Results 1 to 16 of 16
Thread: SHIFING
    Apr 2014
    Felton Delaware
    Default SHIFING
    Took my wifes 2014 Can Am Spyder STS SE5 out for my first ride today. Went about 30 miles and it rides really nice. We live in the country mostly back roads so it seems i spent a lot of time in 3rd gear rpms aroud 4000/4500. She was told keep the rpms around 5000/5500 or so . What is the correct way to shift these bikes. Semi Automatic. She told me she stays in second gear alot to keep those rpms up. I did notice going into the turns it was better for me leaning forward a little and get into turns . Its not my Goldwing Trike but it would be fun to ride from time to time. Any suggestions
    Faribault, MN
    Ride it more! Sounds like you're doing fine, the engine was made for high RPM's. I've got a 13 RTL that has pegged 12k on the tach at times when I'm driving it like an ST. Though I do normally keep it above 4k unless I'm coming to a stop. Still running strong.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2017
    Mesa, Arid-Zone-A
    I tend to shift between 3-4000. The 1330 does not need to run at higher RPMs like the 998'
    Semper Fi
    Feb 2012
    Spring City,Utah
    It's an ST guys,VTwin
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2017
    Mesa, Arid-Zone-A
    OOps
    Semper Fi
    Jun 2010
    Las Vegas
    Poppa your wife is a smart lady and is riding her Spyder the way it was meant to be ridden -at rom over 4000.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2014
    Felton Delaware
    Hers is the 998 and I will keep the rpm's up .Thanks
    Default Doing great....
    Don't know if it was explained to you but so you know the reason for the high rpm is the clutch on the twin is not fully engaged till your above 3,400 rpm's. So ryding under that you are basically slipping the clutch and it will wear out prematurely. Being a 5 speed you would not be in 5th gear until your over 70 mph...Not to worry these engine are very happy at high rpm mine runs most the time between 6 and 8,000. You get used to it...
    The 998 likes high rpm's. 5000 - 5500 or higher gives best engine response.
    Low speeds, first and second gear is right on. I drove Hana Highway in HI (50 plus miles), tight turns and low speeds everywhere. Never got out of first gear.
    Planting the outside foot and leaning slightly into the curves will lessen the "g" forces and make your ride easier. If you have to brake at the entry to a curve--your speed is to fast.
    Jul 2018
    New Jersey
    So how do you keep the rpm's up on the 1330 when your in cruise control. If am doing forty and i shift i can get into 6th gear and the rpm's are about 2200. Are you saying i shouldn't be in 6th gear but a lower gear to maintain 3k+ rpm's???? I'm new to this whole thing never rode a bike or trike.
    Joe
    2018 F3L , Blue
    Mar 2016
    Indiana
    Quote Originally Posted by jlc41 View Post
    Joe
    The 1330 uses completely different shift points. It doesn't need the high RPM's.
    Joe
    The 1330 shift points are 3000 - 3500. This is the "happy" spot.
    60 mph in 6th will give you about 3500 when in cruise control.
    The gear that gives you mid 3000's should be gear you are riding in--for best performance.
    40 mph--I would recommend third gear.
    Jul 2018
    New Jersey
    10-4 all, thanks for the replies.
    2018 F3L , Blue
    Aug 2018
    Winchester, NH
    Default shifting
    Like my HD I have always run 30's mph in 3rd, 40's in 4th and so on. Depending on conditions uphill or down. The Spyder 1330 is very similar. Do not lug the engine. It likes to spin. Just my 1 cent worth....Polly
    Apr 2017
    Pittsville Maryland
    Default TOW MODE
    Quote Originally Posted by poppajim View Post
    I shift at 5-5500, same bike I have found running in tow mode the bike downshifts at 3-3500-no lugging and i dont have to manually downshift i got 13k on mine love it
    Steve
