Results 1 to 25 of 36
    Active Member TheCajun1957's Avatar
    Kilgore Tx.
    Default Super Clamp Spyder Is Discontinued.
    I Really liked the idea of the Superclamp spyder. it would hold your spyder in position with out having to tighten straps against your wheels or parts of your frame. Seemed like that would throw out an alignment if done incorrectly. I know there are a lot of posts on various ways to tie down a spyder, what I would like to know is has anyone found another system that can be bought as a kit (everything you need in one package) that does the same thing as the superclamp system?
    Jan 2015
    southern WI
    Quote Originally Posted by TheCajun1957 View Post
    Use 3 ratchet straps, one over the top of each wheel. Can be purchased in sets of 2 or 4. And then pick up 6 "eye hooks" for your trailer deck. Position the Spyder where ya wan it on the trailer. Put a strap over each tire (in the travel direction) and let the strap hang vertically down to the deck. You'll mount your eye hooks at the ends of each strap. And that's how you'll ratchet it down. It can be done for under $50 and is scratch free and doesn't pull or push on any suspension components. Here's a picture of the rear tire, just do the same for the two fronts and you're golden.
    2016 RTS , Pearl White
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    Is the Spyder Super Clamp discontinued ? No comment of that in original post.
    If SO....do they have stock on hand ? I will look into it too....
    Craig From Albany Oregon
    May 2012
    Palmyra, TN
    Default While there are other ways
    Super Clamp is the easiest, the best. Just that simple.
    Sep 2009
    Albany, Oregon
    It is still on their web site...so I sent them an email.
    Guess what.....the manufacturer just called me ! 7pm their time
    Yes it is discontinued and they are 100% sold out. Discontinued as; they are made in Canada, many of the materials come from the US and material costs have gone up 30%, then when they send them out of Canada the dollar exchange rate....they get screwed. So they basically can not afford to make them anymore. If they did a new retail price (they are already not cheap) would be prohibitive. He has a dealer that plans to send a few back to him, new, so I have my name on one if that happens.
    I was waiting hoping to see a price drop. Best system I have seen for the Spyder..... Oh well.
    Default BEST SYSTEM - REALLY
    Quote Originally Posted by WEB-WVR View Post
    The BEST SYSTEM is in post #2 ...... I started this over two years ago, and now people are finally doing it....... you could actually turn the entire trailer over and the Spyder would re-main ON THE TRAILER ....That wouldn't happen with the SUPER-CLAMPS ..................Mike
    Nov 2013
    Oro Valley Arizona
    Super Clamp, the best gift I ever gave to my Spyder. I have them and would never go back to the Dark Side of Straps, Chalks, Ropes and stopping every fifty miles to see if my Spyder is OK. If anyone has a used set for sale jump on it. They are fantastic.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2012
    Palmyra, TN
    Default Sorry, Mike
    I used your method before the Super Clamp. I am guessing you never used the Super Clamp.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Mazo EMS2 View Post
    How dobyou ratchet it down? Looks like the rear fender is in the way? And is it a problem releasing the tension to remove the strap as well.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Quote Originally Posted by M109Dreamer View Post
    ......His YELLOW STRAP is kinda long ( I think that is an older PIC ) ...Mine is much shorter ..... and you don't need to rachet much 3 - 4 at most and that tire is NOT moving...... ........If there was a " Diamond encrusted Solid Gold Super - Clamp " .......... can you guess which Spyderlover would own one ....maybe TWO ................... Mike
    Vermont
    Mike ( Blueknight911) is right about the BEST SYSTEM in post # 2. He used that system on my( first) 2012 RTSE-5 and my SPYDER DID NOT MOVE. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Mar 2011
    Jackson, MS
    ......His YELLOW STRAP is kinda long ( I think that is an older PIC ) ...Mine is much shorter ..... and you don't need to rachet much 3 - 4 at most and that tire is NOT moving...... ........If there was a " Diamond encrusted Solid Gold Super - Clamp " .......... can you guess which Spyderlover would own one ....maybe TWO ................... Mike [emoji106]
    Lol, yep I could prob guess.
    Sep 2009
    Albany, Oregon
    The Company just called me....they got 6 back from a dealer. One gone, mine is on the way. At this moment they have 4 new in the box left. When they are gone, they are gone. I only put this here as a courtesy. You will need to go to Superclamps web site. Do not order off the site. Call their main number and ask for Todd.
    Default SUPER DUPER CLAMP
    Yes hurry hurry before C. J. buys them all and has them Gold Plated ......Mike
    arntufun
    Guest
    A lot of spyder owners were suckered into this (IMO) stupid way to tie down your Spyder. Most of the people that bought these have no clue they are ratcheting their spyder down on cheap cast metal (a very soft brittle metal) footpegs rather than strong secure wheels.
    It's unfortunate that some spyder owners are not informed enough to realize that cast metal foot pegs is not something they should secure to. Not to mention the stress on the suspension.
    Besides, you can make these by purchasing two ratchet straps and two camper wheel chocks at $25.00 at Walmart.
    Jan 2015
    southern WI
    It does kinda look like it's in the way in the pic, but it's not. Ratcheting and releasing work just fine.
    Nov 2015
    Hagerstown, Maryland
    Default Glad I bit the bullet a couple years ago
    Yes, they were not cheap but I got the Super Clamps several years ago and they were well worth the money. I retired the Goldwing because it was becoming too much bike for a 70 year old man. Now the last thing I would want to do is crawl around over my trailer tying down the bike. Hopefully someone else will step up to the plate for future Spyder haulers.
    Default SOMEONE ALREADY HAS !!!!!!!!!!!!!!!!!!!!
    Quote Originally Posted by Spyderideron View Post
    Just put a strong Rachet Strap over the rear tire ( in-line ) and your Spyder will not move .....Screw a couple of wood blocks along side each front wheel and it won't slide either ...... see Pic's in an above post....... Mike
    Sep 2009
    Albany, Oregon
    Only the best for my baby ! She is high maintenance !
    Invalid Emails
    Jun 2008
    Augusta, GA
    And a variation of this one would be the folding D rings. Easier to drive over.
    Default D- RINGS
    Quote Originally Posted by GA-SPYDER View Post
    . Yes - just make sure you BOLT them to trailer .... do not trust screws ........ Mike
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    ​What a surprise! That's my Spyder and trailer.
    Jun 2011
    Hendersonville, NC
    Our just use something like this
    Default THOSE ATTACHMENT DEVICES
    Quote Originally Posted by CanAmMick View Post
    Mick, I'm the one who started the Rachet Strap thing..... so I know how much pressure is exerted by the strap ..... How exactly is that plug (?)( screw-in piece ) held to the trailer ( which looks to be an aluminum deck ?? )........Thanks Mike
    Nov 2014
    TriCities, WA
    What is the big deal with the super clamp? By the picture it looks like you just butt the front tire to it and maybe the orange part "locks" the tire?? I'm thinking that a DIY duplicate would be easy to do.
    Whatever you do I agree use bolts through your deck.
    Their whole site appears to be down.
