Broke my right side footrest bracket.
I was an idiot and put a tad to much side pressure and my bracket, when moving my seal floorboard to the side to get my tupperware installed, after I put on the heat management system.
I'm looking to see if anyone has a good source for a footrest bracket? I am looking used if possible. If anyone has a GS or RS parts bike, or a good motorcycle junk yard near them I could use the help. Thanks
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
BRP Passenger armrests
Baja Ron Anti sway bar
Lamonster's upgraded BRP vibration damper.
T.I.G.
find a good T.I.G. Welder, and have him/her weld it up.... you'll be ok....
Dan P
SPYD3R
Dan P
SPYD3R
Even though it is cast? It will need to hold some weight, It is a main mounting point for the Seal floorBoards. Will it still hold?
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
WELDS
most welds are stronger than the parent metal... find yourself a guy/gal that knows the requirements of welding aluminum... it needs to be heated prior to welding, alum tends to disperse heat faster than other metals, so adding heat prior to welding is a necessity... most GOOD body shops will have the proper equipment and personnel... check around... and good luck....
Dan P
SPYD3R
check ebay..all kinds of used parts for sale
Yeah I looked, only seen a left, if you seen one please let me know. People post stuff all the time under different names. I just ran out of names to call it in a search.
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
Might can give these people a call.
http://stores.ebay.com/PinWall-Cycle...=p4634.c0.m322
David
705004182 Silver RH Foot Support. RS $102.99 USD
Be careful what you pay for a used one.
at that price get a new one
Price on new one here. try this link. select #50 in the silver and add to cart. Part is $77.24
http://www.powersportswarehouse.com/...E5/70337/70343
David
Originally Posted by Warlock
Sorry but that link will only work for you only because it is your cart. No one else can see it.
Little checking..
cheapcyclepart.com has them also for 102.99 but if you google used motorcycle part you will find outfits that will search nation wide for the part...
Went back and redid link.
David
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
Thank you for looking around, I do appreciate the help. It is funny though, you found the best price I have seen at $77.24. I found a site that sells it for $92.68, the best price before you. Then I look deeper, your site charges $23.94 to ship and my site only $8.50, with the total for both sites the same price of $101.18. Good deals never seem to be as good as we think . On the other hand if I can find something else to buy, they both have free shipping on orders over $99. I will be looking on your site as it gives me $21.76 to play with. Then I will be getting the part I need and something I can use for the same price as if I had paid the high shipping cost.
Again thanks to everyone for looking and giving me some ideas.
Be a good time to order some filters to make up the difference. JAT
David
