tflatt View Post
    Many people here use car tires. If you want a recommendation we need to know the year of your RT.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Spyders use car tires. The Kendas that come on them are very poorly made car tires. I know.......they say "for special motorcycle use only" on the sidewalls. The reason for that is the load carrying capacity of the Kendas is so low that ANY vehicle other than a Spyder would be over the limit of them. I recently had Vedestrein Quatrac5 tires put on the front and I am still blown away by the improvement in ride and handling.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    May 2019
    Windsor
    Default why motorcycle tires
    I have a 2010 RT-s 165/65R 65R14 47H
    …. be very, very careful of who you get Spyder info from ….. A lot of folks really think they are helping …. however bad info can KILL you …. Vredestein Quatrc 5 comes in 14 inch sizes also ….. I highly recommend them ….. Mike
    Apr 2013
    Rocanville Saskatchewan canada
    I see you are from Windsor, is that Windsor Ontario. I changed two 2012 RTs over to Hankook car tires, purchased from Canadian tire, They have been working great on fronts.
    Roger
    Nov 2012
    North Las Vegas, NV
    If they are available to you. Many here have used Bridgestone Potenzas in the stock size.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    About 32K miles back I installed a pair of 175/55R15 Continental ContiProcontact tires. I am now down to 9/32nds. Time to replace??? The measuring device shows 6/32nds as replace time.
    Default Good info above....
    Spyder ryders have been using car tires for some time now. It all started with the rear tire and the apparent short life of the OEM Kendas. The fronts faired much better but later on many changed them to car tires as well. There were problems getting car tires in the recommend sizes and some would not sell them to you if you mentioned what you were putting them on. There is now a long list of tires folks have tried. I myself have had good results with the Kendas and continue to use them.You can search here for the many brands and sizes being used....
    Aug 2019
    NC
    Are the Vredestein tires on your stock rims or did you mod them?
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by fabillingsley View Post
    Om my stock rims.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Nov 2018
    Claremore, Ok.
    did the older RT have 14" tires? My 2015 has 15" tires. I bought 2 Federal Forneza AZ01 from Walmart on-line for $56.xx each delivered to my local store for free. I took them to my favorite tire store in town and then went home to get the Spyder and they mounted and spin balanced them for cheap. They're soooo much better handling in the twisties, like they're glued to the road. Great in the rain and torrential downpours. I highly recommend them.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Revalden View Post
    Yes the 2010-2012 had 14 inch tires. They changed in 2013 and have been 15" since then.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2012
    Central Coast, CA
    When I had my 08 with the 14" rims I switched to General Altimax tires in front and was very happy with them. I don't know if they're still in production or not since it's an antiquated and odd size tire.
    2020 RTL SE6
    Jun 2019
    jstreet
    Today installed 2 front Vredestein Quatrc 5 185/55/14... Rear 225/50/15, What a difference..2012 RTS, SE5....
    for those that are curious of install price: $233.00.... Yup, and I provided the tires.. 2 front and one rear...
    $57.50 x 2
    $80.50 x 1
    Plus disposal and Tax...
    2012 RTS SE5 , Spider Web Brake pedal Orbital blue
    Quote Originally Posted by CADRE View Post
    $57.50 x 2
    $80.50 x 1
    The last time I checked for the Quatrac 5 ….. they weren't making a …. 225/50/15 ….. So please tell us where you bought it …..thanks …. Mike ……… PS , I'll bet those 185's were a tight fit ……….they did fit …. - correct
    Dec 2015
    Oakley Utah
    It sounds like your tire guys are giving you good advice
    2014 RTL Platinum
