Results 1 to 5 of 5
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Default Stop LED hyperflash
    I have several tricLED lights and do have the dreaded hyperflashing. There are excellent videos on how to correct it but it seems to come back from time to time. IS there a component that can be added somewhere in the wiring that will forever prevent hyperflashing?
    Aug 2013
    SF Bay Area
    Ask TricLED.
    2021 F3 Ltd , Magna Red
    Mar 2015
    forrest above Reno, Nv
    Yes, Resistors can be added in line. I put mine close to the tail lights. There is some discussion as to put them in series or in parallel. I tried the button touching and holding but the hyper flash came back. Solder and shrink wrap and it's permanent, no trouble in years of use.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2013
    Quote Originally Posted by Lew L View Post
    Lew L
    Hi Lew,
    What value resisters did you use, and did you put one on each side?
    I will need to do this on my F3S as well.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2015
    Quote Originally Posted by PW2013STL View Post
    Hi Lew,
    Hi PW,
    I think 50 Ohms, 1 watt, one on each side----BUT those values are just a dim memory in a 71 year old brain. Tricled would know best. Superbright LEDS is another source.
    Good luck,
    Lew L
