the fronts are not a problem but they have the rears, can they install them too?
That front looks OK but I wouldn't use the rear.
ANY tire on a motorcycle with uninterrupted tread grooves down the middle of the tire (this one has 2), will tend to follow grooves in the pavement and make the handling feel unstable.
Of course that problem would be more pronounced on the fronts, probably, but I wouldn't take a chance.
Good luck, most that try them give them thumbs down.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
We'll see....
Now that you have them, and at a good price, have them put on, any dealer will put them on as they are for motorcycle use, and get back to us with a review. They have not gotten good reviews yet I have been running a rear Arachnid for some 5,000 miles and it has done well. I did have to adjust the tire pressure I was used to on the Kendas which did well for me also. I am an aggressive ryder and will see how long this rear tire will last. The kendas got me over 15,000 each and 33,000 on the fronts. You be the judge.....
Thanks for sharing!
This info is helpful, and I appreciate you putting it out there for us. Obviously some have shared their input, but I agree that what will really help is your feedback on how they perform for you, and with respect to any of the detractions (grooved pavement etc) noted. Thanks again, and please keep us updated!
Mhbenz
Originally Posted by qwed1
What's the difference in middle grooves???? I don't see any, do you?? My stock Kenda is the same thing and I have never had a highway groove problem.
I didn't say that they are "different".
I said that I might not like the way they track in some situations.
Have you ever gone across a steel grated bridge ?
There is a really "good" one across the Ohio river at Paducah, KY; US 45 I think.
It will test your nerves. If you are on 2 wheels and have a center groove in either of your tires, it will REALLY be a test.
Test
Test ? It's a test in a full size pickup. I would not want to cross it on a motorcycle, 2 or 3 wheels.
Monique,
2016 F3t pearl white
Ultimate driver back rest
12v power outlet for batt. tender
Doc Humphries' vibration damper
factory floorboards
added topcase
Chicago
Try driving in Chicago.....all the bridges are steel grates, but a little wiggling won't hurt anyone. Cars do the same thing, but 3 wheels are better than 2!!!
If you are talking about the bridges over the Chicago river, those are what, maybe 150 feet long ?
The bridge I mentioned is close to a MILE long.
And I think that a "little wiggling" can indeed hurt some riders.....if they are unskilled, inexperienced or very high strung.
Granted, these bridges are not long, but remember you are in anywhere from 3-5 lanes of Chicago traffic and you are not really staying in your lane.....that is unnerving.....!!!!
I have driven in and around Chicago for about 50 years.
Maybe I missed that bridge that has an open metal hash grate and is more than 2 lanes wide AND where the traffic moves at more than 30 MPH.
The one and only time I went over the Ohio bridge, I met a semi coming the other way.
And the lanes are VERY narrow.....and the speed was a bit over 30.
Boy, am I confused now! Glad I don't need tires yet on my first Spyder!
O. J.
Ridin' "Lucille", the MusicMaker
a 2017 F3 Limited (Pure Magnesium Metallic)
Wife, Jan, riding "Ruby Jane"
a 2016 F3-T (Intense Red Pearl)
Spyder tires " for special motorcycle use only "
Sorry if all the rhetoric has confused you (we kind of got off on a tangent with Chicago bridges) but I have spoke to several dealers about VEE Rubber and they seem to agree that if the tires have been designed for Spyder's with their ABS and Traction control systems in mind and the handling, then they should be OK. I have also seen the YouTubes about car tires and that they handle fine, but I have heard nothing about how well they work with the Spyder ABS or Traction Control and this is what you really need to be concerned about. Frankly, I decided to try the VEE Rubber tires this go-around and I will let this forum know what I experience.
If you buy tires that are made for the bike, there should be no problem no matter whose you buy......stay tuned for the test, which will probably not happen till next riding season.....I don't plan to change them till I pack the little lady up for the season.
Hope that clears things up.....
#1 ... on this forum it's well documented that Vee rubber ties and Kenda's are poorly made and MARGINAL at best .... the info on the sidewall isn't a recommendation of quality .... IT'S A WARNING - don't use this tire on ANY other vehicle because even on a Smart Car ( the lightest car available ) ... it will fail very early in it's claimed life span ......" If you have either one ...I'll for you "......This quote is based on Tire Science not a guess ...... Mike
It's all been done before, qwed. There are a gazillion (well maybe a million) Kenda, Vee and car tyre reviews on the Forum. If you want to find out how car tyres perform with nanny, a bit of a search will yield a great many reviews, which don't have any issues with nanny and car tyres. Some swear by car tyres and some swear by the Kendas. It all comes down to personal preference, of course, but I have chosen to go with car tyres for the safety reasons expressed by Mike and Peter A due to their significant detailed knowledge and real world credentials, added to the weight my F3-L is carrying. Personally, I find the Kuhmos far more planted and confidence inspiring for my style of riding than the Kendas ever were.
I look forward to your review.
Harrington, Australia
HeliBars Handlebars
Ikon (Aussie) shocks all round, with sag adjusted for extra 3/8” clearance up front
Kenda Kanine rear.
TIRES ETC
Originally Posted by Peteoz
It's all been done before, qwed. There are a gazillion (well maybe a million ) Kenda, Vee and car tyre reviews on the Forum. If you want to find out how car tyres perform with nanny, a bit of a search will yield a great many reviews, which don't have any issues with nanny and car tyres. Some swear by car tyres and some swear by the Kendas. It all comes down to personal preference, of course, but I have chosen to go with car tyres for the safety reasons expressed by Mike and Peter A due to their significant detailed knowledge and real world credentials, added to the weight my F3-L is carrying. Personally, I find the Kuhmos far more planted and confidence inspiring for my style of riding than the Kendas ever were.
Pete , you are making me cry with your accolade about my ability ( but it is true & and the same goes for Peter A. , IMHO ...... Thanks
HeliBars Handlebars
Kenda Kanine rear.
How did these tires work out for you?
Me too. I need a nap now.
the statement " I have also seen the YouTubes about car tires and that they handle fine, but I have heard nothing about how well they work with the Spyder ABS or Traction Control " should give the answer but in case it didn't yes car tires work just fine with the ABS and the traction control. I have been running a car tire on my 2012RTL for over35,000miles and it has worked great. I will continue to use car tires on the rear of my Spyder when I replace this one which will be this spring.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
