Results 1 to 14 of 14
    Nov 2015
    Tinley Park, Il
    Default power from battery tender leads
    Good evening, can I plug into my battery tender leads to get a power source for my phone or GPS or what ever. I know it would always be live but I always remove my phone and 2nd GPS (yep 2nd, it has somethings my Zumo 660 doesn't). And does battery tender make leads that will do this like to a usb plug. Thanks, Mike
    Jul 2010
    Las Vegas, NV
    Default Yes
    There is a SAE plug USB port available. Amazon. We use it. I had one in a saddlebag to use to recharge my phone.
    Joe Meyer
    Northern Kalifornia
    Default Do what Joe says.........
    That's exactly how I charge my phone or power my heated jacket.
    Nov 2012
    North Las Vegas, NV
    Google battery tender accessories.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    You can even get them on EBay...
    Nov 2015
    Tinley Park, Il
    Thanks, I will try that. I still want to hook up one that works only with the ignition on, what's the best way to do that? Thanks, Mike
    Northern Kalifornia
    Default Key on hot lead...
    Splice into one of the hot leads of the fuel or temp gage.
    Nov 2015
    Tinley Park, Il
    Thanks, Mike
    Dec 2015
    Oakley Utah
    Default Adding accessory circuits
    The best way to do this is to first purchase and install an electronic fuse block. E.g. https://www.amazon.com/Show-Chrome-A.../dp/B01M4K65UO
    2014 RTL Platinum
    NorCal - Northbay
    They do! I am using the single for when I need to charge my phone if I forget or play music from it ALL day etc... They are sold on Ebay, Amazon and tons of other places besides directly from them:
    http://products.batterytender.com/Accessories/
    Chuck
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by hypurone View Post
    Thanks, just ordered one from Ebay, Mike
    Mar 2018
    Ontario ,way up north
    On my 2018 RTL ,i ran the aux and power with ground from the battery up through spare switch cover . I run my zumo ,and if needed power a compressor or tender .Phone will charge in the trunk usb port.
    2018 RTL , dark blue
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by stmike 1800 View Post
    Do you carry a compressor with you, if so which one. Thanks, Mike
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by wmh9680 View Post
    Just got it, thanks, works great, just gotta conceal it now
