Results 1 to 23 of 23
    Central Ohio
    Default F3 brake link rod mod
    Disclaimer: These are not instructions to perform your own modification; if you do it in spite of this caution, I will not be held responsible if something bad happens.
    My wife recently became the proud owner of her own Spyder, an F3 Ltd. For her to be comfortable, the floorboards are back in the number 1 position but the shortest brake link rod causes the brake pedal to be very high and uncomfortable to use. I looked at other solutions and decided to cut the rod, shorten it and weld it together.
    The rod is actually a tube 1/2" OD and 1/4" ID. After cutting it in two pieces, I used various thicknesses of wood blocks to experiment with a comfortable pedal height. We found 1-3/4" between the bottom of the brake pedal and the top surface of the floorboard to be the best for her. That equated to cutting approximately 1" out of the brake link. I cut a piece of 1/4" steel rod slightly shorter than the remaining length of the brake link and inserted it into both pieces of the brake link. I could now temporarily reinstall the link on the Spyder so she could test for "panic stop" full depression of the pedal to ensure she did not run out of brake pedal throw (this was done while sitting in the garage, not on the road). I ground a bevel on each cut end of the link and used some "T" shaped steel pieces to keep the clevises aligned. The 1/4" rod inserted in the ID maintained linear alignment. I used my TIG welder to make the full penetration weld, ground the weld bead flush with the OD of the link, and sprayed it with gloss black.
    My wife is now very comfortable with the brake pedal position and that's what matters!
    H2O
    NorCal - Northbay
    Cool! There is an adjuster at the MC pushrod to do this. Tho it may not have the full range you needed. But nice to know for fine tuning purposes....
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Live, Love, and Ride! God Bless!
    Nov 2012
    North Las Vegas, NV
    Great solution. It would be nice if you could use threaded rod inside the tube so you could fine tune it.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Central Ohio
    I looked at using the adjustment rod but after reviewing the shop manual, it appeared that adjustment was intended to be a fixed distance, and if I remember correctly, there was a special tool/gauge used to set that distance. Needless to say, I decided not to mess with that.
    Sorry, I did not photograph the process.
    I also considered threading the ID of the tube and using a threaded rod on the ID, but was concerned the small diameter may bend. There is also the possibility of threading the OD of the tube and using a long coupling nut, or if you want to get fancy, thread one side with left-hand threads and use a turnbuckle body.
    Using some type of threaded connection for fine-tuning seemed to be a worthwhile goal, but we spent at least an hour with the blocks of wood and her pivoting her foot over to the brake pedal to ensure she was comfortable and had plenty of throw, when needed. I guess we did the fine-tuning on the "front end" of the modification process so I'm very confident in making it permanent by welding the joint.
    H2O
    Aug 2016
    Australia
    As a new Owner of a F3 T Limited I found the pedal height with floor boards and wearing stiff boots dangerous. My initial mod was shorten the rod by 1/2 inch but the pedal was still a bit high. Problem is if the rod is too short the pedal can lock up. Better solution has been modifying the pedal itself by moving the hole across the bottom of the bar. That also involved a bit of welding to change the shape of the bottom of the pedal. The height of the pedal is now just over 2 inches.
    Invalid Emails
    Sep 2015
    Cheshire Ma
    Quote Originally Posted by hypurone View Post
    That adjuster will make the pedal go down farther before the brakes start to work but the return spring will bring the pedal back to the same place you started at.
    Invalid Emails
    May 2016
    NW Washington State
    As an FYI McMaster Carr (http://www.mcmaster.com has the proper 1/2" OD X .260 ID 4130 rod (PN 89955K779 36"@ $27.00) and all the threaded rod ends you pick what size and thread you need. I got two that are 5/16" fine threads. I'm building a custom rod for my bad ankle. When I received the rod ends I noticed they were made by QA1 (www.qa1.net). They are another great source for bearings and rod ends.
    Active Member nealperkins's Avatar
    Feb 2017
    Fort Myers, FL
    Quote Originally Posted by Habib View Post
    Ditto the bad ankle and I really need this solution. When you finish your project would you update me with directions (mechanically challenged...in addition to the bad ankle...life..) ?? Thanks so much!
    Greenville Tx
    For what these Spyders cost, there should be a button to electrically move the brake peddle for 2 different riders.
    2017 F3 Limited
    Nov 2012
    North Las Vegas, NV
    The bike came at #3 and I drilled a hole 1/2 inch shorter to lower the pedal. For #4 I made a rod out of 1/2 inch square tubing and it works just fine. 1/2 inch shorter span between holes worked great for us.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    United States
    Default F3 Brake Pedal Mod
    Roadster Renovations has been working on a mod for this F3 issue for several months. We expect to start product testing by individuals sometime next month. Without going into a lot of detail, I am really excited at what this will do!!
    Jul 2017
    sarasota, fl
    Quote Originally Posted by Roadster Renovations View Post
    since the first day I got my F3, I've been hoping for something to address this.
    Have been planning to try one of the DIY mods, but will wait to see what you come up with.
    Keep us posted
    Springfield, MO
    I've been doing these mods for a few folks as custom jobs before there were floorboards for the F3. Now that my wife and I both have floorboards I went into production and should have the production units heading to the powdercoaters next week. One rod will work for a #3 and a #4 to lower the pedal. We got spoiled with our RIP boards as they put the pedal where you see them now.
    Modified to lower pedal but still give you full brake in panic stop.
    Stock pedal
    Stock boards no mod. This will work with stock boards and pegs.
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    Default My question is
    Will either brake pedal modification work in the #5 position? I don't see any mention of that.
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
    United States
    Quote Originally Posted by MNBK View Post
    Yes.
    Springfield, MO
    We can do a #4-#5 , I even did a custom #6 for a really tall guy with pegs.
    Sep 2008
    TX
    Be careful when doing your brake rod mods: shortening the rod changes the arc of the brake actuation vs displacement of the master brake plunger. If you're going through the effort of cutting and welding, moving the pedal placement won't mess with the geometry of the rod. (I made a tandem brake setup in the #1 and #4 position, modifying the #1 as just stated.)
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Springfield, MO
    Quote Originally Posted by pauly1 View Post
    Wayne
    I have rods out there since 2015 with no issues. What did you do different to yours?
    Aug 2017
    Spokane, WA
    The clevis has a post that sticks into the rod. If you cut only the rod with a skinny wheel right by the original weld you can leave the post. Then grind the old weld away before inserting the shortened rod and re-welding.
    United States
    Default Our solution available for sale soon
    To contact for information, please use this link:
    https://www.roadsterrenovations.info/contact
    Jul 2015
    Edmonton AB Canada
    Default LaMonster Brake Pedal Adjustment
    Quote Originally Posted by Lamonster View Post
    you mention you can make them for position 4/5. Will those be available when your production gets going? What is the expected cost? when are they expected to be available?
    Feb 2018
    Colorado
    I have also seen a break lever extension that could have worked.
