Results 1 to 25 of 39
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    Default How often do you use your Battery Tender, if you ride a lot ?
    I ride my Spyder RTS at least 5+ days a week to and from work and for pleasure. I have not hooked up my Battery Tender Jr since it was cold. Do you guy's and gal's use it when you ride frequently?
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    May 2016
    Denver
    Battery Tenders are, for me, just a winter thing. I guess if I were going months between rides during the summer months it'd make sense but as long as it runs every couple weeks, I don't see it the least bit necessary.
    Nov 2013
    Central Texas
    I only use mine during the winter when my is serviced and put away from approximately late November until maybe early April. Otherwise, I am riding pretty much every day and do not need to charge up or maintaint he battery. But it is a must when put away for winter storage.
    Invalid Emails
    Sep 2015
    Cheshire Ma
    I use mine twice a year once in the middle of winter again just before first ride in spring, do the same on my motorcycle and it's seven years old hoping for 8
    Default BATTERY TENDER
    If I'm not riding it's on the Tender ...... I don't think the Battery was properly set-up prior to delivery, because it has always seemed weak when trying to start it...... According to another Dealer the charging system is working properly, but I don't know that for a FACT ........... Mike
    May 2016
    Denver
    If I'm not riding it's on the Tender ...... I don't think the Battery was properly set-up prior to delivery, because it has always seemed weak when trying to start it...... According to the Dealer the charging system is working properly, but I don't know that for a FACT ........... Mike
    If you have a voltmeter, check the voltage at the battery with the engine running. If it's around 14v dc, then your charging system is probably fine. If lower, like 12v, then you might have a problem.
    Mar 2012
    NJ
    I do the same as Mike and do this with all my bikes. If it's not being ridden and just sitting in the garage, its on the tender. It takes about 5 seconds to plug it in.
    Sent from my Nexus 6 using Tapatalk
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default Same here...
    Quote Originally Posted by oldguyinCT View Post
    ....exactly the same in our cases. (the 4 of us)
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Sep 2016
    Alma,Arkansas
    Default battery tender
    Question: would it not be a good idea just to disconnect the battery, for long term storage?
    I don't care for battery tender that supply constant .75-1.00 amp charge. I use a battery anailizer for any of the long term bikes. The Battery Anailizer by Schmacher, supplies a charge rate as needed. This happens around 90-95% of max charge voltage.
    I am not calling out "Battery tender comany" only talking about the charger systems.
    Good Luck
    Sep 2016
    Pueblo Colorado
    Quote Originally Posted by Belrix View Post
    So do you just have to open the battery compartment and test it with the voltmeter?
    Sent from my SM-G900V using Tapatalk
    Aug 2016
    Central Illinois
    Default Battery tender
    I use mine year round on all my bikes.
    Riding 5 days a week you probably don't need to use it, but for any prolonged inactivity (greater than a week) I would plug it in.
    Quote Originally Posted by Aracknoid View Post
    Good Luck
    ........." BATTERY TENDER " is actually a Brand name ....for a battery maintainer ...... and they do not supply a constant charge ( to the best of my knowledge ) ...they supply a float charge as needed by the battery ......This is why they are called a MAINTAINER .......not a CHARGER ...............Mike
    Very Active Member Vader's Avatar
    Hudson Valley
    If I know I won't be riding for more than a week, as mentioned, it's on my Battery Tender Jr.
    Super easy to connect to the pigtail I installed to the battery.
    IT IS, WHAT IT IS...
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Everyday regardless of the amount of use, unless away from home.
    AJ
    Quote Originally Posted by ES44AC View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Mar 2013
    Oz
    Here's my take, to add to the mix...
    Twins = Tender
    Triples = Tough - "not so tender"
    The triples have a higher capacity proper alternator; the twins have a stator thing which doesn't start recharging the battery until 3500 revs.
    I always use/d the battery tender on my RS/ST models if I'm not riding every day or so... learnt the hard way.
    Jeff hasn't used one at all on his F3.
    I can't talk about putting them away for winter, cos luckily we don't need to do that.
    Default Depends....
    How long the ryde is and how much added items using the battery you have added to your machine. The more consumption the longer it takes to charge back. From what we see here it seems the older RT's have the least hold on the charge. I have an RS with minimal extras and don't use a tender even if I don't ryde for a couple of weeks...rare...we also ryde all year round.
    Dec 2008
    Jacumba, CA
    NEVER! We are on our 3rd Spyder. I ride year round, 5 days a week going to work. Never bought a battery for any of the three Spyders.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    May 2016
    Denver
    BnG: if you have a tender cord attached, you could test right at it by sticking the test probes in it, no need to open the bike up. On F3 the battery is in the frunk... easy reach. I know other models have it well hidden.
    In general, though, I recommend measuring at the battery as first choice.
    Sent from my LG-H901 using Tapatalk
    In the rare occasions that the is not ridden regularly I seem to be okay with no Tender for at least three weeks. The Tender goes on for more than that period of time. I usually take the out to get a full charge before the Tender goes on for the winter sleep.
    Feb 2012
    Spring City,Utah
    During riding season I don't used a battery maintainer,but when the bad weather comes and the bike goes under wraps then I hook it up.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Well when your DPS fails because your battery is undercharged you wish you had plugged it in[emoji51]
    Adrian, Mi
    Default Tender
    My Spyder is always hooked up to the Tender when it's not out on the road providing me with my Spyder therapy . I even invested in a tender for the ugh... lawn tractor . Fellow at the dealership said it would help with battery life, YMMV
    Jim
    Jun 2014
    ny
    mine hooks up during the winter but if i were to be away for a few weeks i would plug it in also
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by Dudley View Post
    You would, if you didn't trade them in so often.
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by PaladinLV View Post
    AJ
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Well there are two opposing views. I do pretty much what SPIDERMAN does, but I'm wondering how many folks unplug their battery maintainer when away from home. I've never heard of potential fire problems on any of the better units that have a "float mode".
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
