Results 1 to 16 of 16
    Sep 2015
    Yulee fl
    Default Rear rotor torque?
    Got my balancer in from lamonster today new tire will be in tomorrow.got the kumho ecsta ast
    Does anyone know what the torque specs are for the rotor,caliper,and axle bolts?
    From what ive been reading on here i should probably go buy a lttery ticket for getting 14,180 miles
    Out of the factory rear tire lol. Anyway if anyone knows the specs it would be appreciated thanks
    Nov 2015
    Myerstown, Pennsylvania
    What model & year please?
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Jul 2015
    Dorr, michigan
    For a 2015 RT
    rear brake rotor bolts 68 lbf FT
    rear caliper bolts 77 lbf ft
    rear axle nut 166 lbf ft
    2020 RT Limited , Petrol Blue
    Harrington, Australia
    Quote Originally Posted by mcurtright View Post
    I have a 2016 F3 Limited, and that looks like an RT.......I have only commented as you may get differing specs for the axle, as BRP changed from a lower torque setting of 90? or so to 160 ft/lbs a couple (few?) years ago........AND...... 160 is bloody hard to get to.
    Disc Rotor 68 ft/lbs
    Brake Caliper 77
    Axle 166 (+/- 10lbs)
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2015
    Yulee fl
    Sorry forgot to put that in its a 2015 rtl
    Fatcycle has got you covered
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2015
    Yulee fl
    Ok thanks alot found several videos on taking the tire off but no one mentioned torque specs i appreciate it
    I will let you know how it goes i will be mounting tire myself called several tire shops and nobody will touch it
    Get the standard answer of hell no
    Jul 2015
    Dorr, michigan
    I got the same response when I called, so I just took it into one of those tires shops with a new tire and the rim and said can you change this for me? They said sure no problem, I never did tell them what it was for.
    Quote Originally Posted by Fatcycledaddy View Post
    Yep, same for me.....all 3 local tyre shops were happy to change it......mind you, I did buy the tyres from the shop I used to change them. There is absolutely no difference to changing a normal car wheel/tyre, except they have trouble balancing it.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Ryan12's Avatar
    Apr 2017
    Wichita, Kansas
    Default Tire
    I took my whole rear wheel and hub assy to my local Dealer here in Wichita, KS. and had no problem putting on the Yokohama S Drive. Took 15 min and $27. Im a happy camper. Heck I thought 96 FT lbs was a lot if torque for my 2012 RT.
    Sep 2015
    Yulee fl
    Got my tire and balancer on today. Was not too bad even mounting tire myself everything
    Seems good belt is running almost center of the pulley. Has anyone else noticed the
    Parking brake pawl on the caliper rubbing on their muffler? Once again thanks for the
    Info on torque specs
    Jan 2019
    AZ
    Have a 2013 RT. Anyone know if the torque settings mentioned above are the same for the 13.
    Jan 2019
    AZ
    Discount tire did mine, no problem. Couldn't balance it.
    Nov 2018
    Claremore, Ok.
    Since you've taken it off yourself, take it in and there's no need to tell them what it's off of. Keep going around the shops until you find one that has the small hub lock.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Oct 2020
    Arizona
    For a 2015 RT
    Are these numbers the same from our 2018 RT-L???
    Oct 2011
    Kalamazoo, Mi
    I don't believe that these have been changed since the 2014's
    For a 2015 RT
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
