Page 1 of 5 12345 LastLast
Results 1 to 25 of 119
    Mar 2013
    Default Tools needed for Ryker wheel change
    You will need BRP socket #529036457, and a torque wrench that goes to 300 nm (221 #lbs). Plus a large external snap ring plyers.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Default Of course...!!
    Or go to the dealer... guess if you do some of your own work it is worth it but seeing as there is no belt you only need it to change the tire. Could rent the wrench or do what I do...220lbs full body weight and an extra jump.... my weight
    May 2009
    Connecticut
    Everything else seems to be fairly customer friendly, why not the tire removal. I have to take the front off to wire my led fender lights unless the amber cap on the side comes off because I will run the wires up in that tunnel and the light will start just past the tunnel.
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2016
    Indiana
    It's held on with one nut and a spring clip. I'm not sure if you can even rent the tool anywhere. If you watch Sean Smoak's second vlog on the Ryker he shows the tool you need to remove the nut. Also not very many cheap torque wrenches will go that high.
    It seems for all the things that BRP made easier to service on the Ryker, the tires aren't one of them.
    Feb 2016
    Paw paw mi
    well its not hard it will just cost you more than you would like if you already had the tools it would be no big deal
    Durham,Maine
    Don't know what the tool cost but if your handy with a torch or plasma rig you could easily make the tool! And just use the 220, jump method.
    2012 RTL , Pearl
    May 2009
    Connecticut
    May 2009
    Connecticut
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    The torque wrench shouldn't be too bad. Even in 3/4" drive its only about $110 . https://www.northerntool.com/shop/to...7235_200627235
    65 mm socket is only about $40. https://www.toolbarn.com/sunex-465m....ce53f7f2a90643
    2019 Ryler Rally , Shock Yellow
    Mar 2013
    Quote Originally Posted by Tslepebull View Post
    I do not believe that 65 mm socket would work as the nut used on the Ryker is not standard shaped. This is based off what Shawn S. Showed in his first video so I could be wrong.
    As for the T wrench years back I was able to pick up a used snap-on 3/4" that goes up to 250 ft# from a snap-on salesman that was a trade in for a fraction of the cost.
    https://youtu.be/nv8ZgGaMN9Y?t=164
    Dec 2018
    KS
    I kinda wonder if my rear wheel wasn't torqued properly. When I accelerate forward after being in reverse.... or, after deceleration/stop... I hear the typical clunk of the drive shaft and then a moment later after the acceleration continues, I hear/feel a pop... almost as if the spline joint slips just a little because the nut isn't tight enough???? I dunno. Thoughts anyone?
    2019 Rally , Black on black
    Mar 2013
    Quote Originally Posted by CTAC View Post
    You can go back to the dealer and ask them to check it and see if they will allow you to watch them do it so you will know if they have the correct tools and not doing the 220# Bubba method
    Dec 2018
    KS
    Thanks... I will do that on Wednesday ☺
    May 2017
    Mesa, Arid-Zone-A
    Or, do what I do. Enjoy a few extra calories and use 3/4th of your body weight and not have to try to jump.
    Semper Fi
    SoFlo
    My thought, if you own a Ryker, buy the correct tool. The cost is not inexpensive, but not break the bank.
    Get the correct socket, keep a note of the correct torque, then store it on your Ryker at all times. If you have an issue with a flat or failed tire, the current trend from tire shops is not to install a plug from the outside. The tire shop removes the tire and patches it.
    Without the correct tool, damage may occurr to the nut, which no doubt is expensive also. Without the tool, a simple flat tire may require a tow to the nearest Can Am dealer, which will likely only replace the tire.
    As for the torque wrench, those that have experienced incorrect torques from an inexpensive torque wrench understand why a quality torque wrench is essential. I would be more comfortable applying 110 pounds directly into a 2 foot long bar or 73 pounds onto a 3 foot bar vs using an inexpensive torque wrench that has not been calibrated.
    Dec 2018
    East Texas
    What you are hearing is likely drive-line lash. It is common in any shaft drive bike. It is caused by the play between the teeth on the shaft drive meshing with those of the final drive. It actually needs to be there so that the lubricant can flow between the gear teeth. All of my BMW's have done it. It would still be a good idea to verify with the dealer just to be sure.
    Dec 2018
    East Texas
    Quote Originally Posted by PW2013STL View Post
    Now I see what you are saying. The nut looks like is way more than 6 sided. The Can-Am tool it will be.
    Mar 2013
    I counted 12.
    Houston
    Does anyone have a close up picture of the hub nut? Will a standard 65mm hub nut socket fit this?
    These are pretty common in the truck service field. Many Fords use a 65mm hub nut. The socket is under $20 at most auto parts stores. $40 will get you a name brand one.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Dec 2018
    East Texas
    I counted 12.
    This is actually listed as a socket specifically for a 12-point hub nut. It is cheap enough I may buy one and give it a try. If it is not a perfect fit the fall-back plan can still be the Can-Am part.
    https://www.ebay.com/itm/65mm-HUB-NU...T/262670282877
    Mar 2013
    Check out my link in post 10.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Why would Can Am do such a stupid thing. My 1800 Valkyrie is a single swing arm and the wheel is put on with 5 lug nuts just like a car. Doesn't make sense to me. I think their engineers are looking at formula 1 race cars too much.
    Feb 2016
    Paw paw mi
    my bike.jpg love my Valkyrie cant wait for my Rally Ryker
    Jan 2009
    austria
    HAUBEOFF.jpgmaybe one of the Designers has an old Jaguar E ??
    I love the idea of opening the front for service and the way how they fixed the wheels !!
    https://mossmotors.com/long-handle-k...nal-knock-offs
    Sep 2018
    Australia
    Quote Originally Posted by bscrive View Post
    Lower parts count to keep the cost down was the official reason on one of the early vids,same went for the shaft drive it was cheaper to produce than the belt and pulleys etc, with the bonus of being superior engineering for the job at hand.
