Results 1 to 12 of 12
    May 2017
    Mesa, Arid-Zone-A
    Default Yikes...Tire size
    I don't want to start another discussion about tires. There are way enough already here. After researching this forum I purchased a General Altimax RT43 215/60R15 rear tire and a pair of Federal Formoza AOZ1 175/55R15s for the front. I will have the fronts mounted on Monday. Tuesday, bike is going to the shop to have the rear mounted along with a new drive belt installed (darn rock). The tires all look awesome (for a tire). But, the front tires look like they are a bit big to fit under the fender. I do trust you who have installed these slightly bigger tires and am confident they will fit. But.....they are noticeably bigger!!! Thanks to all who have contributed to tire information. And I want to especially thank Mike and Peter for your expertise and advice. The information you provide on this subject is invaluable. I am anxiously awaiting my "new" riding experience.
    Semper Fi
    Default TIRES
    Quote Originally Posted by canamjhb View Post
    . Thank you for your kind words, I'm sure Peter will appreciate them also ..... Those Formoza's have been fitted by others here so I'm sure they will fit yours ....Personally I put General Altimax's in 175/65 -15's on my fronts with basic fenders but I did bend the brackets a little ..... From my understanding of the problem with clearance with the New Style Front fenders ...is caused by the NEW inner plastic side piece .... I believe if you don't use this any clearance issue would be resolved ..... this piece is more a Splash guard than anything else ..... and since you like my advice ... the fronts can run at 15psi and the rear at 18psi .... they will have better traction , especially in the rain .... and the ride ( ie comfort ) will be better ...... The tire is ACTUALLY a part of the suspension system ...... a high psi car tire will give a hard ride .... Mike
    Apr 2015
    Green Bay, WI
    Default Where to shim the front fender for a larger tire?
    I know a few people with grooves cut into their side walls which doesn't sound healthy to me.
    Darrell
    Default GROOVES !!!!!
    Quote Originally Posted by Wildrice View Post
    Darrell
    .. REALLY ...who in their right minds would do this ......... I have used washers between the fender mounting brackets and the HUB .... Also up to 1/8 th in. washers on the wheel studs before mounting the wheel/tire ...... the washers ( especially on the studs ) should be as close to an EXACT fit for the bolt/stud size .............. Remember if there is NO contact with tire and bracket ...this will not change even with lower tire pressures , because any bulge with be at or near the road surface not where the brackets are ..... good luck .... Mike
    Apr 2015
    Green Bay, WI
    I guess the clearance looked ok to them initially--then a few hundred miles later---the Picasso artwork appeared--Abstract Infoitem--it's a Greek mythology thing--I don't get it either.
    Nov 2012
    North Las Vegas, NV
    I just got the Formozas in the stock size. Waiting to wear out the Kendas.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    I installed Continental Contiprocontact 165/60R15 on the fronts. Same width number as the OEM but a bit larger diameter. There isn't much room to spare between tire and fender so the 175 may be pushing it close.
    May 2017
    Mesa, Arid-Zone-A
    I'll know for sure tomorrow but looks like everything will be A-OK. the 175/55s are actually 3/8th of an inch wider and 2/10th of an inch taller than OEM. Your 165/60s are actually taller than the 175/55 by a tenth of a inch. It seems there are many here running 175s without any issues. Stand by for actual results.....
    Semper Fi
    May 2017
    Mesa, Arid-Zone-A
    With Wildrice's comments in mind, after I removed the front tires, I did a good search of things that could potentially rub the wider tires. The 3 bolts that attach the fenders to the fender brackets protrude unnecessarily far into the fender wells. I removed them and snipped a quarter inch off each one with bolt cutters. Now, if anything were to rub, it would only be the smooth surface of the fender bracket. And, I can get my little finger between the new tires and the brackets. The top of the fender is also close but still has little finger clearance. No rubbing of any kind noted. The new tires are awesome. Had them mounted and balanced at Costco. What I thought was the dreaded belt vibration at interstate speeds is now completely gone. The bike is smooth and solid on the road. I had some pretty good cupping on the OEM tires, especially the right one. I will now never know for sure, but I bet I also had some tread separation happening. Every little thing I have done to the bike (Elka shocks, Squared Away, etc.) has made a noticeable improvement to the ride. By far the biggest improvement has been replacing the front Kenda tires. Total cost of the tires replacement including mounting and balancing was $150.00. Should have done it long ago. The bike is at the shop having a new drive belt and rear tire installed as I write this. I'll pick it up in a couple of hours and am anxious for all the future miles of smiles. Thanks again to all those who provide excellent insight and thoughtful comments.....
    Semper Fi
    Apr 2015
    Green Bay, WI
    With Wildrice's comments in mind,... The new tires are awesome. Had them mounted and balanced at Costco...
    Did you purchase the tires at COSTCO? What was the brand/size of the tires.?
    Costco fills their tires with Nitrogen which is great because the tire pressure doesn't change with heat.
    Darrell
    May 2017
    Mesa, Arid-Zone-A
    Purchased tires on-line. My first post has brand and size.
    Semper Fi
    Vermont
    I am also running the Continental Contiprocontact's on the front( size: 165/60 R15) which was installed last year. I have not had any problems. Also, there is not much space between the fender supports/ fender outside. It is about the width of my finger for space.
    I am also running the General Altimax RT 43 on the rear, (Size: 215/60 R15) no problems, and I have 16,209 miles on them. There is a lot of tread left.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
