Results 1 to 25 of 28
    Delhi,ca
    Default Tire valve stems
    Greetings to all
    I am getting ready to install a new back tire on my 2010 RT-S w/20,200 on the original tire and I would like to put steel valve stems on. What is the diameter of the valve stem hole and has anybody changed these and where did you get them?
    Jul 2010
    Las Vegas, NV
    Default Better idea
    Put a new steel valve stem where you can get at it! Buy a 90 degree stem in steel. Cycle gear has them. Measure and Mark, drill a hole in the rim, install stem. Mount tire. Problem solved.
    Joe Meyer
    Delhi,ca
    Default valve stem
    Quote Originally Posted by cptjam View Post
    Why would I want to drill, I'm just looking to replace what is there now. That's why I was wondering the valve stem hole diameter, I was wondering if it was a .453 or not
    May 2014
    Benson, NY
    Default .453
    It is the standard .453. I put an enkei valve in my rear tire.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Active Member Mikel53's Avatar
    Amarillo Texas
    Default Weight and balance?
    I want a 90 degree valve stem so it's easier to check pressure and it looks like you would have better access on the right side. Would a steel valve stem mess with the weight and balance of the rear wheel? Where can I get one?
    Mike Campbell
    Amarillo, Texas
    2015 RTL "intense red pearl"
    Quote Originally Posted by Mikel53 View Post
    http://www.jpcycles.com/search/searc...012733&Ntk=All
    Check the balance after installing.
    Default METAL VALVE STEMS
    I have done this THREE times already .......KURVEY GIRL . COM sells steel ones 85 or 87 degree's ( close enough ) or get it elsewhere .............. My advise is when you drill the NEW HOLE .....put it almost in the CENTER of the RIM , this way it won't interfere with the TIRE MOUNTING MACHINE .............don't ask how I know this ...................And you can leave the other one in...........................JMHO........Mike
    Delhi,ca
    Default Tire stems
    Thanks for the responses, I was hoping it was the .453. Now I just have to decide how much of an angle I want to go with.
    Default ANGLE DIFFERENCE
    Quote Originally Posted by Madincalif View Post
    The difference between 85 -87 or 90 is so small from 10 ft. you couldn't tell the difference .....jmho...Mike
    Feb 2016
    I used these on three previous bikes. They are very well made.
    http://www.motorcycleanchor.com/tire_valves/
    2020 RT Limited , Marsala Red
    Delhi,ca
    Default Valves
    I do like the looks of those I just don't know if my FOBO's would fit with those
    Default TIRE VALVES
    Last time I looked a pair from Kurvey girl was 2 @ $10.00 shipped !!!!!!!!!.....But that was for junky not STEEL ...not super lightweight Aluminum ...... and saving 8 grams makes a big difference on a 750 + lb. Spyder .....Mike
    Delhi,ca
    Default Tire valve
    True....don't want junk. Found some really nice 60 degree ones I think I'm going to try.
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Got any pictures. Getting ready to install a tire tomorrow and already have some of the 90 degree valve stems.
    thanks, David
    Default VALVE STEM CHANGE
    [QUOTE=Madincalif;1185658]True....don't want junk. Found some really nice 60 degree ones I think I'm going to....................I was being SARCASTIC !!!!!!! ...... and GOOD LUCK with getting a 60 degree valve to work, I think from the right side ( disc side ) you will actually have more problems getting anything to seat on the valve.......remember neither steel or aluminum is going to bend AT ALL ......But what do I know ....I've only done 3 to date ................Mike
    Default THE MIDDLE ? ? ?
    Quote Originally Posted by Warlock View Post
    thanks, David
    David, the middle is the middle !!!! ......... If you need a picture to find it ......I think you should not do this Mod .......................jmho, Mike
    Oct 2011
    Magnolia, Ms
    I have no problem finding it. Been a chief mechanic for 35 years. I just like to see how it looks. I might not like the way it looks on the rim. Excuse me for asking for a picture,.
    David
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    ...................I was being SARCASTIC !!!!!!! .....................Mike
    YOU??.........No.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Tampa FL Area
    Default Valve Stem Position
    Has anyone modified the valve stem on a RT to point to the right side?
    It seems little difficult to check the air from where it is now.
    Harrington, Australia
    It's really, really easy to check the air with FOBO on the stock stem. Then if you see a change that alarms you, you can check it manually.........and they work fine on the rubber stems according to both the local Spyder dealer and the tyre guy.
    Since it takes me ten minutes to get down and back up these days, I wouldn't ride without them.
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2012
    Spring City,Utah
    If you want to check the rear tire easier Harley makes an extension that allows you get the gauge and air chuck up where you can see/use them. It is $10.00 at your local Harley Davidson dealer.
    http://www.harley-davidson.com/store...stem-extension
    90* stems
    http://www.ebay.com/itm/like/2819166...&ul_noapp=true
    another idea
    http://www.awdirect.com/wheel-master...161209002039:s
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Yeah, but you still have to get down there and back up, Paul.....maybe if they made an inflatable knee pad that you could insert the air hose into after you had finished your tyre work, that lifts the knees to an upright position.
    90* stems
    another idea
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2012
    Spring City,Utah
    I'll tell you what if you bring me to Oz I'll check your air for you and at 70 it aint all that easy for me either but for you Pete I'd do it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member JimVonBaden's Avatar
    NoVA
    WAY better than steel!
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
